Old 06-01-2014, 10:22 PM   #1527
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Both can handle more spring than OTS; the nod to engineering goes to Ohlins. I don't know the exact range since we haven't done enough testing to determine, but I'd guess a +100 is viable for both, perhaps more.
I didn't mean "than OTS"..I meant, which could handle more? ..in the damper's original OTS state.
fooddude is offline   Reply With Quote
Old 06-02-2014, 09:01 AM   #1528
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
RCE Andy has posted dynos for both of the systems you are asking about. On this very thread I think. Do a search and you will see that the RCE T2 will offer you more damping and damping adjustment range therefor ability to accommodate different or higher sprig rates. than the Ohlins. Another thing to consider is one system is a twin tube (KW) and the other is a mono tube (Ohlins). Again the benefits and drawback of the two types are probably already covered in this very tread. While I have 0 experience with either system on this car, I think it's safe to assume that the Ohlins will offer better accuracy of the 2 while the KW's will offer a much broader range. But then you have to consider the independent adjustability of the KW 2-way can offer you in terms of tuning over the singles. Can't go wrong with either, IMO. Ask yourself what you value more in a coilover system, then pick your poison.
Whatever happened to wanting Fortune Auto dampers? lol
The Following 2 Users Say Thank You to solidONE For This Useful Post:
fooddude (06-02-2014), Racecomp Engineering (06-02-2014)
Old 06-02-2014, 09:24 AM   #1529
We ran them back to back. Street, track, backroads, suburbs, downtown, everything. Advantages to each of them but yes I'd say OTS you have more headroom with RCE T2s and the 2 way adjustability gives you an edge in dialing them in with stiffer springs than a 1 way. But Ohlins are Ohlins...fast, fun, and simple. We ran them stock and with 8k springs all around...they did well.
- Andy
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
fooddude (06-02-2014), solidONE (06-02-2014)
Old 06-02-2014, 04:46 PM   #1530
Malt
Drives: 2015 WRX
Going in for another alignment tomorrow and I vaguely remember something about advantages/disadvantages to getting camber with camber plates vs camber bolts. Am I crazy or was there a benefit to using camber plates over the bolts?
Malt is offline   Reply With Quote
Old 06-02-2014, 04:49 PM   #1531
ayau
Drives: Some rust bucket
Yup, camber at the hub (crash bolt) is ideal because it doesn't change the steering angle inclination (SAI). However, you'll be limited to only about -1.5 max, which isn't enough if you're pretty serious about tracking the car. For more camber, you'll need camber plates.
Old 06-02-2014, 08:41 PM   #1532
solidONE
solidONE's Avatar
That is a lot of camber considering it's just stock crash bolt.
Old 06-02-2014, 08:43 PM   #1533
Malt
Drives: 2015 WRX
To be fair, I'm running RCE T2's which have a slotted top hole along with raceseng camber plates. I'm sure I can get all the camber I want from either choice, I just wanted to be sure I was telling the shop where I wanted the alignment performed at.
Old 06-02-2014, 08:47 PM   #1534
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
I got -1.2 up front with just the crash bolts. I was pretty impressed with that.
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 06-03-2014, 12:52 PM   #1535
Malt
Drives: 2015 WRX
Originally Posted by Racecomp Engineering View Post
K. Not knowing much about using bolts to adjust camber in the rear and how much adjustment they have, I'd just be worried about you buying toe arms and then finding out that your camber bolts are maxed out anyway. Can you peek under and see if there is much adjustment in the bolts left?
- Andy
Semi old reply but info for those that are curious. Went in for the alignment this morning after I installed my toe arms and while it was on the rack the tech showed me the range of adjustment for the camber bolts in the rear. Roughly 0.3 degrees. So not enough to get the camber dialed in with the toe I wanted in the rear.
Let this be a lesson to those of you who lower your car. Don't cheap out and do everything to avoid buying lower control arms. I've spent well over twice what it would of cost me to just buy them now in alignments/parts that I didn't use or didn't work.
Buying LCA's now and finally going to put this to rest
The Following User Says Thank You to Malt For This Useful Post:
CSG Mike (06-04-2014)
Old 06-03-2014, 01:16 PM   #1536
That's what I was afraid of. Thanks for updating!
- Andy
Old 06-03-2014, 03:21 PM   #1537
enivid
enivid's Avatar
Drives: WRB JR BRZED
I got 1.5 with stock bolts. I'm going to switch to the crash bolts to get - 2.
enivid is offline   Reply With Quote
Old 06-03-2014, 03:33 PM   #1538
was385
Drives: MT WRB BRZ Limited, 2007 911s
This is really for anyone with experience, including the RCE guys:
How big is the performance gap between a stock dampers/RCE Yellow setup and a Bilstein B8/RCE Tarmac setup? This would mainly be for autox (locally, never going to spend enough to be nationally competitive) and the occasional track day as well as DD duty. I'm trying to decide if it's worth the cost to jump up to the next level.
was385 is offline   Reply With Quote
Old 06-03-2014, 03:49 PM   #1539
Turkish
Serial Cone Killer
Turkish's Avatar
I will say, that completely OE to B8/Tarmac I have LESS problems bottoming out in dips in the road. Steep driveways and really tall speed bumps present the usual challenge for lowered cars. I realize that this doesn't necessarily answer your question, but the stiffer shocks and springs really firmed up the driving, at the expense of a touch of bounciness.
... his name is...
C'THULHU
The Following User Says Thank You to Turkish For This Useful Post:
was385 (06-03-2014)
Old 06-03-2014, 04:11 PM   #1540
was385
I'll be going into a purchase blind based on what I read on the internet so any and all first-hand experiences are very useful even if they're not exactly what I asked. Thanks.
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
