Old 10-17-2011, 11:58 PM   #155
MannyO
Night Owl
MannyO's Avatar
Drives: 2013 Subaru BRZ
So here's my exercise in futility to get back on topic here. Spent a few hours scanning the interwebz for a sound clip and finally found one. You can hear it starting @ 10:44 Enjoy!
[u2b]tGlITzrLZsY[/u2b]
MannyO is offline   Reply With Quote
Old 10-18-2011, 12:16 AM   #156
Mr.Hachi.Roku
I'm NOT the *****istrator
Drives: 1NZ-FE
Nice find!!
Unfortunately it took one of the worst lines in that corner compared to the other cars before and after it......
I hope it's due to the driver, and not the handling...
Mr.Hachi.Roku is offline   Reply With Quote
Old 10-18-2011, 12:16 AM   #157
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Oh nice find! It has a nice tone to it but why was he going so slow into the turn?!
Old 10-18-2011, 12:23 AM   #158
MannyO
Night Owl
MannyO's Avatar
Well he did have his hazards on so I'm gonna guess he was just slowing down to let the Porsche and Aston by.
Old 10-18-2011, 04:35 AM   #159
Levi
Drives: Toyota
Very well, my car will get stripped down from day one. No stereo, no A/C, no airbags, no rear seats, but instead half-rollcage.
Levi is offline   Reply With Quote
Old 10-18-2011, 04:39 AM   #160
Slide
Drives: Toyota Aristo
And this can be a road car?
You can take air bags out without voiding road worthy or anything?
In aus you would get defected like nothing.
Slide is offline   Reply With Quote
Old 10-18-2011, 06:44 AM   #161
CyberFormula
CyberFormula's Avatar
Drives: gti, nsx, integra type r,porsche911
I don't hear anything at 10:44
CyberFormula is offline   Reply With Quote
Old 10-18-2011, 12:07 PM   #162
ForReal-Someday
Drives: Company Vehicle
I live in the middle of the US, and we have to get one $10 inspection every two years. Most of the time the only thing they check is that all of your lights work. If your car fails for some reason then it costs you $20.
ForReal-Someday is offline   Reply With Quote
Old 10-18-2011, 12:28 PM   #163
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
How did this manage to get in the same class?
Nearly stock FT86 stacks up well against an S2k.
Happy.
I'm not familiar at all with their classing rules, but you likely can't run an FT86 in a production class yet as there's probably a requirement that it's a.. well production car. So they ran it in a more open class. That would be my guess.
Basically stock CTRs did very well against the FT as well, but Type-R's in general tend to be quick on track (for what they are) so that's not all that surprising.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-18-2011, 12:37 PM   #164
fred_boosted
fred_boosted's Avatar
Drives: 2008 EVO X GSR (Sold)
I just want get a crazy turbo build on this thing...
fred_boosted is offline   Reply With Quote
Old 10-18-2011, 12:46 PM   #165
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by blur View Post
This car weights 2450 lbs WITH a cage that likely weighs 150 lbs or more, and an air jack system. The things they took out of the interior (seat, carpet, rear bench, plastic panels, a/c, speakers) weigh 50-75 lbs at the most.
Seriously though, I can't figure out how you lost 350 lbs by simply gutting the car. Care to explain?
Well I have no idea how heavy the tubing used in the cage in our integra race car is, but here's some links to pics in case you want to guess (1.75 tubing):
http://www.itrexpo.com/users/dave/chump/IMG_0451.jpg
http://www.itrexpo.com/users/dave/chump/IMG_0454.jpg
http://www.itrexpo.com/users/dave/chump/IMG_0459.jpg
http://www.itrexpo.com/users/dave/chump/IMG_0460.jpg
http://www.itrexpo.com/users/dave/chump/IMG_0461.jpg
Anyways, we removed:
-Door glass, quarter glass, lexan rear window (net savings of probably 50lbs mostly due to huge rear window)
-All 4 seats, fronts are ~30 each, rears are maybe 10 total, so 70?
-Speakers, no idea on weights.
-All AC components, compressor, lines, blower motor, heater core, condensor, evap, mounting bracket for comp (iron), total weight around 60lbs.
-All interior panels, and cut drivers door opening for nascar door bars. No idea on weights.
-Stock crash beam (normally under the rear seat, right where a bar in the cage goes now) and dash support bracing (again replaced by cage bracing). Some weight saved but mostly offset
-Airbags, 15-20lbs
-Dash itself maybe 5 lbs, it's just plastic and no real weight once everything is removed anyways
-Sound deadening including firewall mat. 50lbs
-ABS pump, wiring, computer removal and conversion to non ABS lines, 30lbs (mostly in the big pump)
-Spare tire and tools, not sure on weights.. whatever they weigh.
-Sunroof, motor and wiring 40-50 lbs, offset a little by sheetmetal and screws
-Power window/locks and associated wiring, window tracks, etc probably 25lbs
-Power steering removal (pump, lines, res, etc, rack looped with a breather)
And I'm forgetting various other items obviously and may be conservative on some of these weights. Everything that wasn't absolutely needed is gone from the car.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-18-2011, 12:52 PM   #166
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Legally, no, but it depends on where you live whether or not you'll get hit with it. Drivers airbag is removed in my ITR and if I ever find the passenger storage piece that replaces that airbag for cheap then I'll remove the passenger side one also.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-18-2011, 01:41 PM   #167
suprachica79
Drives: free Hyundai, 2006 Kawasaki ZX6R
Originally Posted by Scion FRS View Post
Get a grip? have you ever seen a football match that they failed in qualifying but came first?
Crack your empty head, everybody coming up with at least a 300hp & here they are giving us only 200? What is 200 nowadays? I dont even think it could move you & your fat gf.
First off, act with a little maturity kid. Secondly, a 300hp car would be up in the high $20k, low $30k range, which is not what this car is about. You expect a law $20k car to beat a low $30k car? This car is suppose dto be fun and affordable, a drivers car, not something that is insanely fast in straight aways. I guess I don't expect $30k performance for $20k, be a little realistic dude.
suprachica79 is offline   Reply With Quote
Old 10-18-2011, 01:52 PM   #168
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Exactly. A mustang will give you that power for low 20s and while it's a great mustang compared to prior generation mustangs it still isn't all that engaging to drive and shouldn't hold a candle to the actual driver feedback that the FRS should provide.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Pictures of Scion FRS in a different environment john FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 05-10-2011 05:46 PM
Report: Toyota FT-86 Sedan Version Coming Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 62 09-24-2010 10:45 PM
Report: Toyota FT-86 will move up in price and age demographic ft86cbx Scion FR-S / Toyota 86 GT86 General Forum 201 06-02-2010 04:36 AM
Report: Baby Toyota FT-86 also in the works Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 60 05-17-2010 08:41 PM
Report: Toyota chooses alternative Toyota FT-86 design (by Calty studio)! Nemesis Scion FR-S / Toyota 86 GT86 General Forum 128 02-19-2010 12:36 PM
