Old 11-12-2015, 03:36 PM   #1583
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I Love all the Pictures, Specs, and Constructive conversation on how to make MEATY Tires fit! Thanks to all that have done so.
Old 11-12-2015, 04:20 PM   #1584
itsibarra
itsibarra's Avatar
Drives: Supercharged Car
Originally Posted by showoff3civic View Post
Ambit 18x9.5 +38
Dunlop Spec star II 265/35 18
front: -1.7
Rear: -1.5
St Coilovers
Front Fenders pulled 10MM
Any LCA's or top hats*? I have the same coils but rubbing on 225's in the front =/
itsibarra is offline   Reply With Quote
Old 11-12-2015, 06:59 PM   #1585
showoff3civic
Drives: 2015 BRZ
Originally Posted by Bamsterman View Post
Exact set up I want. Already have the wheels. Was it needed to pull the front fenders, or was it more of a precaution?
I would say yes - yes totally up to you how you want to run your camber.
I may end up going a little more aggressive (-2.0) but I drive alot and want to keep even tire wear.
Here is a before and after shot
showoff3civic is offline   Reply With Quote
Old 11-12-2015, 07:02 PM   #1586
showoff3civic
Drives: 2015 BRZ
Originally Posted by itsibarra View Post
Any LCA's or control arms? I have the same coils but rubbing on 225's in the front =/
not running either - nor camber bolts - I also didnt Slam my car, its about an 1.5 inch lower. I have enough room for a good finger/two between the tires/fenders
Old 11-12-2015, 07:09 PM   #1587
showoff3civic
Drives: 2015 BRZ
Originally Posted by sactownbwoy View Post
I see you are running Star Specs. So few people run them. I have them also, 255/40, and I love them. Your setup looks nice
I'm a huge Dunlop fan - Run Star Specs on my car
Had them on my STi:
And Dunlop Q3 on my bike
Old 11-13-2015, 03:05 AM   #1588
BPM
Drives: A Blue One
Anybody know how to get rid of the rubbing at the front with the steering wheel turned all the way? My tires are rubbing the inside of the wheel-well when my steering wheel locks all the way to one side. Im guessing spacers, but can someone verify with me the minimal size they went with and what brand used?
Suspension: Stance SS Coilovers
Tire Specs: 265/35/18 Michelin PSS
Wheels: 18x9.5 +38
Camber: -2.8 L&R
Height: 1 Finger gap clearance from fender, no fender mods
@Lust what did you end up doing to eliminate the issue?
BPM is offline   Reply With Quote
Old 11-13-2015, 09:21 AM   #1589
Bamsterman
Drives: 13' Scion FRS
That before and after picture speaks for itself. Thank you so much!
Bamsterman is offline   Reply With Quote
Old 11-15-2015, 07:18 PM   #1590
Metabrz
001 of 012
Metabrz's Avatar
Drives: MY12 NZDM Subaru BRZ "BRZ001"
Wheels: 18x9.5 +38
Camber: -2.8 L&R
Consider getting steering stops. @nzer had to - he runs 265/35.
BRZ001: Peace Love and Wheelies @metabrz on IG
Metabrz is offline   Reply With Quote
Old 11-15-2015, 07:32 PM   #1591
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Yep @BPM, I had the same issue. With my 18 x 9.5" +45 I avoided fender rub but at full lock left the inside of front left tyre was rubbing on the chassis rail.
I had minor steering stops put in that restrict the lock until just before rubbing. Don't even notice the minor change in turning circle.
I was going to put 5mm spacers in but went for steering stops instead to avoid any fender rubbing. Was the perfect solution for me.
5mm spacers for you would change you to +30 offset and that's quite a bit of poke. It'd be illegal here as you'd need to run too much camber to get the wheels withing the fender line. Not sure on the rules where you are.
nzer is offline   Reply With Quote
Old 11-16-2015, 11:34 PM   #1592
BPM
Drives: A Blue One
Any recommendations on steering stops used/fabricated? I will be looking into this option as well.
Thanks!
Old 11-16-2015, 11:36 PM   #1593
nzer
nzer's Avatar
Thanks!
Sorry, the race car place that put in my final drive change did it for me so not sure what they used @BPM.
Perhaps ask an alignment place.
Old 11-22-2015, 05:58 PM   #1594
serial gixxer
I will be swapping shoes but here she is as it sits at the moment. Enkei rs05rr 18x9.5+43 265/35/18 michelin PSS square.
serial gixxer is offline   Reply With Quote
Old 11-23-2015, 01:17 AM   #1595
Lust
Drives: 2017 Subaru BRZ
Wheels: 18x9.5 +38
Camber: -2.8 L&R
I think everyone who runs a similar setup said they rub on full lock. I however rub when I drive on curvy back roads still and rub on hard dips/bumps.
I am seriously considering going down in tire size to a 255/35 but we will see.
I also got another alignment. Now running -2 up front and -3 in the back. Going to go back yet again to lower it some more and get another alignment. Probably will end up running -2.5 in the front and -2 in the rear with a little bit of toe in.
Lust is offline   Reply With Quote
Old 12-02-2015, 02:45 PM   #1596
FR-Shred
FR-Shred's Avatar
Question guys.. Probably the best spot since you guys actually have the meaty tires I'm looking into..
Spec:
Lowering springs dropped just under 1"
Camber -1.5f -1r
I'm looking at 18x9.5 +38 wheels and want to probably go 265 tires.. Will that wheel and tire combo fit stock struts? Will it work with my camber too?
I'm probably going to end up getting coils before the wheels, cause winter, but just in case I was wondering if that'll work. I don't mind adding a tiny bit more camber, -.5 more front and back but that's about it. I had 18x9.5+40 with 255 on the rear (staggered set up) and it fit with no issues I wouldn't see the 265 interfering with anything back there mainly I'm thinking about the front.
Thanks
FR-Shred is offline   Reply With Quote
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
