Old 03-09-2019, 09:16 AM   #155
BRZnut
Drives: BRZ DGM Limited
I have been expressing my professional opposition to this idiotic recall since I first heard about it. All the springs that were going to fail have already done so long ago.
I have felt the same way when I first heard about it!
The Following User Says Thank You to BRZnut For This Useful Post:
Ultramaroon (03-09-2019)
Old 03-09-2019, 11:50 AM   #156
PWBRZ
PWBRZ's Avatar
Drives: 2013 BRZ 6MT
Exactly. I just wish I had a choice; in CA you have to take it in. Mine is daily driven and tracked and thus far I have had zero problems/issues. At this point I think I’m going to go the route of being a registration scofflaw rather than rolling the dice with the recall.
PWBRZ is offline   Reply With Quote
The Following User Says Thank You to PWBRZ For This Useful Post:
why? (03-09-2019)
Old 03-09-2019, 01:33 PM   #157
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
great reason to leave that state.
why? is offline   Reply With Quote
The Following User Says Thank You to why? For This Useful Post:
ermax (03-09-2019)
Old 03-09-2019, 02:37 PM   #158
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
What do they do if you don't take it in? I didn't read the letter that close and at this point have zero intention of taking it in.
ineedyourdiddly
Old 03-09-2019, 04:54 PM   #159
soldi3r
Drives: '13 WRB BRZ
Car ran fine before I took it in. They replaced the valve springs while I had my clutch replaced. Less than 500 miles later I was sitting on the side of the freeway with a bent rod. The paint on the new valve springs came off, clogged and choked my engine resulting in a bent rod.
Bad news: Recall broke my engine.
Good news: New short block thanks to Subaru and currently enjoying the 2019 Forester loaner while my car is in the shop.
soldi3r is offline   Reply With Quote
Old 03-09-2019, 05:10 PM   #160
maslin
Benz Tech
Drives: 2017 BRZ Premium
The paint mark on the spring bent a rod? Ha.
maslin is offline   Reply With Quote
The Following User Says Thank You to maslin For This Useful Post:
gravitylover (03-09-2019)
Old 03-09-2019, 05:12 PM   #161
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
They are lying to you about the failure, but you are getting it fixed no cost so
maslin (03-09-2019)
Old 03-09-2019, 06:48 PM   #162
ermax
ermax's Avatar
Results of the Valve Spring Recall Work
Yeah that is an interesting theory. I guess if all the paint (it isn’t just a mark but covers the entire top of the spring) from all 16 springs wound up in the pickup it wouldn’t be a good thing. Obviously paint chips will not bend a rod but oil starvation would spin a bearing but not sure a spun bearing would lead to a bent rod. Probably something lost in translation from the tech to the service manage and then to the customer.
Old 03-09-2019, 07:21 PM   #163
maslin
Benz Tech
The paint on the spring made the retainer sit crooked which blew out the locks, valve dropped and bent a rod. Wasn’t the techs fault. It was that darn paint.
ermax (03-09-2019)
Old 03-09-2019, 07:34 PM   #164
ermax
ermax's Avatar
Okay okay. I buy that. Hahahaha
Old 03-09-2019, 07:37 PM   #165
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
Sounds like yours is one of the rare Subaru BRZ this has happened to . At least Subaru covered all the block and admitted to it . How is the forester ? My girl likes the sport model
mswbrz is offline   Reply With Quote
Old 03-10-2019, 12:36 AM   #166
PWBRZ
PWBRZ's Avatar
As far as I can tell, you won’t be able to get it registered: https://techinfo.toyota.com/techInfo...p/j02tofaq.pdf
Can’t see any way around this... yet. I wonder if an out of state car coming into CA would need to show proof of recall work completed?
Old 03-10-2019, 03:01 AM   #167
strat61caster
Thanks!
That sounds like a problem for 2021 me, looks like it doesn't prevent registration until the car goes in for smog which doesn't happen for 8 years after a new car gets purchased and I just paid my registration for 2019.
I believe there was a section in my letter indicating that you can have the repair performed by an independent mechanic and file for reimbursement (Q8 in the FAQ you linked) which should get the VIN on the list of vehicles that have been repaired.
My current thought is having The Racers Line do the work (I also need a throwout bearing replaced, the leaky timing chain cover resealed, and an overall engine health check), but I haven't called him up about it yet.
I'd rather pay out of pocket to have the engine built by someone I trust, I'd DIY but as I'm not ASE certified I have a hunch that'd be a big fat waste of time.
ineedyourdiddly
Teseo (03-10-2019)
Old 03-10-2019, 04:24 AM   #168
Why would you do that when you can have the recall work done, plus all that other stuff, for the cost of a TOB, down at your local Bay area Toyota dealership, by a highly trained, highly certified, highly experienced mechanic with a PhD in FA20 engineering and maintenance - ??
ORrooster (03-16-2019)
Valve spring recall - where did you get it done? satisfied with the work? fiveoneoh Northern California 103 09-25-2020 02:10 PM
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 09:32 PM
valve spring recall/ additional work performed when engine is out swfrs Issues | Warranty | Recalls / TSB 172 07-31-2019 12:10 AM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-08-2019 11:38 PM
Valve Spring Recall venturaII New England 13 02-25-2019 07:41 PM
