AVOturboworld
Old 11-27-2012, 02:25 PM   #1611
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
Originally Posted by 2forme View Post
Oh, i thought you said it was the stage 1 kit...
My apologies, the original text was confusing, I see that when I go back and re-read it.
What I meant to say in it (and I'll go back and edit it), is that we are working on the stage 2 kits. Stage 2 kits will be Stage 1 kit, plus the AVO crossover pipe and catted front pipe. Stage 2 (at this time) will still be on stock fueling.
So basically, once you lift the restriction in the exhaust (the standard piping/cat), this is where we are getting with the power on stock fueling.
AVOturboworld is offline   Reply With Quote
The Following User Says Thank You to AVOturboworld For This Useful Post:
MSTiFK8R (11-27-2012)
Old 11-27-2012, 02:32 PM   #1612
2forme
Oh, so my next question is for those with header back exhausts already (I have an SRT headerback), can they get the 6-6.5 psi wastegate "stage 2" spring'ed kit and tune for the stage 1 price (since the exhaust components wouldn't be necessary)?
:-D
The Following User Says Thank You to 2forme For This Useful Post:
sf86 (11-27-2012)
Old 11-27-2012, 02:48 PM   #1613
sf86
sf86's Avatar
Drives: Red Scion FRS AT
:-D
You are asking too many question dude.. but i like since this kit is going to be mine once its available
sf86 is offline   Reply With Quote
Old 11-27-2012, 02:52 PM   #1614
2forme
Well I know there are plenty of people looking at this kit who will go "Oh, I have a full exhaust already... So if that's the only difference between the kits, why can't I just buy the stage 1 kit with the stage 2 spring/tune?"
I agree though, if it makes 240ft lbs from 3k to redline and quiets down the obnoxious cold start, I will probably grab this kit a couple weeks before I pull the car out from winter storage.
The Following 2 Users Say Thank You to 2forme For This Useful Post:
civicdrivr (11-27-2012), ngabdala (11-27-2012)
Old 11-27-2012, 03:06 PM   #1615
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
:-D
I have your same questions and would be willing to pay more just for the Stage 2 tune/wastegate setting, since I already have exhaust too.
Old 11-27-2012, 03:22 PM   #1616
2forme
Edit this and take that bolded part out in hopes it might save us all money!!!
Old 11-27-2012, 03:24 PM   #1617
Sportsguy83
Drives: Limited BRZ
LMAO! I pay for good service. The Stg 2 tune will require Dyno time, so I am willing to pay for it :happy0180: We are already at 4K+ including ECUTek license... what is 200-300 more??
Old 11-27-2012, 03:25 PM   #1618
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
I recall 5psi was the limit of stock MAP sensor, is it in place yet?
MSTiFK8R is offline   Reply With Quote
Old 11-27-2012, 04:23 PM   #1619
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
:-D
If you use a boost controller, you can go up to double the wastegate spring pressure, without changing the actual wastegate spring.
IMO this is the better way to do it because you than have the option to run say 5psi low boost setting, than raise it either manually or electronically to "stage 2" type levels when you want the extra power.
That is what we are going to do.
No Limit Motorsport is offline   Reply With Quote
Old 11-27-2012, 04:28 PM   #1620
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Can you setup the car to run say a dd 5 psi tune, then have the ability to swap to a lets say 15psi race tune on the fly and make more power when you want?
Tansey86 is offline   Reply With Quote
Old 11-27-2012, 04:32 PM   #1621
No Limit Motorsport
Probably not, usually double the spring pressure is the limit. Could do a 5psi, than 10psi for sure at the push of a button or the adjustment of a knob. If the car is tuned for 10psi, running less PSI is never an issue. So you just leave the 10psi ECU flash in there, than set the controller for 5psi low setting, 10psi high setting.
Old 11-27-2012, 04:34 PM   #1622
2forme
If the tune is calibrated correctly, it should run 5 and 6.5psi with little trouble....not needing to flash a different tune.
I've run full standalones on turboed cars and never had to retune when turning the boost up or down. It's usually compensation, not a map. You have a base fuel trim map, and then adjust compensation for positive pressure.
Old 11-27-2012, 04:35 PM   #1623
Tansey86
Tansey86's Avatar
So 10 and 20 it is :P
The Following User Says Thank You to Tansey86 For This Useful Post:
No Limit Motorsport (11-27-2012)
Old 11-27-2012, 05:08 PM   #1624
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Will the stage 2 kit suit any garden variety cat back type aftermarket exhaust or would it benefit more from a specific type of exhaust system of a specific diameter (2.75 inches or 3 inches)?
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
The Following 2 Users Say Thank You to ultra For This Useful Post:
Jive Turkey (11-27-2012), Mr.Jay (11-27-2012)
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
