Old 07-11-2013, 06:19 PM   #155
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
My first parts arrived in the mail today.
The Following 2 Users Say Thank You to neutron256 For This Useful Post:
DAEMANO (07-11-2013), SloS14 (07-11-2013)
Old 07-11-2013, 06:27 PM   #156
jamesm
what a fitting name lol
Old 07-11-2013, 06:35 PM   #157
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
This is such an awesome thread. Subscribed all the way.
No Limit Motorsport is offline   Reply With Quote
Old 07-11-2013, 07:09 PM   #158
s2d4
s2d4's Avatar
I have looked it over. Some good motors but none seem quite up to the task.
May I ask how you came to that conclusion?
Old 07-11-2013, 07:21 PM   #159
Toma
Drives: Viper, Mustang, FD RX7, FFR GTM
Good god. I hope you are careful and dont hurt yourself? Do you have ANY electronics background? Scares me what you are about to attempt but cant do simple math.
Please be careful.
Toma is offline   Reply With Quote
Old 07-11-2013, 08:03 PM   #160
neutron256
neutron256's Avatar
Based on my own research what others have said here I've come up with what I think are some good minimum specs.
RPM: 30K
Power: 3000 Watts
Glancing over the list I don't think any meet this.
Please be careful.
You really can't help but be insulting can you? You really need to learn some manners.
Yes I have a strong electronics background, and lots of experience with high voltage and high current systems.
Old 07-11-2013, 09:07 PM   #161
Toma
Aghhhh Too much math, my brain hurts.
I'll be the first to admit that while I'm a huge science geek I suck at math which is why I would never have made it as an engineer.
So can one of you math/FI wiz's figure out how much power we do need to make this work?
And don't forget to show your work. J/K.
How did I insult you when you yourself said you cant do basic math? That's a bad sign when someone is about to start playing with caps and electricity.
Anyway.
None of you would be in this thread if Rob didn't do.it first and prove it could be done.
His kit is far more developed than you guys realize. Thats what makes some of ur comments funny.
Just wanted to make sure you acknowledged him on page one for giving you inspiration and proving it can work.
Old 07-11-2013, 09:17 PM   #162
Pete
Pete's Avatar
Drives: 22 BRZ
Anyway.
It looks like you are upset. Just calm down, what are you afraid of?
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
Pete is offline   Reply With Quote
Old 07-11-2013, 09:18 PM   #163
s2d4
s2d4's Avatar
RPM: 30K
Power: 3000 Watts
What is the torque spec required to drive the compressor under load at 30k, 50k etc?
Old 07-11-2013, 09:32 PM   #164
FAER
Drives: Silver BRZ
Anyway.
Toma i'm starting to think you're Rob in disguise... How about you stop crusading on his behalf and let the man come into the thread himself and voice his concerns...
BTW every exhuast/intake/wheel/etc thread should have toyobaru's head engineer on it because he gave everyone the inspiration to start their thread...
FAER is offline   Reply With Quote
Old 07-11-2013, 09:42 PM   #165
neutron256
neutron256's Avatar
As far as I know this is probably too hard to calculate since the torque would vary based on lots of variables.
I'm using 3000 watts as a good general minimum power reference based on what Toma (I hate to even mention him at this point) said about the Phantom setup.
Old 07-12-2013, 06:53 AM   #166
solma
Drives: Raven FRS
So neutron at what voltage do you want to run the motor? my feeling tell me it will be over 12V, will you use a step up circuit or do a parallel capacitor charging to serie discharging?
solma is offline   Reply With Quote
Old 07-12-2013, 08:15 AM   #167
neutron256
neutron256's Avatar
I've decided for now on a motor with a max voltage of 30V so I'm going to use 32.4V (12 x 2.7V). The max current is 110A which should give me about 30 seconds of run time at full power.
I'm not an expert on charging systems so I'm going to be consulting with a couple of people who are but at the moment I'm thinking a step up transformer.
Another challenge is that with a capacitor bank this size you need to balance the charge. This can be done with resistors (less efficient) or charge balancing circuits (more efficient).
I also want to add a few other features:
-Variable charging rate
-Charge indicator on the pack itself
-A built in discharge circuit so you can drain the pack for safety if you need to work on it.
I still might end up going with SLA batteries, but I wanted to explore the possibility of Ultracapacitors.
Old 07-12-2013, 09:17 AM   #168
Wild Weasel
Wild Weasel's Avatar
Drives: 2001 Sunfire GT + 2007 Mazdaspeed3
This is true... but I think it's exciting to see this sort of thing going on. For my part, I'll be very curious as to how this progresses.
Rob has put a lot of effort into the development, so I don't imagine he'd be terribly thrilled to see this DIY thing become a roaring success... but that's the nature of pretty much everything, isn't it? I actually think it's somewhat likely that the guys here start running into a number of pitfalls along the way that end up demonstrating what a good deal Rob's kit really is and showing that there's a bit more to this than slapping a few bits and pieces together and calling it a day.
I know I'm over-simplifying what you guys are up to, but you get the idea.
For what it's worth, I know there's instructions out there describing how to build your own somewhat basic but probably functional system, though without the advanced motor control that Rob has. I know this because I was asked to review them, probably with the end goal of an endorsement. In the end, I just kept quiet about the whole thing because, while it wasn't necessarily bad, I thought the actual work involved was well beyond the capabilities of pretty much any average DIY enthusiast.
The guys here will start discovering that as they go. I'm reasonably sure though that whether they end up with something that works well or not, a lot of people are going to have a lot of fun working on this.
Wild Weasel is offline   Reply With Quote
hairdyerperformance, only pulls hard one gear
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
DUP THREAD MODZ PLZ DELETE KTHX SloS14 Forced Induction 0 07-09-2013 05:41 PM
Electric Turbocharger Shankenstein Forced Induction 91 06-24-2013 02:47 PM
Electric 86 frosty86 Scion FR-S / Toyota 86 GT86 General Forum 8 11-10-2012 02:16 PM
WRX Electric turbo Neilus Engine, Exhaust, Transmission 42 05-03-2012 09:20 PM
