Old 10-08-2013, 03:49 PM   #155
BRZgirl
BRZgirl's Avatar
Drives: Subaru BRZ Silver Limited AT
I agree with your point. It is all a gradual process as the manufacturers find better and detailed ways to produce the same product. I am very open to seeing another company that can produce what you are saying below using two sheets of high quality titanium. It is again, appearance or durability and Greddy has done good on appearance, now let's wait for the one who can do both.
Originally Posted by Anaxilus View Post
I buy most of that explanation, except for the slant cut Greddy tip you seemed to have missed. Believe me, if the finish was as well crafted as the GReddy tip, I'd be all over the Milltek w/o a second thought. As it is, the less than perfect welding seems to coincide w/ the bubble blisters ghosted in the heat treated finish on the edges and some stories about leaking gaskets. I think it's a great product but some people like myself would like to see a little more attention to detail at a certain price point. I don't have a problem with the process, I have a problem w/ the semi-DIY finish/craftsmanship which is more than evident on the Ti tips on inspection.
BRZgirl Subaru BRZ Silver Limited AT
Pages:BRZ & FR-S Girls
Current Builds: Mann Stainless Steel Brake Lines, OEM Audio+, Speedline & Mann Engineering Type-25 Coilovers
Tune by:
Mann That's Delicious Future Builds: Brembo 4-Piston BBK
BRZgirl is offline   Reply With Quote
Old 10-08-2013, 10:11 PM   #156
fooyc
fooyc's Avatar
Drives: GT86-JDM
any 1 did a stock vs milltek (full system) dyno before?
fooyc is offline   Reply With Quote
Old 10-09-2013, 02:26 AM   #157
BRZgirl
BRZgirl's Avatar
Modified Mag did a write up of it. The gain seems a bit low, however the gain is throughout the entire RPM. And of course every dyno reads differently depending on environmental conditions and temperature. hope this helps!
http://www.modified.com/tech/modp-13...xhaust-system/
Tune by:
The Following 2 Users Say Thank You to BRZgirl For This Useful Post:
fooyc (10-09-2013), HotLeopardMama (10-09-2013)
Old 10-09-2013, 03:13 AM   #158
Trettiosjuan
Drives: GT86
Here one that a belgian forum member posted in the regional forum (Milltek full system resonated):
(edit: pic doesn't show, here is the direct link:http://www.hostingpics.net/viewer.ph...1327370001.jpg )
Trettiosjuan is offline   Reply With Quote
The Following User Says Thank You to Trettiosjuan For This Useful Post:
Old 10-21-2013, 03:17 AM   #159
mush
mush's Avatar
im just wondering if any of u with the milltek have a popping sound when shifting above 4000 rpm
mine is a auto and i hear it only in sport mode when shifting above 4000 rpm with my foot still on the pedal
i love the sound but im wondering what causes it
milltek catback non resonated
Old 10-21-2013, 11:37 AM   #160
ToyoburuBRZ
ToyoburuBRZ's Avatar
Drives: Black BRZ
It is more than likely some form of shift cut that allows you to do full throttle shifting. It just takes some of the force off of the transmission and allows the gears to shift.
The most common type of shift cut is an ignition cut where the ECU removes some ignition timing to cut engine power. A lot of times fuel doesn't get cut so good amount of raw fuel will pass through into the exhaust.
The pop is probably the raw fuel burning in the exhaust system. It doesn't damage the exhaust at all but like you said the sound is fantastic.
Hope that helps!
ToyoburuBRZ is offline   Reply With Quote
The Following User Says Thank You to ToyoburuBRZ For This Useful Post:
mush (10-21-2013)
Old 11-02-2013, 12:38 PM   #161
ToyoburuBRZ
Drives: Black BRZ
Looking for some opinions here. I really love the sound of this exhaust but I've been told that it will be too loud for a DD and I would experience a lot of droning on the highway. However, when listening to the sound clips, it sounds like the resonated system doesn't sound much louder than stock and the non-resonated sounds exactly like what I want.
Its really hard to tell through the sound clips online but I want an exhaust that is definitely louder than stock but with no drone at all. So is the resonated system what I want or the non-resonated?
Old 11-02-2013, 01:06 PM   #162
Trettiosjuan
Drives: GT86
I have the 2nd catback resonated, EU approved version which is almost a quarantee it would not be obnoxious or droning. Good. But at the same time apprehensive like you that I wouldn't hear the difference inside, kinda the point of this exercise.
The fist week I had it it was surprised at its heavy bassy voice and how loud and droning it was on full throttle even in low revs. I truly wondered how this got approved, but after a few days driving it started becoming quieter. Now a few weeks later, I can always hear the nice low rumble of the exhaust above the noises of the engine/intake at low revs without being loud, perfect for DD and much nicer than stock where basically the exhaust was not heard and the slightly thrashy engine was heard predominantly. At middle revs and full throttle it snarls nicely, and at high revs now the exhaust and intake/soundtube complement eachother nicely in concert.
Basically what a sportscar should sound like from factory.
PS: cold start is still pretty loud, a car standing next to me in an underground garage had its alarm go off when I started up mine...
The Following 2 Users Say Thank You to Trettiosjuan For This Useful Post:
BRZgirl (12-07-2013), ToyoburuBRZ (11-03-2013)
Old 11-02-2013, 01:11 PM   #163
atledreier
Drives: GT86 DGM
No drone at all with the secondary unresonated. Sounds like sex on wheels at cold start then quiets down a bit after a few minutes. Nice rasp at load.
atledreier is offline   Reply With Quote
The Following 2 Users Say Thank You to atledreier For This Useful Post:
Old 11-03-2013, 09:12 PM   #164
fooyc
fooyc's Avatar
Drives: GT86-JDM
ya. w/ cat back resonated @ the cold start do keep trigger my STI alarm. when rpm below 3k it do hv some droning. Car now feel easy to rev up over the mid range. Even now w/ KNN drop in can hear the intake sound too.
Hope by remap the ecu can gain more respond.
Old 11-04-2013, 06:49 PM   #165
Ganthrithor
Ganthrithor's Avatar
Drives: '13 BRZ, '06 997, Other Things(TM)
I've got the resonated catback. It's not much louder than stock at all IMHO, but has a little bit deeper, bass-ier, more rumbly sound to it. The system is a little louder than stock, but the increase in volume seems to be greater inside the cabin than it is at the tailpipe, which I actually like for a DD since I can drive it around at night without feeling like a total asshole.
I'd grab some sound clips of mine if I had any kind of decent mic setup to work with. I don't think cellphone video will give you a good idea of what it sounds like.
Mann's video comparing the stock vs Milltek resonated system is pretty accurate:
[ame="http://www.youtube.com/watch?v=yg80fpI_fFE"]Milltek Sport Resonated Catback System for 2013 Subaru BRZ and Scion FR-S - YouTube[/ame]
The resonated system (really, both systems, since the guys at Mann said the non-resonated one is only a couple of db louder than the resonated) really isn't much louder than stock, but the sounds it makes are nicer. Insert, "this is how it should have come from the factory" cliche here-- you're not going to install this system and find out that your car suddenly sounds like a straight-piped STI. It's really pretty reserved. I really didn't want an overly-loud exhaust since my BRZ is my DD and I don't like to feel like an asshole driving around at night etc, but even I sometimes wonder if I should have gotten the non-resonated version. The resonated is pretty subtle: it sounds better than stock, not louder.
Ganthrithor is offline   Reply With Quote
The Following 2 Users Say Thank You to Ganthrithor For This Useful Post:
BRZgirl (12-07-2013), ToyoburuBRZ (11-04-2013)
Old 11-05-2013, 04:27 AM   #166
chiefshayan
chiefshayan's Avatar
Drives: 2013 AT Firestorm FRS
I have the secondary catback from Milltek (non-res) with the Motive concept test pipe (no cat and no resonator) and I tend to set off car alarms when I'm in a garage. Drone is present above 4k but I wouldn't have it any other way. I'm in love with this exhaust, don't know anyone who has complained.
chiefshayan is offline   Reply With Quote
Old 11-16-2013, 05:32 AM   #167
shaunsweeney
shaunsweeney's Avatar
Drives: 2014 FR-S MT Asphalt Grey
Great thread. Just picked up my FR-S. This will definitely be the exhaust I go with in the summer.
shaunsweeney is offline   Reply With Quote
Old 12-16-2013, 06:22 AM   #168
pepe
Drives: gt86
Hey guys, you have had the opportunity to join two people who each have a form of escape and compare live? resonator with an escape and one without?
I continue to doubt resonated or non resonated ....
pepe is offline   Reply With Quote
Exhaust System/Exhaust Manifold Removal and Replacement GrimmSpeed DIY (Do-It-Yourself) Guides 52 11-11-2015 10:30 PM
Dynosty Presents MXP Exhaust System for FR-S/BRZ Dustin@Dynosty Engine, Exhaust, Bolt-Ons 12 11-08-2012 10:15 AM
Subaru BRZ Arrives At Milltek Sport HQ For Development vividracing Engine, Exhaust, Transmission 13 08-13-2012 09:53 PM
What is the best exhaust system for the FT86 LOTUS86 Engine, Exhaust, Transmission 4 07-31-2012 03:36 AM
TRD Exhaust System... Griffdawg Engine, Exhaust, Transmission 2 07-18-2012 01:27 AM
