Old 09-13-2014, 10:29 PM   #141
Triumphrider
Triumphrider's Avatar
Drives: 2013 Scion FRS in white out
Tried everything I can think of... Still can't save those tables
2013 Scion Frs AT in Whiteout, Borla UEL header, Greddy SP Elite AxleBack. Kraftwerks C38 Supercharger tuned by Moto East and 2 kid seats in the back.
Triumphrider is offline   Reply With Quote
Old 09-13-2014, 11:12 PM   #142
Triumphrider
Originally Posted by Wayno View Post
Whenever I reopen the bin file after modifying tables Timing Compensation Per Cylinder A and B, they are returned to the original values. Knock Correction Max Advance A saves fine. What's going on?
Hey @Wayno did you do anything else other than change your user level? I'm on the highest setting and I still can't save those 2 tables.
Old 09-14-2014, 10:12 PM   #143
Triumphrider
So I have gone as far as deleting OFM / Romraider and all my Maps and re-installing them today. Everything is up to date and I still cannot get the timing compensation table A and B to save. Knock correction max advance saves without issue. Rom Raider has the proper ecu definition file
And my user level is advanced....not sure what to do now? BPB's are due to arrive this week and I'm out of luck having a map ready.
I'm by no means a computer guy, but I have never had any issues with updating and loading my maps and flashing the car using OFM. This is my first time using romraider...am I overlooking some sort of settings?
Old 09-14-2014, 10:58 PM   #144
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
You said you're on the highest user level then said you're on 3. You need user level 5.
Old 09-14-2014, 10:59 PM   #145
Triumphrider
I tried the highest one as well... Still no luck
Old 09-14-2014, 11:10 PM   #146
Triumphrider
Is there anything funny like copying cells one at a time of anything like that? Right now I just copy the section next to it and paste it in all in one shot..
Old 09-14-2014, 11:18 PM   #147
Wayno
Wayno's Avatar
Copy the tables from C or D to A and B.
Old 09-14-2014, 11:36 PM   #148
Triumphrider
It's late here tonite bit I'll give that a try tomorrow... Thanks for the tip!
Old 09-15-2014, 08:32 PM   #149
Triumphrider
So here is what I was doing wrong. Firstly I had my user setting as advanced and it needed to be on debugger. Secondly I copied tables from C and D and pasted to A and B. At first it was trying to copy zero'd cells within tables A and B....apparently that didn't work. Got it all sorted now. Thanks to all replied and helped....first time using romraider...now to learn how to data log hahaha
Old 09-15-2014, 08:35 PM   #150
Wayno
Wayno's Avatar
Don't worry, everyone does the exact same thing, me included.
Old 10-01-2014, 09:28 PM   #151
mission2toilet
mission2toilet's Avatar
Originally Posted by Silver Ignition View Post
GOTTA use E85 tune. I used Stage 2 EL e85 tune for my BPB on e85
So you have BPB and running E85 stage 2 EL?(do u have EL or UEL headers?
Reason I ask is I tried stage2 E85 UEL and to me stage 2 UEL BPB 93 was faster!
Thanks~
mission2toilet is offline   Reply With Quote
Old 10-02-2014, 05:03 PM   #152
Triumphrider
Well Installed my BPB today and loaded up my tune. Took it very easy for a few miles to help the fuel trims sort out. Car runs incredibly smooth, Nice and steady pull from 3k rpm til 6500 when I shift anyway. I am on Borla headers, greddy sp elite axle back, perrin drop in filter and stage 2 UEL BPB OFT 91 oct. tune. Loving it!
Old 10-09-2014, 03:53 AM   #153
Stumpygt86
Drives: Toyota GT86. N/A for life
What did you do as I am having the same issue. Tried on advanced and DeBug
Stumpygt86 is offline   Reply With Quote
Old 10-09-2014, 04:57 AM   #154
Stumpygt86
All sorted
Vishnu Tuning's Tales From The Dyno: Crawford Billet Power Blocks Shiv@Openflash Engine, Exhaust, Transmission 129 11-24-2017 07:58 PM
Crawford Billet Power Blocks smbstyle Engine, Exhaust, Transmission 799 01-18-2016 05:01 PM
Crawford Billet power blocks Triumphrider Engine, Exhaust, Transmission 0 08-01-2014 01:39 AM
FS: One set of barely used Crawford Billet Power Blocks Robert@Openflash Engine, Exhaust, Bolt-Ons 1 06-07-2014 04:13 PM
**Crawford Power Block Install Special -- R/T Tuning -- Call Today** R/T Tuning Engine, Exhaust, Bolt-Ons 3 05-21-2014 11:18 AM
