Old 10-28-2013, 11:21 AM   #127
kombatlion
Life to short to be slow!
kombatlion's Avatar
Drives: Toyota GT86
Anyone have any dyno on this or any performance gains?
kombatlion is offline   Reply With Quote
Old 10-29-2013, 06:36 PM   #128
Mixlplix
For those that have actually done it, how hard/tricky is removing the front bumper? Is it pretty straight forward or is there a f'ed up part to taking it off and puting it back on? Plz only reply if u have actually done it.
Mixlplix is offline   Reply With Quote
Old 10-29-2013, 06:45 PM   #129
Hanakuso
Originally Posted by Turdinator View Post
Plus the Prova, Maxracing and Symes ducts/intakes.
and the HKS Kansai
Hanakuso is offline   Reply With Quote
Old 10-29-2013, 06:50 PM   #130
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Not too difficult after the first time. I've taken it on and off 3 times. Make sure you remove all the clips before pulling anything so you don't rip any of the mounting points. It would help with another person to line everything up and connect the lights when installing it back on. Just take your time with it and all will be good.
JDKane527 is offline   Reply With Quote
Old 10-31-2013, 03:55 AM   #131
tjohnson104
Drives: brz
i want this, but I dont want to remove the bumper... is it possible to install with keeping it on somehow..??
tjohnson104 is offline   Reply With Quote
Old 10-31-2013, 04:29 PM   #132
diss7
Drives: AE86, 2x GT86, TE27
Anythings possible.
Except this.
Well unless you take the radiator and air con heat exchanger out through the engine bay, and then have go-go-gadget arms to get the duct where it needs to go, and some how fix it in place.
Just take the bumper off.
diss7 is offline   Reply With Quote
The Following 2 Users Say Thank You to diss7 For This Useful Post:
nguyen_er (08-19-2014), NoChance (10-31-2013)
Old 11-04-2013, 12:36 AM   #133
Trojan_SC
Trojan_SC's Avatar
Drives: '14 Monogram FR-S(RIP)
Dude the bumper takes like 5 minutes to take off. Just do it. I've taken mine off more times than I can remember. Too easy.
Trojan_SC is offline   Reply With Quote
The Following User Says Thank You to Trojan_SC For This Useful Post:
Trap63 (11-04-2013)
Old 11-04-2013, 05:45 PM   #134
Mobius357
Drives: '15 WRX '13 Legacy '07 Colorado
The alternatives are much more difficult anyway. Just buy a pair a pushpin pliers and it's no trouble.
Mobius357 is offline   Reply With Quote
Old 11-04-2013, 08:35 PM   #135
jebuwh
Village Idiot
jebuwh's Avatar
Drives: '13 FR-S Ultramarine Manual
does anyone have pictures of a modified stock one? since i would literally never see it under the bumper, i would have no problem wasting a few minutes dremeling the stock one. even if it truly adds no power... like other said. It cant hurt.
jebuwh is offline   Reply With Quote
Old 11-08-2013, 01:27 PM   #136
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Update - Front Bumper Mod
Originally I was going to cut out the Toyota/Scion badge, but upon further inspection/measurement.. it is better to cut away at the flat vertical part of the bumper like so:
The height of the holes is perfect for getting cooler air into the HKS Cold Air Intake, plus the HKS is situated about 1-1.5inches higher than the holes so there is a very very low chance for water coming into the air box.
I also changed back to my STOCK AIR BOX, however I'm using an AVO Filter(non oiled) and the PERRIN Silicone Intake Tube. Both wrapped up with Reflect-A-Gold Heat Wrap.
stevo_12v is offline   Reply With Quote
Old 11-08-2013, 03:11 PM   #137
Pitman
Living the dream
Pitman's Avatar
Drives: Fensport AVO Turbo GT86
I presume you mean very little chance of water getting into the air box, and not air as stated above?
Pitman is offline   Reply With Quote
The Following User Says Thank You to Pitman For This Useful Post:
stevo_12v (11-08-2013)
Old 11-16-2013, 01:59 PM   #138
stevo_12v
Covered my HKS tonight in some Reflect-A-Gold aswell
Old 11-16-2013, 05:35 PM   #139
Turdinator
Señor Member
Turdinator's Avatar
Did you notice much difference between the stock and TRD airbox with the HKS duct?
1974 TA22 Celica
2013 86 GT
Old 11-17-2013, 01:31 AM   #140
stevo_12v
Tiny bit more responsive. Slightly louder induction noise(non oiled filter)
PERRIN Silicone Intake Duct Review JoeBoxer Engine, Exhaust, Transmission 287 01-24-2018 10:01 PM
FRS bumper duct VENOM~ Cosmetic Modification (Interior/Exterior/Lighting) 36 12-12-2015 12:15 PM
TF Brake Duct Cooling Kit Touge Factory Tracking / Autocross / HPDE / Drifting 77 06-11-2015 07:01 AM
Maxracing dynamic intake duct Mars2 Engine, Exhaust, Transmission 123 09-23-2014 08:39 PM
WTB: Stock Intake Air Duct FR-S Matt Want-To-Buy Requests 4 08-12-2013 06:30 AM
