Old 09-23-2012, 10:01 PM   #1527
Yruyur
Yruyur's Avatar
Sweet. You running any specials on the e85 tunes if we meet you there. There are few from AZ thinking of driving out there.
Yruyur is offline
Old 09-23-2012, 10:11 PM   #1528
Visconti
Drives: 05 STi
I've been thinking about it
Visconti is offline
Old 09-23-2012, 10:29 PM   #1529
BAE
BAE's Avatar
Drives: BRZ Ltd WRB
No, they should be shipped with-in 10 days.
I'm preparing them all right now
John
I have only paid the deposit. Shall I pay the rest now?
Enkei RPF1/K&N/Perrin crank pulley/Visconti Stg1/Perrin catback and overpipe/KW V3
BAE is offline
Old 09-24-2012, 12:31 AM   #1530
Subynewbie
Subynewbie's Avatar
Drives: 2013 swp brz
For those of you who have flashed their cars I'm not sure I'm doing this correctly. Car is running and logging to file with a red light on cable. If this is correct thus far, how long does this take?
Thx
Subynewbie is offline
Old 09-24-2012, 02:22 AM   #1531
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
How close are we to map switching on the fly? I will purchase the e85 tune as soon as its available i only need 3 maps: stock, 93, and e85. My other mods are pretty mild i've got a Cosworth drop in filter, Perrin pulley, and Motiv Test Pipe although i will be adding adding an axleback or TRD exhaust in the future i'll send some logs though if you want them once the i get the cable from the group buy.
JoeBoxer is offline
Old 09-24-2012, 02:27 AM   #1532
Yruyur
Yruyur's Avatar
When doing on the fly map switching does the ecu require 50 miles to relearn like after a new flash is done?
Yruyur is offline
Old 09-24-2012, 03:01 AM   #1533
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
I have to wait for flex fuel sensor capability to be added. There is an E85 station relatively close to me, but not close enough to be convenient for every fill-up, and there certainly aren't enough stations in the surrounding area.
Flex fuel would be awesome though.
uspspro is offline
Old 09-24-2012, 05:21 AM   #1534
LeavingNormal
FRS2DTH
LeavingNormal's Avatar
Drives: Hot Lava 2013 Scion FRS
John said its already in the works, I'm waiting for that tune also.
LeavingNormal is offline
Old 09-24-2012, 05:53 AM   #1535
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
For a real flexfuel switching automaticaly through two maps or more depending on how much the ecu can adapte then you will neeed to install one of this flex fuel sensor and use their voltage signal to switch through map's
http://www.autozone.com/autozone/par...nsor/_/N-8veh0
http://www.ebay.com/itm/Haltech-Flex...c7da80&vxp=mtr
Mars2 is offline
Old 09-24-2012, 05:55 AM   #1536
Mars2
http://www.zeitronix.com/Products/ECA/ECA.shtml
Mars2 is offline
Old 09-24-2012, 06:04 AM   #1537
Mars2
On My other car VW Golf R32 we have oem build'in wide band lambda that are always working in closed loop even at WOT so it's pretty easy for the tunner. he just have to widen the range of fuel adaptation from 25% to 45% and then the fueling adapte automatically according to lambda reading.
About the timing the tunner put a few different map with first one very agressive for the E85 and then if their is knock because lower pourcentage of E85 it switch to more conservative map of ignition.
OK I simplify abit but that's the idea.
Have use this R32 Flexfuel tune since 80k miles with no problem and no headach about what blend of E85/Gazoline is in my tank it's all automatic the ecu adapte itself to whatever according to O2 reading and knock.
But I guess BRZ/FRS/GT86 do'y have wide band lambda porbe and are in open loop when at wot.
Mars2 is offline
Old 09-24-2012, 07:24 AM   #1538
Visconti
Drives: 05 STi
Map switching this week. Racerom guy was sick for a few days last week..
Don't ever need a 50mile learn
Sure
Visconti is offline
Old 09-24-2012, 08:35 AM   #1539
CharlieChaos
Drives: FRS
If I havent recieved the file from you yet should I remail you or is it gonna get sent out when the cable does?
CharlieChaos is offline
Old 09-24-2012, 08:38 AM   #1540
Visconti
Drives: 05 STi
Anyone with a six speed that didn't get a file yesterday needs to email me to let me know.
I'll need your first and last name in the email
Visconti is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 10:09 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 01:42 PM
