Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 11-08-2021, 12:39 AM   #155
MyHybridBurnsGasAndTires
Drives: what
Originally Posted by nikitopo View Post
So is the fender gap still there? I was reading people here saying that new car's suspension is lower, because cog was lower too ...
cog is lower but it's millimeters lower.
there is not a significant difference caused by the springs in the overall cog
MyHybridBurnsGasAndTires is offline   Reply With Quote
Old 11-08-2021, 02:07 AM   #156
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
Yep.
Its 1.5mm lower for the GR86, 4mm lower for the BRZ.
Blighty is offline   Reply With Quote
Old 11-08-2021, 08:06 AM   #157
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Too bad they didn't fix the fender gap. Main issue is not the suspension, but the diameter of the wheels which are quite small. Other manufacturers are offering much larger wheels with the expense of a longer gear ratio, but if factory kept the previous 4.3 final drive ratio it wouldn't be noticeable at all. With a larger wheel the suspension would have to be redesigned a bit to keep the vehicle height same, BUT overall it would be better than to have this ugly gap and use again old coilover solutions with the lose of suspension travel.
Old 11-08-2021, 08:31 AM   #158
Too bad they didn't fix the fender gap. Main issue is not the suspension, but the diameter of the wheels which are quite small. .
Well, the real issue is they made the wheel well to fit larger wheels/tires because they knew folks would change them out.
Frankly I don't find a drop much of a solution because all it does is close the gap at the top. I'd rather have the symmetrical gap than no gap at the top and a wide one at the bottom.
If If were going to "fix" it, I would go with larger (more sidewall) tires rather than larger wheels. Since mine is primarily a road car, I would hope it would help soften the ride a bit, plus I HATE low profile tires.
Dadhawk is online now   Reply With Quote
The Following 6 Users Say Thank You to Dadhawk For This Useful Post:
Blighty (11-08-2021), Dzmitry (11-09-2021), nikitopo (11-08-2021), Pete (11-08-2021), SpectreRT (11-08-2021), Stonehorsw (11-08-2021)
Old 11-08-2021, 12:10 PM   #159
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
You do realize that by using a larger outer diameter tire to shrink the fender gap you also lose suspension bump travel? While making the ground clearance higher.
timurrrr is offline   Reply With Quote
Old 11-08-2021, 12:32 PM   #160
alphasaur
friendly
Drives: 17' 86
How are you losing bump travel with a larger diameter tire? Trying to wrap my head around this
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 11-08-2021, 12:39 PM   #161
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
As you compress the suspension with an increasing force, either it eventually hits and squishes a bump stop, or the tire hits the fender liner, or metal.
The geometry of a properly designed suspension should make it impossible to hit the fender liner or metal. But that also means that the larger the tire, less suspension travel should be allowed.
The Following 2 Users Say Thank You to timurrrr For This Useful Post:
alphasaur (11-08-2021), Jucostud (11-09-2021)
Old 11-08-2021, 12:54 PM   #162
alphasaur
friendly
Drives: 17' 86
Oh yes, that makes sense. I thought you were referring to it affecting bump stop travel. Thank you for your clarification.
Old 11-08-2021, 11:32 PM   #163
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
It is not necessary that you lose bump travel if you go with a bigger tire. It could work with a bigger inner liner well clearance, but I saw now that rear wheel clearance in new one is even worse.
Old 11-08-2021, 11:35 PM   #164
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Yeah, more inner clearance would be very much appreciated for many reasons, but given it's a small car with a McPherson strut front, and the rear tires are close to the rear seats, I can imagine there are non-trivial packaging issues.
Even then, 1st gen cars fit 245/40R17 tires much more easily than ND Miatas, for example.
Old 11-20-2021, 07:53 AM   #165
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Originally Posted by azndavepgh View Post
I'm curious if the fitment of the floor and trunk mats is the same as the first gen so we don't have to wait for new parts from WeatherTech, 3D, Lloyd, etc.
The weathertech floor liners fit the same in the new car.
dragoontwo is online now   Reply With Quote
The Following 5 Users Say Thank You to dragoontwo For This Useful Post:
azndavepgh (11-20-2021), bcj (11-20-2021), Falken86 (11-30-2021), Rossman (11-30-2021), Simmons (11-20-2021)
Old 11-29-2021, 08:26 PM   #166
azndavepgh
Drives: 2022 BRZ
Has anyone tried a cargo tray from the first gen?
azndavepgh is offline   Reply With Quote
Old 11-30-2021, 02:49 PM   #167
alphasaur
friendly
Drives: 17' 86
Anyone drive a mildly boosted (~250-270whp) gen 1 and care to compare to how it feels vs gen 2?
I have a 2017 86 and a turbo kit in my basement waiting to get installed, but really trying to decide if I should just trade in and get the brz.
Old 11-30-2021, 09:42 PM   #168
FritoPendejo
Drives: FRS
Trade in and boost the new BRZ with the kit you already have.
FritoPendejo is offline   Reply With Quote
