Old 11-18-2012, 04:47 PM   #1555
Tiz
Drives: Subaru BRZ
I believe you are setting the right priorities (although I am personally looking for a high-end solution /w a ball-bearing turbo and an electronic boost controller).
Tiz is offline   Reply With Quote
Old 11-18-2012, 05:53 PM   #1556
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
Builds like this are actually relatively easy for us to arrange for. It's just that it's technically custom, so it's not sitting on the shelf, and thus may take a bit longer to deliver. Plus tuning at the end will need to be customized to that level of hardware, as well as any supporting modifications.
AVOturboworld is offline   Reply With Quote
Old 11-18-2012, 06:55 PM   #1557
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
Wondering if you guys will eventually offer a "tuner" kit options in case people wish to go with a system like Hydra or anything?
While I know you guys have put in a lot of time on this tune, I figured I'd ask as I know some will want to up the boost and do personal/custom setups with the kit, just a thought
-Seven || youtube.com/turnsevenvideo
2012 C6 Grand Sport 4LT
2015 Mazda 3i-T/Tech
seven is offline   Reply With Quote
Old 11-18-2012, 07:13 PM   #1558
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
This kit pretty much is a tuner kit, a tuner kit does not provide tuning or fuel. The only thing this kit does in regards to those things is provide a daily driver tune so the car is operational. Other kits are more expensive because they also provide injectors and a fuel pump, which is another 750 or so dollars tached on.
Tansey86 is offline   Reply With Quote
Old 11-20-2012, 01:30 PM   #1559
Tansey86
Tansey86's Avatar
May have missed this, but does any aftermarket Cold Air Kit bolt up to this? For example if I buy an injen CAI and then install the AVO kit, will it bolt right up?
Old 11-20-2012, 01:43 PM   #1560
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
Not without modification.
Intake kits run from the throttle body to the snorkel in the bumper. Any new intake will need to run from the turbo - not the throttle body.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 11-20-2012, 01:57 PM   #1561
2forme
You'd be better off with an AIRAID or AFE intake since they come close to the stock location, piping-wise. I'd go with an AFE over an AIRAID because they flow a bit more and suck in colder air.
Injen's are SRI's and suck air from the engine bay.
Old 11-20-2012, 01:58 PM   #1562
Tansey86
Tansey86's Avatar
I was just talking about the box, not the piping. But yeah I like the Injen looks the most and apparently it does work very well. This is just based off testing ive seen.
Old 11-20-2012, 02:02 PM   #1563
2forme
I'd want colder air for any kind of forced induction.
I haven't seen any credible testing showing driving conditions. I know the AIRAID unit sucks in considerably warmer air, and the Injen is even further back in the engine bay. But if you like the looks, then it's whatever. However, that's a lot of money to pay for a filter and filter house. Food for thought.
Old 11-20-2012, 02:41 PM   #1564
Tansey86
Tansey86's Avatar
Well hopefully AVO will chime in on the compatibility of aftermarket boxes for the kit, i'll probably just go with whatever one has the best gains.
Old 11-20-2012, 03:00 PM   #1565
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Any air box that has one connection where the stock airbox ends, and the pipe run begins, will work with the AVO kit. A tune will be required to account for the new airflow and get maximum gains.
Old 11-20-2012, 06:00 PM   #1566
ahaghshenas
ahaghshenas's Avatar
Drives: Subaru BRZ
The only kit that will be compatible of the bat is the ARC Aluminium Super Induction Box (about double the price of other kits) as it hooks up to the stock piping and includes a spot for the MAF sensor
Other kits like afe or injen relocate the MAF sensor on there kits piping, which you wont be using with the AVO turbo kit. Therefore a mod to the AVO pipe or an intermediate piping between to locate the MAF sensor wud be needed.
ahaghshenas is offline   Reply With Quote
Old 11-20-2012, 07:22 PM   #1567
BoostedWrbBrz
Drives: 2014 Wrb Brz limited 6m
This work with an auto trans
BoostedWrbBrz is offline   Reply With Quote
Old 11-20-2012, 07:28 PM   #1568
sf86
sf86's Avatar
Drives: Red Scion FRS AT
yes it does
sf86 is offline   Reply With Quote
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
