#155 | |
Drives: SSM LT MT BRZ
Go back and re read what i posted that was quoted that I responded to, Im not your second grade teacher your reading comprehension is not my issue, I didn't say any of the things you just ASSumed, I simply was stating why I wanted to see the dyno graphs and clarifying MY background on this matter, So now that you have taken this out of context and are on the defensive, tell me what part of what I said was wrong and please highlight where I discouraged any use of this product... |
#156 | |
Drives: Viper, Mustang, FD RX7, FFR GTM
Worst case, I'll buy EcuTek, it's not THAT bad, I think it was $2000 ish they quoted me, just saw it as a "mail order option" since they force you to buy a programmer with every car you tune, and most my customers, once i tune them on site, they have no need for their own programmer with most other platforms. Your call. I'd be happy to try it as long as you are not out the money for the tool. Either way, worst case, we can throw it on the dyno and see what it's currently doing and putting down. |
#157 | |
No we aren't and all you did was take 1/3rd of my statement out of context... if turbos put out more energy than it took to run them we wouldn't be paying for electricity and you would only need gas to start your cars... |
#158 |
Drives: 2013 FR-S whiteout
Turbos really don't put out any useable energy. They make it possible for the engine to burn more fuel. Taking 0.01 calorie of food and turning that into the muscle energy needed to strike a match to light the fuse on the bomb does not mean the energy the bomb releases is 0.01 calorie or less, they are two different energy sources, and can not be compared as such.
#159 | |
Drives: FR-S 10 #103 AT
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#160 | |
now besides the fact that you didn't understand my 1st post, and are hell bent on making yourself look smart...are you going to bring this back around to the topic at hand or should I just ignore your misguided attempts to skew my view point further? I wish there were a reading comprehension test required to sign up for the forums...a big part of reading comprehension comes in tying the whole of a statement together. So much gets taken out of context, you can't actually argue with anything I said, because it is all correct, I'm sorry it disagrees with what you want me to have said but get over it unless you have a valid point to make. I never even said this was a bad idea, quite the contrary...but you seem to be fixated on disproving common truths about energy and energy transfers. |
#161 |
You guys are all essentially on the same page. I was SUPER skeptical before I tested the Golf, especially since I was expecting some monster electric motor.
This is not free energy of course, but energy that is generated during a normal "stop and go" drive cycle, stored in batteries, then released on demand. They even experimented with different batteries, Lithium etc, and settled on the "small" AGM's. I cant remember what he said, but the batteries were very happy all the way down as we depleted them to ~21 volts over the course of many runs, with an actual very slight increase in boost as they did. I *think* recharge only took 5 minutes or so of idle time. If this thing can make 5 psi on the hit, I guarantee Nothing else except nitrous will offer the kind of bottom end hit this thing will provide. If they can size it to maintain 2.5 to 3 psi on the top, it will outperform other forced induction set-ups at probably 4-5 psi since there are no drive losses (does not charge at WOT). This kit, if all pans out will be great for the stop light bandit, or weekend warrior. Not suited for a 2 hour mostly wot enduro type race, or races where you need increased part throttle power. |
| The Following User Says Thank You to Toma For This Useful Post: | fenton (06-27-2013) |
#162 | |
Why are you being rude? I apologize if I misunderstood something you wrote. No need to resort to insults Last edited by SloS14; 06-27-2013 at 05:27 PM. |
#163 | |
see above statement, you are trying to read between the lines and you can't even read the text on the page, It is clearly a viable idea. I even expressed that I had spent time mulling over the potential losses of a similar setup for sometime now (not with the interest of development simply for experimentation...and fun) It's cute that you want me to not want this to work. but if you have been around for any amount of time you would understand where I'm coming from. essentially similar products (albeit without any decent hardware such as we have here) have popped up every couple of years, and have all been scams/lies/or too heavy and battery dependent to make up for their own losses. like all things there are more ways to get it wrong than right, I would like to see someone finally get it right, you could potentially use something like this to even fill in the lag from a turbo, reducing the pressure after the compressor will bring a turbo up to speed quicker since it works on pressure ratios. Am I skeptical? ofcourse, if you aren't...all of your lights aren't on...but as i stated (which you misread entirely and ignorantly) I hope this works. |
#164 | |
The 2000 bucks you pay as the tuner and that lets you build your own maps. I have the cable already, apparently all i have to do is flash the stock tune then you are good to go with brz edit. |
#165 |
Drives: 2013 Scion Frs(Scarlet)
#166 | |
I have a very strong command of the english language and have little issue making my point clear. I don't need people coming in and trying to tell the world what I meant to say, or taking my thoughts out of context, I came in here hoping to have good technical conversation with like minded people, not have to explain the basics of electricity and ICE to people that wrote me off as a hater before they finished reading my statement (which was a response to a previous misinterpretation of my statements.) besides that I'm an asshole, I see no need to offer courtesies to people who offer me none and take the liberty to misrepresent my statements. |
#167 |
Edit: not arguing with you anymore, back to topic.
| The Following User Says Thank You to SloS14 For This Useful Post: | SkullWorks (06-27-2013) |
#168 | ||
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 05:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 07:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 08:07 AM |
