Old 03-21-2014, 04:06 PM   #1569
Tromatic
It would also be interdasting if Vishnu could find a stock example of the car with the "noise" and get some audio and data of the normal induction sounds and a car with the pump problem.
Tromatic is offline   Reply With Quote
Old 03-21-2014, 09:42 PM   #1570
Blu-by-U
Some Dumb Guy
Blu-by-U's Avatar
Drives: wanting an Acabian
@shiv, I may not understand all of the quirks of tuning today (yet). Back in the day, I had a 3500 lbs. 68' Charger, 2bbl 318, 727AT getting 23 mpg hwy. I understand that my dwell meter and feeler gauge are not required anymore. However, I just want to say thanks for the effort that you and your team have put into giving the options back to people.
She said it was her or the car. Longest she had ever seen.
Blu-by-U is offline   Reply With Quote
Old 03-21-2014, 10:27 PM   #1571
s2d4
s2d4's Avatar
Originally Posted by shiv@vishnu View Post
The graphing of knock correction has been fixed. Just auto update your OFT through OF Manager
@steve99, can you confirm this is working for ya?
Looks the same to me after updating via OFM.
Old 03-21-2014, 11:16 PM   #1572
steve99
Just update oft and tested.
had not looked before but knock correction is graphed and you can select/deselect graph line by tapping screen. Initially was white on selection went red. Not much to see though as no knock correction idling in garage
Old 03-21-2014, 11:18 PM   #1573
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Now, when in the graphical display screen, the knock correction value of 0 will be at the top of the screen. When knock occurs the value will drop (- X deg).
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
steve99 (03-21-2014)
Old 03-21-2014, 11:21 PM   #1574
steve99
@s2d4
could you have a look here
http://www.ft86club.com/forums/showp...&postcount=423
what do you think about the flck at 5000-7000 ??
that was on 98, I think I'm going to run United 100 I'm sure it was not there on 100 RON
Old 03-21-2014, 11:45 PM   #1575
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
So if anyone was curious here is what shivs oft300 tune made on the dyno
Borla UEL, Perrin Headerback system, 93 octane shell, numbers corrected for weather conditions.
vs what shiv made
OFT+OFH+Votech SC (9psi)+Perrin CBE 93 octane
cjsporl1996 is offline   Reply With Quote
Old 03-22-2014, 01:19 AM   #1576
s2d4
s2d4's Avatar
@s2d4
Lol, thanks for not answering my question Haha
I still haven't tried P100 yet but you are most likely right that it wasn't there.
What 98 is it again? Shell? It isn't as good as BP from my experiences on the BNR32. Instead of pulling I think it would be best to run P100 due to the extra octane plus ethanol properties.
Old 03-22-2014, 01:37 AM   #1577
steve99
Yeah agree I don't want to knobble the tune any more , correct shell 98, I think you said caltex was sus as well.
BP 98 you reckon is better than shell 98 , I'll give it a go some time
I checked my old logs on united P100 and although I did not have tactrix then to monitor flck the kc learned has no dips in 5000-7000 range.
I was also adding 5-6 liters of E85 to a tank of 98 with good results so a 20l of E85 was good to suplement 4 tanks of 98 , the P100 station is a fair way away like the E85 one.
Old 03-22-2014, 01:41 AM   #1578
s2d4
s2d4's Avatar
Yeah, this was the general consensus on the skyline forum. EDIT:so it wasn't just me.
It may differ on location though so see how you go.
I am definitely thinking of E85, less than 15min away so not so bad....
Old 03-22-2014, 11:10 AM   #1579
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
vs what shiv made
Something doesn't loom right here. Your torque curve STARTS 500 RPM later. I don't mean you started at a higher RPM, I mean where you are on the curve at 3000 RPM is where Shiv was at running 2500RPM.
Edit: I just looked and you are making almost as much torque. Shiv made only 9-15ft/lbs more.
Luckrider is offline   Reply With Quote
Old 03-22-2014, 12:33 PM   #1580
Kodename47
Kodename47's Avatar
Drives: UK GT86
Looks just like dyno variances to me. I'd be happy with those results CJ.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-22-2014, 01:03 PM   #1581
s2d4
s2d4's Avatar
Ahh, somehow I missed this and @steve99's post maybe I need to use the latest template but maf voltage doesn't work on that one for me...
Old 03-22-2014, 01:36 PM   #1582
s2d4
s2d4's Avatar
@shiv@vishnu
I am on 125 firmware with the latest template file just downloaded from the website, unfortunately it is still just a red line at the bottom so any events won't be shown in real time graphical display, extremely weird..
EDIT:MAF voltage does work on the new template, does the tablet exhibit caching behaviour?
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 02:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 01:39 PM
