03-09-2019, 09:16 AM | #155 |
Drives: BRZ DGM Limited
The Following User Says Thank You to BRZnut For This Useful Post: | Ultramaroon (03-09-2019) |
03-09-2019, 11:50 AM | #156 |
Drives: 2013 BRZ 6MT
Exactly. I just wish I had a choice; in CA you have to take it in. Mine is daily driven and tracked and thus far I have had zero problems/issues. At this point I think I’m going to go the route of being a registration scofflaw rather than rolling the dice with the recall. Sent from my iPhone using Tapatalk |
The Following User Says Thank You to PWBRZ For This Useful Post: | why? (03-09-2019) |
03-09-2019, 01:33 PM | #157 | |
Only happy when it rains.
Drives: series.blue
The Following User Says Thank You to why? For This Useful Post: | ermax (03-09-2019) |
03-09-2019, 02:37 PM | #158 | |
03-09-2019, 04:54 PM | #159 |
Drives: '13 WRB BRZ
Car ran fine before I took it in. They replaced the valve springs while I had my clutch replaced. Less than 500 miles later I was sitting on the side of the freeway with a bent rod. The paint on the new valve springs came off, clogged and choked my engine resulting in a bent rod.
Bad news: Recall broke my engine. Good news: New short block thanks to Subaru and currently enjoying the 2019 Forester loaner while my car is in the shop. |
03-09-2019, 05:10 PM | #160 |
Benz Tech
Drives: 2017 BRZ Premium
The paint mark on the spring bent a rod? Ha.
The Following User Says Thank You to maslin For This Useful Post: | gravitylover (03-09-2019) |
03-09-2019, 05:12 PM | #161 | |
Drives: Crapcan
The Following User Says Thank You to NoHaveMSG For This Useful Post: | maslin (03-09-2019) |
03-09-2019, 06:48 PM | #162 |
Results of the Valve Spring Recall Work
Yeah that is an interesting theory. I guess if all the paint (it isn’t just a mark but covers the entire top of the spring) from all 16 springs wound up in the pickup it wouldn’t be a good thing. Obviously paint chips will not bend a rod but oil starvation would spin a bearing but not sure a spun bearing would lead to a bent rod. Probably something lost in translation from the tech to the service manage and then to the customer. |
03-09-2019, 07:21 PM | #163 | |
Benz Tech
The Following User Says Thank You to maslin For This Useful Post: | ermax (03-09-2019) |
03-09-2019, 07:34 PM | #164 |
03-09-2019, 07:37 PM | #165 | |
Drives: 2013 brz limited / galaxy blue
Sounds like yours is one of the rare Subaru BRZ this has happened to . At least Subaru covered all the block and admitted to it . How is the forester ? My girl likes the sport model Sent from my iPhone using Tapatalk |
03-10-2019, 12:36 AM | #166 | |
As far as I can tell, you won’t be able to get it registered: https://techinfo.toyota.com/techInfo...p/j02tofaq.pdf Can’t see any way around this... yet. I wonder if an out of state car coming into CA would need to show proof of recall work completed? Sent from my iPhone using Tapatalk |
03-10-2019, 03:01 AM | #167 | |
That sounds like a problem for 2021 me, looks like it doesn't prevent registration until the car goes in for smog which doesn't happen for 8 years after a new car gets purchased and I just paid my registration for 2019. I believe there was a section in my letter indicating that you can have the repair performed by an independent mechanic and file for reimbursement (Q8 in the FAQ you linked) which should get the VIN on the list of vehicles that have been repaired. My current thought is having The Racers Line do the work (I also need a throwout bearing replaced, the leaky timing chain cover resealed, and an overall engine health check), but I haven't called him up about it yet. I'd rather pay out of pocket to have the engine built by someone I trust, I'd DIY but as I'm not ASE certified I have a hunch that'd be a big fat waste of time. |
The Following User Says Thank You to strat61caster For This Useful Post: | Teseo (03-10-2019) |
03-10-2019, 04:24 AM | #168 | |
humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | ORrooster (03-16-2019) |
Similar Threads | ||||
Valve spring recall - where did you get it done? satisfied with the work? | fiveoneoh | Northern California | 105 | 09-25-2020 02:10 PM |
Possible recall on the 86 regarding valve spring | tanner | CANADA | 84 | 11-28-2019 09:32 PM |
valve spring recall/ additional work performed when engine is out | swfrs | Issues | Warranty | Recalls / TSB | 172 | 07-31-2019 12:10 AM |
Valve spring recall | meadowz06 | Issues | Warranty | Recalls / TSB | 115 | 06-08-2019 11:38 PM |
Valve Spring Recall | venturaII | New England | 13 | 02-25-2019 07:41 PM |
