Old 08-22-2014, 08:48 AM   #155
FR-S Matt
This is one expensive piece of plastic with no proven gains. Stock one works just fine and doesn't cause any unnecessary turbulence to re-tune for.
You might get a few degrees cooler temps but only on the highway. Otherwise, this looks like a huge marketing gimmick to take everyone's money.
Old 08-22-2014, 11:40 AM   #156
xoa
Drives: GT86
Answer from HKS:
Installing the intake duct and Hybrid filter will help increase airflow into the engine but in itself will not significantly affect fuel consumption which is more directly related to how you drive the car with these parts fitted.
The Premium Suction Kit is designed and tested for use with the factory engine and ECU. It will not damage the vehicle and will not require a remap even when used with the Intake Duct.
xoa is offline   Reply With Quote
Old 08-22-2014, 02:54 PM   #157
wbradley
Sarcastic SOB
wbradley's Avatar
Hey I'm not Mexican but I think a 2L soda pop bottle or a bleach jug could easily be adapted to the existing snorkel using plastic weld cement. The piece looks like it cost .50c to make, might as well make one for .50 c
The Following User Says Thank You to wbradley For This Useful Post:
chaoskaze (06-24-2015)
Old 10-09-2014, 02:42 PM   #158
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
@CSG Mike I saw you guys include this on your track packages. Is the main benefit throttle response? Also do you have any thoughts on this compared to a modded snorkel (i.e. cut and stretched wider)?
I'm about to get an intake and figure I'll mess around with the bumper at the same time. I had originally planned to just mod the stock snorkel but when I saw you guys sell it I figured you must think its worth something.
Old 10-09-2014, 02:48 PM   #159
J.C.
Drives: '13 Raven FR-S
Going to be pairing the Airaid intake with this along with my Innovate SC w/ headerback exhaust and Delicious Tune.
With the stock intake I noticed a bit better throttle response when I added this duct. Nothing major but I'm sure it didn't hurt either.
J.C. is offline   Reply With Quote
The Following User Says Thank You to J.C. For This Useful Post:
finch1750 (10-09-2014)
Old 10-29-2014, 08:22 PM   #160
Slysdexia
Slysdexia's Avatar
Drives: '14 Monogram 6MT FR-S - Hot Lava
Originally Posted by tjohnson104 View Post
i want this, but I dont want to remove the bumper... is it possible to install with keeping it on somehow..??
Well, actually...
Originally Posted by johan View Post
You don't have to remove the bumper to mod the snorkel...
  1. Remove the stock intake.
  2. Remove all of the bolts / clips holding the hood seal on and remove the hood seal
  3. Remove the two bolts holding the bumper to the alignment tabs above the headlights (to give you just a bit more slack on the top lip of the bumper)
  4. Remove the 6 silver bolts (2 on top, 2 by the header, and 2 on either side of the bumper facing the front of the car) and 2 clips (next to the 2 bolts on the front side) that hold the crossmember on
  5. Gently pry upward on the bumper and wiggle the crossmember out
  6. Profit
Did this last night to mod my snorkel. Was SUPER easy, I've removed many many many bumpers in my day (I've owned 18 cars, all modded one way or another), and this was trivial in comparison to pulling a bumper.
Here's the Proof:
Note:
There is a bolt and a clip down here. I used a ratcheting wrench to loosen the bolt, then fished it out with my hands. If you pry up gently on the bumper with one hand, it should give you just enough clearance to get your other hand in there to get the bolt / clip out. The clip is exact same style as the ones that hold the hood seal on, so a thin flat head screw driver works well for popping them loose, just be gentle.
Just be careful not to drop either of them into the bumper. Taking care to do this right, is worth it. The effort spent on these two bolts and two clips is far less than removing the bumper.
Remove these two bolts down by the header.
And the best part.....
Bumper still fits like a dream
I just did this to install my duct without removing the bumper.
Slysdexia is offline   Reply With Quote
The Following 4 Users Say Thank You to Slysdexia For This Useful Post:
8R6 (12-16-2014), frsvr4 (10-19-2016), johan (10-29-2014), JohnJuan (10-30-2014)
Old 04-13-2015, 03:03 PM   #161
1Cor10:23
1Cor10:23's Avatar
@Slysdexia @johan how much do you have to lift the top of the bumper to squeeze the snorkel back in? Does your HKS duct scrap against anything as you slide it back in? Reason I ask is because I decided to put heat reflective tape on mine and would like to try and avoid scraping it off.
Thanks!
Old 11-26-2015, 02:04 PM   #162
G-awesome
Drives: 2015 Firestorm Scion FRS
wonder if any one of those replica companies willing to create a knockoff of this and slash the price by like half! Shouldn't be that hard to make a mold and inject plastic. Ain't paying $200ish for this with minimal or little gains. :/
G-awesome is offline   Reply With Quote
Old 11-26-2015, 02:24 PM   #163
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
This is why we can't have nice things.
Sent from my HTC6525LVW using Tapatalk
JDKane527 is offline   Reply With Quote
The Following 2 Users Say Thank You to JDKane527 For This Useful Post:
go_a_way1 (11-26-2015), Pekingduck (11-28-2015)
Old 11-26-2015, 05:54 PM   #164
Gringosteve
Drives: UK Spec GT86
Stock snorkel is more than adequate
Gringosteve is offline   Reply With Quote
Old 11-26-2015, 06:00 PM   #165
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
False, these aftermarket snorkels are better and pull more air and in return are faster. I have the greddy snorkel andi can feel the difference. Also i have beaten other members from my 86 club with very similar parts yet still beat them because of the greddy snorkel.
Dr. BRZ is offline   Reply With Quote
Old 11-26-2015, 06:03 PM   #166
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Or maybe you are a better driver
Also I hope you are not racing on the streets
Dr. BRZ (11-26-2015)
Old 11-26-2015, 06:44 PM   #167
Cole
Not a troll
Cole's Avatar
Butt dyno, I assume. I highly doubt your overpriced piece of plastic makes you win.
Old 11-26-2015, 06:59 PM   #168
Dr. BRZ
Dr. BRZ's Avatar
Thats what i thought too but nope the other members and i agree that overpriced piece of plastic does make a difference.
PERRIN Silicone Intake Duct Review JoeBoxer Engine, Exhaust, Transmission 287 01-24-2018 11:01 PM
FRS bumper duct VENOM~ Cosmetic Modification (Interior/Exterior/Lighting) 36 12-12-2015 01:15 PM
TF Brake Duct Cooling Kit Touge Factory Tracking / Autocross / HPDE / Drifting 77 06-11-2015 08:01 AM
Maxracing dynamic intake duct Mars2 Engine, Exhaust, Transmission 123 09-23-2014 09:39 PM
WTB: Stock Intake Air Duct FR-S Matt Want-To-Buy Requests 4 08-12-2013 07:30 AM
