Old 05-07-2014, 08:08 PM   #1597
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
Well, while im in there tomorrow, I can take a voltage reading.
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
Deadspool is offline   Reply With Quote
Old 05-07-2014, 08:15 PM   #1598
Dipstik-sportech
Dipstik-sportech's Avatar
I'm running the 485 setup with 1000's. All is well so far and I have about 450mi since the tune on it now
The Frozen North
Old 05-07-2014, 08:17 PM   #1599
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Hes worried ill have a voltage drop at somepoint. I guess its common on gtr's
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 05-07-2014, 08:22 PM   #1600
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by pmccut View Post
1.) Absolutely, this is certainly what I stated. I wanted it to start up on the first attempt. No three-start approach like I was used to with E85. No giving it gas to keep it idling until it warms up, that gets real old real fast. You stated you hadn't been able to get larger injectors to start and idle perfectly, so there would be a sacrifice if I didn't switch back to stock injectors. You assured me we'd be able to hit my power goals easily on stock injectors, I was very weary of this but it was your assurance (and Mike's) that sold me on going back to stock injectors.
2.) At Mann Engineering, sometime around 4pm before you started on my car, we discussed what the power was on the smaller turbo setup, and you said 15psi would probably be more power than my goal (400/300), so there wouldn't be a need to use the EBCS (that is still installed). We talked about roughly what that whp/tq would be on the MAHA to ensure we didn't exceed the tq for the clutch.
I'm really just trying to figure out why it's so low. When you were done with the car we stood around discussing this for 10 minutes... You said the stock injectors weren't maxed, and suggested that the GTX3076R could be much less efficient than the GT2871R at 15psi, which doesn't seem to be true. Is this just because the stock injectors are maxed? Is the larger turbo really less efficient at 15psi?
In the end I spent a lot of time and money to lose power, add turbo lag, for better drivability. I don't understand why I can't have power and drivability
Check your PM's as there was a miss communication on our part. We would like to take care of your vehicle, so give us a call when you get a chance.
Regards,
William Knose
Old 05-07-2014, 08:30 PM   #1601
Deadspool
Much title. Wow.
Deadspool's Avatar
its entirely likely.
same issue with just about every dsm as well.
Old 05-07-2014, 08:47 PM   #1602
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Hardwiring will ensure no drop across the whole RPM range, but at those levels not necessary at all.
Old 05-08-2014, 09:39 AM   #1603
xwd
With the larger pumps it might be more of an issue but yeah what kind of IDCs are you really running? Not much downside to hardwiring other than having to run some wires and install a relay/fuses somewhere.
I've also been looking at the 485 instead of some of the other options since it just seems to be a better pump altogether even if it is a little large for a GTX2867R even on E85. Then again I'll also be using ID1000s which are overkill as well.
Old 05-08-2014, 10:55 AM   #1604
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Deadspool View Post
the slim fan hardware ate my radiator
JB Weld fix?
Old 05-08-2014, 10:57 AM   #1605
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
JB Weld fix?
Boil an egg
Sent from my IBrick
Old 05-08-2014, 11:54 AM   #1606
Dipstik-sportech
Pepper?
The Frozen North
Old 05-08-2014, 12:44 PM   #1607
Deadspool
Much title. Wow.
Deadspool's Avatar
And now. I'm cooking breakfast.
Old 05-08-2014, 02:56 PM   #1608
Deadspool
Much title. Wow.
Deadspool's Avatar
Well. On the green wire to the pump I'm reading 8.65v at idle. It must be regulated.
Old 05-08-2014, 03:57 PM   #1609
Reaper
Reaper's Avatar
Drives: violent
Hmmm...so there's some good to be had here. I dont neeed more flow but if i remember right higher voltage should lower the strain on the pump.it seems like Walbros dont like low voltage. That's a common discussion on gtr's and ive been reading about non hardwired failures on those cars.
Old 05-08-2014, 06:34 PM   #1610
Infamous Performance
Infamous Performance's Avatar
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
Originally Posted by jamesm View Post
I tuned a gtx2867r (similar to the 2871) and gtx3076r on the same (very heartbreaking mustang) dyno recently, at ~15psi oddly enough (actually a bit less, maybe closer to 14 psi). the 2867r made 357whp and the 3076r made something like 376 iirc. the 3076r, in my direct experience, makes more power at every boost level than the 2867, from 9-18psi and beyond. at least that's what i've seen... ymmv i suppose.
That is interesting because no FRS/BRZ running ACN 91 has ever come close to those numbers on my Mustang (at the same boost levels). With e-85, yes, but not ACN 91.
Food for thought... PM's IDC (port) is 88% on his current tune (that made 270whp on Manns dyno). 15psi, 88%idc, afr's proper. So, the air/fuel mixture is proper at 15psi and the injectors are no where near the "ragged edge". Larger injectors will do nothing at this point. The car does not need more fuel. It would appear that the car needs more compression and then it could use more fuel. There could be other contributing factors.
I for one want to see a trap speed (1/4 mile). Dynos are tools. Without a pre and post pull on the same dyno, numbers are almost meaningless. Too many variables. But... trap speed can be a very good indicator of power and has less variables.
Infamous Performance is offline   Reply With Quote
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
