Old 10-17-2019, 03:44 AM   #155
Zer0
Drives: 2015 frs
Originally Posted by ka-titties View Post
See previous comment
Everything is just about complete. I just need to make 4 spacers to go in between the inner and outer plates on the transmission mount. I also need to make the rack and pinion mounts for my crossmember as well as sway bar mounts. Hopefully by the end of next week its getting powder coated, so I can start plumbing and wiring.
Zer0 is offline   Reply With Quote
The Following User Says Thank You to Zer0 For This Useful Post:
new2subaru (10-17-2019)
Old 10-29-2019, 08:07 PM   #156
Zer0
Drives: 2015 frs
I had a little set back. I totaled my daily driver. I did manage to start getting the rack mount tacked into place today. The old steering ujoint is in a picture but will be getting removed, and the shaft will be lengthened to meet the new u joint.
Old 10-30-2019, 12:16 PM   #157
ka-titties
Drives: 2013 BRZ Limited 6MT
RIP DD
ka-titties is offline   Reply With Quote
The Following User Says Thank You to ka-titties For This Useful Post:
Zer0 (10-31-2019)
Old 10-31-2019, 01:06 AM   #158
Zer0
Drives: 2015 frs
RIP DD
Now I'm F#$*^! With her hood rat sister.
Old 11-02-2019, 05:50 AM   #159
Zer0
Drives: 2015 frs
Starting to make the parts for my steering shaft to connect my custom rack to my column. Modifying the original collapsible section. I cut off the oem lower steering u-joint that connected to the rack to place a machined adapter I made that slides in the oem shaft, and reduces the inner diameter to go to 3/4" steering shaft that will attach to the new lower steering u-joint that connects to the rack. The new rack I installed forward of the oem rack location which necessitates lengthening the steering shaft. The new steering rack has a different size shaft, and spline count which required switching to a new lower steering u-joint as well. Otherwise I could have just lengthened the shaft.
Old 11-04-2019, 09:52 PM   #160
Zer0
Drives: 2015 frs
I abandoned the idea of keeping the collapsible section of the steering shaft. It would have required more clearancing of the hole from the passenger compartment to the engine compartment due to the much larger outer diameter. I just used the adapter I made to attach a 3/4" shaft to a ujoint at the bottom of the electric power assist steering motor, and attached the other end of the 3/4" shaft to the u-joint on the steering rack. I did clearance the hole slightly and it will need a little more as it is in place but rubs a bit. The u- joints are pressed on for now after the hole is clearanced I will do a final test fit, and weld everything up. I may build a more compact collapsible section when I pull the car apart for paint before final assembly.
Old 11-22-2019, 11:11 AM   #161
all4spl
Can you go into a little more detail on the heater core and ac line relocation? thanks!
all4spl is offline   Reply With Quote
Old 11-23-2019, 11:16 AM   #162
Zer0
Drives: 2015 frs
I haven't got much more done other than welding in blanks over the old openings to smoth the firewall. I also purchased a bulkhead to run the lines from the engine compartment into the passenger compartment. The bulkhead is placed under the cowel cover by the windshield wiper assembly. I plan on running the lines under the fender to keep them out of the way and hidden. The bulkhead is a unit that they would use on a old hot rod to run the heater, and ac lines. The bulkhead is a vintage air part or jegs part I can't remember. They sell the hose ends that screw onto the bulkhead to make your own lines, or you could have lines made with the correct ends on them.
Old 12-02-2019, 07:11 PM   #163
Zer0
Drives: 2015 frs
I finished test fitting the pedal assembly, steering shaft, and steering rack. Welded the steering u joint's and shaft together today. I submerged the ujoint in water to keep it cool while welding. I need to complete the welding on the steering rack mounts. After the rack mounts are completed I will begin putting all engine together to get it ready to run all the plumbing, and electrical.
Code Monkey (12-02-2019)
Old 12-03-2019, 11:05 AM   #164
ka-titties
Solid progress
Zer0 (12-03-2019)
Old 12-09-2019, 04:39 PM   #165
Zer0
Drives: 2015 frs
I installed the steering shaft it fits well. I was going to start assembling the accessory drive assembly, and supercharger. While under the car I noticed the oil pan sealant is a bit excessive. So change of plans. I'm going to pull the sub frame final weld the rack and pinion mounts. While the subframe is out I'm going to pull the oil pan and timing cover to seal it up a bit cleaner. I don't want random RTV sealant pieces floating around in my engine down the road.
Old 02-21-2020, 10:31 AM   #166
all4spl
any updates and pictures on this?
Old 02-24-2020, 06:47 AM   #167
Zer0
Drives: 2015 frs
No working 6 days a week 10hrs a day with a 3hr commute. Not much time to do anything besides work.
Old 02-24-2020, 02:02 PM   #168
Zer0
Drives: 2015 frs
Thanks. Your build seems to be going well. I like that your using the oem ecu. Cant wait to see the progress.
Andy0323's Back To Basics Build Thread <Long Term Project> andy0323 Member's Car Journals 15 02-02-2018 01:16 AM
long term and short term brichard0625 Engine, Exhaust, Transmission 7 08-26-2013 09:56 AM
Long term Bt216 Scion FR-S / Toyota 86 GT86 General Forum 3 06-07-2013 12:58 AM
Fuel Trims - Long term and short term victorb Engine, Exhaust, Transmission 6 03-27-2013 03:18 PM
Short Term and Long Term Fuel Trims naikaidriver Engine, Exhaust, Transmission 3 03-18-2013 10:55 PM
