Old 08-19-2014, 12:04 AM   #155
Vic
63 Auto Body
Vic's Avatar
Drives: 2013 SCION FR-S WHITEOUT
Wait a minute...can't we just install the headlight brackets with the fog bezel removed so that theres a huge hole for you to put your arms throught and tighten the the headlight bracket area down.
That way you can install the bumper with the brackets already on there for perfect alignment.
..but then this method will theoretically work only on install and the more you remove the bumper the more wear and tear the brackets will get.
I just thought of this and Im going to try this tomorrow...having this issue on my passenger side.
wish me luck @_@
Vic is offline   Reply With Quote
Old 08-19-2014, 12:11 AM   #156
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
@mkivsoopra @sw20kosh
Originally Posted by Shoebox View Post
For that price anyone could get a c6z and have money for a simple heads cam package and make a bunch more power and have a superior handling car. This seems overpriced to say the least. "Have it your way" is basically offering someone a massive dildo to shove up their ass BUT they have the option of choosing the method in which it is inserted....
unsurety is offline   Reply With Quote
Old 08-19-2014, 12:16 AM   #157
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Originally Posted by Vic View Post
Wait a minute...can't we just install the headlight brackets with the fog bezel removed so that theres a huge hole leading you straight to the headlight bracket area.
wish me luck @_@
That's not the problem though. I mean it would work if you permanently attached the bracket to the bumper.
Old 08-19-2014, 12:57 AM   #158
Vic
63 Auto Body
Vic's Avatar
well from what i see its usually the headlight brackets not holding the bumper in so the sides pop out, even if the sides marker arear holds the tabs in then the area near the headlights will tend to pop out.
For my method I was just basically saying to install the bumper with the headlight brackets already snapped into the bumper cover. then youll reach in through the fog light hole to tighten down the bolts. It sounds like a pain in the ass tho...
Im pretty sure for 50/50 of us its the alignment of the brackets thats causing this because I installed headlights on @Midarete's frs and aligned it perfectly and that didnt happen.
but not doubt that its a poor design flaw. I'll try tmw and give feedback!
The Following User Says Thank You to Vic For This Useful Post:
Midarete (08-20-2014)
Old 08-20-2014, 01:13 AM   #159
Vic
63 Auto Body
Vic's Avatar
You were right. the bumper is so shitty lolol.
and my theory failed...theres no room to work through the foglight hole.
boredom.is.me (08-20-2014)
Old 08-20-2014, 01:45 AM   #160
boredom.is.me
Custom User Title
You would have to mold a flare on both the bumper and bracket for small bolts. Even then, the molded extension would probably break.
Old 09-30-2014, 12:05 AM   #161
diirk
diirk's Avatar
Drives: 4Runner
This is my solution for the bumper. Hopefully they'll get it into production shortly.
http://www.ft86club.com/forums/showthread.php?t=75057
diirk
waiting on a Neptune Premium MT
diirk is offline   Reply With Quote
The Following User Says Thank You to diirk For This Useful Post:
Vic (09-30-2014)
Old 09-30-2014, 10:50 AM   #162
RFB
RFB's Avatar
Drives: FRS
My hope as well as I was trying to accomplish the same goal.
CERBERUS
RFB is offline   Reply With Quote
The Following User Says Thank You to RFB For This Useful Post:
diirk (09-30-2014)
Old 09-30-2014, 11:51 AM   #163
RFB
RFB's Avatar
Drives: FRS
I'm sure it will be a hot seller due to all the chin additions the twins have (lips, body kits, splitters etc.). Those additions cause weight and wind pull that will eventually cause separation gaps (not to mention all the chins that scraped on driveways etc.).
Almost all that I see with those accessories have the gap, those that don't may soon have the gap.
Iff'n you need another frozen northern volunteer - i'm in.
CERBERUS
Old 09-30-2014, 12:02 PM   #164
diirk
diirk's Avatar
Drives: 4Runner
CERBERUS
Exactly. That's one reason I haven't added a splitter to the front. I figured the extra downforce would make the gap worse.
I'm PM you the contact info for MOR.
diirk
Old 10-21-2014, 02:42 AM   #165
luluma
luluma's Avatar
Drives: 2013 Scion FRS
has anybody giving up on this problem?
anyone fixed?
luluma is offline   Reply With Quote
Old 10-21-2014, 10:03 AM   #166
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Bumper not lining up near fender?
Like most of you I took my bumper off to install some goodies and for the life of me could not get it to properly align in the sides.
I then took it off several more times to try to reposition it and all attempts failed.
I then saw a post for "revised" bumper supports that were in a Subaru TSB that had revised part numbers and thought that was the solution. I purchased them all, installed everything and while it wasn't perfect, it was improved.
Well improved wasn't good enough for me. I got tired of pushing on the bumper for it to momentarily be perfect then walk around the corner for it to pop back out of place.
I took a trip to Home Depot and purchased 1/4" threaded rod, 1/4" washers and hex nuts.
That resolved the issue for me.
I used what I saw in the photos from post 138
http://www.ft86club.com/forums/showp...&postcount=138
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
The Following User Says Thank You to ecko04 For This Useful Post:
sw20kosh (12-24-2014)
Old 10-21-2014, 10:45 AM   #167
DrunkMonkey45
DrunkMonkey45's Avatar
Drives: 2015 Brz Series.Blue
Maybe I missed it but what does your solution actually do?
DrunkMonkey45 is offline   Reply With Quote
Old 10-21-2014, 11:43 AM   #168
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Same thing as Post 138
Bumper and fender damage - Hit and Run 01s0uljah Cosmetic Modification (Interior/Exterior/Lighting) 40 12-24-2016 02:44 PM
Worn floor mats - Covered under bumper to bumper warranty? Philly758 Issues | Warranty | Recalls / TSB 45 08-19-2013 02:32 PM
Where to Buy Fender badges and bumper V light?? taimysho0 Scion FR-S / Toyota 86 GT86 General Forum 5 05-17-2013 05:31 AM
WTB: headlamps, fender garnish/cover/vent, and bumper reinforcement mariolefty1 Exterior Parts (Aero, Lighting, Etc.) 0 05-06-2013 05:52 PM
Need scratches/scuff marks buffed out of bumper or cheap bumper for sale [Cyanide] NY / NJ / CT / PA 12 12-28-2012 08:34 PM
