Old 01-07-2013, 05:17 PM   #155
gonzo
Drives: frs
7 cold, hard, abusive miles.
LOL
way to rub it in. I wouldn't be surprised if the car lost 5hp because of those cold hard abusive miles
gonzo is offline   Reply With Quote
Old 01-07-2013, 11:02 PM   #156
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
Dealer wasn't able to reflash my ECM so they ordered a new one. Also had the fuel pump replaced and they broke the plastic intake cover latch so will need to ask for a new one-they are $50
Life is short...NO BORING CARS
russv is offline   Reply With Quote
Old 01-08-2013, 10:47 AM   #157
WRXcellent
Drives: 2013 BRZ Limited WRB & 2002 WRX WRB
The dealership put 14 miles (which I think is excessive) on my car when I first brought it in for the Reflash Recall, Crickets, GPS, and Rear Popping noise.... all they fixed was the popping and then order the parts for everything else.
This past Friday I dropped off the car again and they only put on 3 miles when they fixed the crickets, gps, and replaced both taillights.
Like some other people posted after driving around since the reflash, revs seem a little different but I also feel the torque dip isn't as bad as it used to be. The best fix is not hearing "GPS Signal Lost" every morning anymore... I have yet to have an issue with the GPS signal after the fix. Crickets never bothered me that much as I usually always have the radio on, but stood outside the car at idle and don't hear them anymore. Taillights were a bonus because I didn't complain about them even though I noticed it once, and I think the Tech just pulled up all the TSB's and did all of them for my car.
WRXcellent is offline   Reply With Quote
Old 01-08-2013, 01:53 PM   #158
frs23
frs23's Avatar
Drives: FR-S H Lava
Same for me, but they didn't order a new one for me, instead they said they had link problems and for one car it took over a dozen tries to flash. Thus, they said they will wait for Scion to address the problem before flashing later on.
frs23 is offline   Reply With Quote
Old 01-08-2013, 01:59 PM   #159
russv
First 86
russv's Avatar
Mine was the first one they worked on. Kind of like having surgery by a doc that has never done the procedure before.
Old 01-08-2013, 06:20 PM   #160
OrbitalEllipses
Drives: Attitude
"It's okay I saw this on TV once!"
The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post:
russv (01-08-2013), siXXtoes (01-17-2013)
Old 01-08-2013, 10:59 PM   #161
enigmaaron
enigmaaron's Avatar
Drives: '13 Firestorm FR-S MT, '04 Tacoma
Originally Posted by chaotichoax View Post
In comparison to all other vehicle I've owned/driven this car takes more time to warm up completely.
Originally Posted by Calidrifter View Post
This^^^
And it also takes an ungodly amount of time to cool down.
Originally Posted by Opposed View Post
I also agree. I find it strange for a modern car to take this long to get to normal opp. temp.
Originally Posted by BRZnut View Post
Mine too...I can drive 10 mins to work and it is still not at normal temp according to the dash temp gauge, but the odd thing is the heat from the heater is hot. Can't figure that one out.
You guys realize you are complaining about a sports car engine running too cool right?
enigmaaron is offline   Reply With Quote
Old 01-08-2013, 11:06 PM   #162
Calidrifter
@Executive_chicken
Drives: Firestorm FR-S, Audi A3 E-tron
Lol, in reality I just wish we had an oil cooler to keep the temps down once operating temp is reached.
Club 4AG | Apex'i | HKS | GrimmSpeed | TRD | Beat Sonic | ENKEI | Cusco | Fujitsubo
Originally Posted by Jyn View Post
That guy, like me after BBQ Thursdays, is full of shit.
Calidrifter is offline   Reply With Quote
Old 01-08-2013, 11:20 PM   #163
Opposed
Drives: 2013 Asphalt FR-S
No, its not a matter of how cool it runs, but how long it takes to get there. And this engine does not run any cooler then a typical passenger car.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 01-09-2013, 02:26 AM   #164
chaotichoax
chaotichoax's Avatar
Drives: 2013 SWP BRZ
Exactly.
Epic fail alert
chaotichoax is offline   Reply With Quote
Old 01-09-2013, 08:30 AM   #165
enigmaaron
enigmaaron's Avatar
Ok, operating temp may be the same but it takes longer to get there. Please provide alternate reasons than the following two for this: the engine generates heat less rapidly than "normal" cars therefor it's less likely to overheat when pushed hard because the delta is smaller, and/or it's more efficient at dissipating heat thus taking longer to getting up to temp and being less likely to overheat when pushed. That is why I say the car "runs cooler", I'm not just talking about normal operating temp.
Old 01-10-2013, 01:51 PM   #166
developer
Drives: BRZ Limited
Does anyone know the VIN cutoff for this recall? Thanks!
developer is offline   Reply With Quote
Old 01-12-2013, 06:38 PM   #167
Propaganda
Diamonds & Cadillacs
Drives: '13 fr-s, 1974 911s
I think some others have posted, but I kept forgetting to chime in. After the reflash, yes the car gets up to temp SO MUCH faster than before.
Propaganda is offline   Reply With Quote
Old 01-12-2013, 07:14 PM   #168
Mo707
Mo707's Avatar
I haven't noticed. Haha
Mo707 is offline   Reply With Quote
Checking and Changing BRZ/FR-S Engine Coolant GrimmSpeed DIY (Do-It-Yourself) Guides 39 05-29-2023 09:15 AM
FT-86 low temp THERMOSTAT ft86-UAE Engine, Exhaust, Transmission 52 08-30-2016 04:46 PM
Blue Coolant Boosted2.0 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 108 07-12-2016 06:13 PM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 01:03 PM
European fuel/coolant gauge face arbnpx Cosmetic Modification (Interior/Exterior/Lighting) 0 05-31-2012 01:23 AM
