Old 09-30-2017, 06:54 PM   #16129
johan
Drives: '14 981CS, '99 NB1
Originally Posted by Drambeenie View Post
UGHHH I need to do this!
As do I! I've been procrastinating for almost a year now. Hard to believe I've had my '17 that long.
johan is offline   Reply With Quote
Old 10-01-2017, 06:44 PM   #16130
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Installed a K&N intake filter and GCS smoked 4th brake light... goes really well with the 2017 tails.
wolffbite is offline   Reply With Quote
Old 10-01-2017, 08:00 PM   #16131
mjanmohammad
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
Did you have to tap any wires for the brake light?
mjanmohammad is offline   Reply With Quote
Old 10-02-2017, 12:31 AM   #16132
Kentoxik
Drives: 13 WRB BRZ
I just put in weathertech floor mats in mine. Looking at tints next.
Kentoxik is offline   Reply With Quote
Old 10-02-2017, 10:42 AM   #16133
wolffbite
Just the tip
wolffbite's Avatar
The factory harness is only set up for the reverse lights, so yes you have to tap a connection to your running lights for the V, and brake lights for the triangle brake light. It was pretty easy, and the kit includes some scotch locks if you aren't comfortable tapping in with soldered connections like I did.
The instructions I found online were for pre-2017 tails, but the wiring was identical for me.
Old 10-03-2017, 05:10 PM   #16134
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Now I need some black buttons... and finishing wrapping the rest of the silver...
Deciding if it would be too much glossiness if I wrap the cluster surround as well 🤔
Old 10-07-2017, 04:25 PM   #16135
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Glossy black Subaru and BRZ emblems
B-R-Z is offline   Reply With Quote
Old 10-07-2017, 07:04 PM   #16136
DSOmegaX
DSOmegaX's Avatar
Applied her lipstick
@dsomegax.cars
Old 10-09-2017, 01:46 PM   #16137
radroach
Drives: car
Belated update, changed fluids in manual transmission and differential at 86k miles, Motul Gear 300 in both. They were last changed about 30k miles ago at 55k miles. After about 30k miles on the fluid the gearbox wasn't performing like it should, 1st gear felt dry and 2nd gear would grind when I pulled it out of gear.
Changing the fluid has made shifting much better.
May consider changing MT fluid every 25k miles rather than extending it to every 30k miles instead because of this.
Old 10-09-2017, 02:33 PM   #16138
Azzudien
Drives: 2017 Series Yellow BRZ
Originally Posted by hiertytrig View Post
Sorry if this has been asked before but how many kms were on your new BRZ at dealers?
3
Azzudien is offline   Reply With Quote
Old 10-09-2017, 02:51 PM   #16139
Kabong
Drives: 1999 Accord v6; 2017 CWP BRZ Ltd
I didn't see a small metal rod on the freeway at night and got a door ding because of it. *cries*
And now, time to find a body shop....
Kabong is offline   Reply With Quote
Old 10-09-2017, 10:24 PM   #16140
spike021
spike021's Avatar
Bought a full @DiodeDynamics interior LED replacement kit about a month ago and finally got started around dusk doing my first swaps.
Got the license plate and trunk LEDs swapped in. Gonna have to do dome, vanities, and courtesies later.
I'm having a ton of trouble getting the dome light cover off, though :\
spike021 is offline   Reply With Quote
Old 10-09-2017, 10:31 PM   #16141
mjanmohammad
Passed some much more expensive cars.
[ame]https://www.youtube.com/watch?v=SZOpaOqTjsA&ebc=ANyPxKoHER3sA3S1AvW3vNKTJf GfawFmgNDXoZmMwLTo5DwH6fMPBULC3htCwTH3c5-oaniHyI_gj3ai9zFl8-ycvmchQGSziQ[/ame]
Old 10-09-2017, 10:31 PM   #16142
mjanmohammad
Instead of taking just the clear plastic part off, take the whole assembly off and change the bulb from the back. Makes it a million times easier.
