09-29-2017, 10:23 PM | #16130 | |
Just the tip
Drives: 2017 DGM BRZ
Blackout looks way better in this car. What kind of prep/paint did you use for this? |
09-30-2017, 01:27 PM | #16131 |
Raised my Greddy Supreme SP exhaust as well as my diffuser, only needed 5mm spacers out of the possible 25mm!
09-30-2017, 04:03 PM | #16132 |
Drives: 2017 Subaru BRZ WRB PP
The trim on the knee pads are the jdm black Toyota parts from FT86speedfactory. As far as prep goes I lightly sanded with scotchbright fine pad cleaned with alcohol and painted with krylon covermaxx flat black spray can. I work at Sherwin Williams so I was able to test a few different sheens and paints till I got the perfect match.
The Following User Says Thank You to derekbrz24 For This Useful Post: | wolffbite (09-30-2017) |
09-30-2017, 06:54 PM | #16133 |
Drives: '14 981CS, '99 NB1
10-01-2017, 06:44 PM | #16134 |
Just the tip
Installed a K&N intake filter and GCS smoked 4th brake light... goes really well with the 2017 tails.
The Following User Says Thank You to wolffbite For This Useful Post: | kai_gt86 (10-07-2017) |
10-01-2017, 08:00 PM | #16135 | |
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
Did you have to tap any wires for the brake light?
10-02-2017, 12:31 AM | #16136 |
Drives: 13 WRB BRZ
I just put in weathertech floor mats in mine. Looking at tints next.
10-02-2017, 10:42 AM | #16137 |
Just the tip
The factory harness is only set up for the reverse lights, so yes you have to tap a connection to your running lights for the V, and brake lights for the triangle brake light. It was pretty easy, and the kit includes some scotch locks if you aren't comfortable tapping in with soldered connections like I did.
The instructions I found online were for pre-2017 tails, but the wiring was identical for me. |
10-03-2017, 05:10 PM | #16138 |
Drives: Neptune GR86
Now I need some black buttons... and finishing wrapping the rest of the silver...
Deciding if it would be too much glossiness if I wrap the cluster surround as well 🤔
10-07-2017, 04:25 PM | #16139 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
Glossy black Subaru and BRZ emblems
The Following User Says Thank You to B-R-Z For This Useful Post: | MJones_RB (10-17-2017) |
10-07-2017, 07:04 PM | #16140 |
Applied her lipstick
@dsomegax.cars
2013 Subaru BRZ Limited | WRB | STI tS Build Thread [SOLD] 2019 BMW M2 Competition | LBB | ///M Performance Build Thread 2020 Toyota GR Supra | Turbulence | TRD | Build Thread |
The Following 5 Users Say Thank You to DSOmegaX For This Useful Post: | carsebuco (10-09-2017), justinco (10-11-2017), MagicMexican (10-13-2017), tintumz22 (10-10-2017), wolffbite (10-09-2017) |
10-09-2017, 01:46 PM | #16141 |
Drives: car
Belated update, changed fluids in manual transmission and differential at 86k miles, Motul Gear 300 in both. They were last changed about 30k miles ago at 55k miles. After about 30k miles on the fluid the gearbox wasn't performing like it should, 1st gear felt dry and 2nd gear would grind when I pulled it out of gear.
Changing the fluid has made shifting much better. May consider changing MT fluid every 25k miles rather than extending it to every 30k miles instead because of this. |
10-09-2017, 02:33 PM | #16142 |
Drives: 2017 Series Yellow BRZ
Similar Threads | ||||
Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
Got my new FR-S today. | Boosted2.0 | Scion FR-S / Toyota 86 GT86 General Forum | 51 | 06-03-2012 10:35 PM |
Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 10:19 PM |
sat in a BRZ today | NESW20 | BRZ First-Gen (2012+) -- General Topics | 8 | 03-31-2012 08:53 AM |
