Old 08-20-2014, 02:09 PM   #141
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Element Tuning View Post
Sorry if I offend anyone, but I came...
Old 08-20-2014, 02:18 PM   #142
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Ha ha. I so wanted to turn up the boost even higher but when my logs showed 100% injector duty and even at this boost level it was too lean for maximum power.
I think for now we'll hold the power level we're at and get back racing in TT3 or TT2 to finish out the year. Hopefully the transmission will hold up but I do have a spare we bring to the races just in case.
Element Tuning is offline   Reply With Quote
Old 08-20-2014, 02:51 PM   #143
Dezoris
Dezoris's Avatar
I wish I could get some video of that car. That clip was amazing.
Assuming it holds up and is somewhat reliable you guys may have the most legit race ready 86 setup.
Thanks for sharing details about pressures and other things for those of us who double duty the car.
Old 08-20-2014, 03:45 PM   #144
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
If I remember correctly, when you first did the Hydra, you were only on port injection. Is that still the case?
Old 08-20-2014, 03:49 PM   #145
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
Wonder if na would make power with just the head port, springs and valve angle job..
IG-Joey_Soul
Old 08-20-2014, 05:12 PM   #146
mike the snake
In another thread about lightened flywheels and pulleys, I read that some have found that running lightened parts on both ends of the engine (lightened flywheel AND pulleys) caused failures of bearings.
I wonder if there's something to be taken from that on a high rpm race engine.
Maybe a harmonic balancer?
Old 08-20-2014, 05:50 PM   #147
noob and expert
Drives: None :(
Of course it will, but the gains would be much larger if it had FI. Doing that always helps though (assuming the porting is done right).
For me, there is no glide in pulse and glide :p
??? is offline   Reply With Quote
Old 08-20-2014, 06:20 PM   #148
mike the snake
Looks like they're getting 240-250 hp with higher compression, ITB's and other mods.
http://www.ft86club.com/forums/showt...t=71092&page=2
Old 08-20-2014, 08:29 PM   #149
Element Tuning
We only ran that in the very, very early stages just to solidify the DI was a huge advantage and it is.
Now the Hydra EMS runs both the direct injection and the port injection along with quad variable cam timing, and full CAN support. So your ABS, stability control, all dash functions etc remain but the biggest asset is the fact that you can fully turn off the "stability control" and have a fully programmable traction control!
The direct injection and port injection strategy is also different from OEM and really allows me the freedom to change very specific ratios of "port" to "direct" injection at any boost or RPM level.
The flex fuel support is also very awesome because it switches fuel, timing, boost, starting, closed loop fuel tables, and more when running full E85 but when you taper off the ethanol it automatically alters the maps until it finally fully switches to the pump fuel mapping.
Very cool!
Phil Grabow
Old 08-20-2014, 08:49 PM   #150
Element Tuning
I just need someone to say, "Phil, I'm going all out NA, build me an engine."
Yes there would be significant gains with the head mods even NA. Probably NA would benefit more with some cam grinding also where the cams are pretty aggressive already for boosted applications.
Old 08-20-2014, 08:52 PM   #151
Element Tuning
No they just aren't as smart as we are. Oil pressure is the issue, not lightened parts. From the get go with just pictures it was obvious that we would have high demands for oil pressure. Unfortunately it took a lot of R&D to get the oil pressure we needed.
I'll be moving onto our external oil pump shortly and then the dry sump. We already have it all and just need to start making brackets etc.
Thanks,
Phil Grabow
Old 08-20-2014, 08:59 PM   #152
Turdinator
Señor Member
Turdinator's Avatar
There is no mention of ITBs and in fact I am rairly sure under the R3 rules you have to have a single throttle body. Also the quoted power figure is at the flywheel not the wheels. Someone with full bolt ons and a tune is probably already making similar power at the flywheel. I suspect the rally car has a nicer power curve though.
1974 TA22 Celica
2013 86 GT
Old 08-21-2014, 03:32 AM   #153
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Looking at a built FA20 block, this quickly becomes a very very expensive build. Can this be a sticky?
Old 08-21-2014, 03:38 AM   #154
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
So finally I can really run the Element Tuning Pro Comp motor hard to 9k RPM, run after run. In this video I'm running right at 20-21 psi of boost on E85, FIC 1100cc injectors, DW300 fuel pump, Garrett 60 Trim, Hydra EMS, Perrin 3" cat-back exhaust, internal oiling mods, oil accumulator, and the Perrin Oil Cooler kit.
Phil, I'd love to hear a price quote for all that work, but I'm scared im going to have a heart attack.
FA20 Engine component photos Crawford FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 89 02-22-2016 02:31 AM
FA20 Engine component photos Crawford Engine, Exhaust, Transmission 46 01-26-2015 05:19 AM
Engine Hardware, Gaskets, & Bearings Oh My; All on sale at FR Sport. FRSport.com Engine, Exhaust, Bolt-Ons 0 01-10-2014 12:33 PM
FA20 Le Mans Race Engine SilverSkyline210 Engine, Exhaust, Transmission 11 11-17-2013 11:24 PM
