Old 02-12-2014, 09:03 PM   #141
stevo585
Drives: White 2014 BRZ
I'm running the stage 2 EL e85 on a completely stock car. Feels great! Like I have a V6 or larger displacement engine. The datalogs show very rich @ 11.25:1 but 45 degrees of timing advance!
stevo585 is offline   Reply With Quote
Old 02-12-2014, 09:27 PM   #142
jamesm
Surely you don't mean 45 degrees under load, do you? That's insane lol.
Old 02-12-2014, 09:30 PM   #143
stevo585
Yes @ WOT I believe that's what the OFT said. I'll verify tomorrow.
Old 02-12-2014, 09:37 PM   #144
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Nope, 45 degrees sounds right. Under certain conditions my total timing was up to 50 degrees advance.
Luckrider is offline   Reply With Quote
Old 02-12-2014, 09:46 PM   #145
Luckrider
Luckrider's Avatar
I switched back to gas today and was able to get just over 11.5 gallons in the tank. I ran it for almost 10 minutes before flashing and probably almost 10 minutes after flashing before moving, but the fuel trims are just crazy right now. After the 3 minute drive home from the gas station (and very little throttle), LTFT was almost 30%. AFR was bouncing and running rich in some places and there were times when STFT was almost 30% and LTFT was -2%-3%. Unmodified 1.52b file that was generated automatically. My computer's battery died before I could finish transferring over the 1.55b tune.
Old 02-12-2014, 10:58 PM   #146
Luckrider
Luckrider's Avatar
@shiv@vishnu
I just opened the OFM while connected to the interwebs and it is downloading lots and lots of stuff and upgrading my device. Are we finally getting those extra logging parameters?
Old 02-12-2014, 11:11 PM   #147
Luckrider
Luckrider's Avatar
Just as an update to this, here is a snipping of my last e85 log. This was after probably 5 consecutive tanks of e85 after the previous last flash.
Old 02-12-2014, 11:14 PM   #148
jamesm
That's seems normal, cruising around 50-ish degrees. At WOT it shouldn't be anywhere near that. Is that what you meant before?
Old 02-12-2014, 11:21 PM   #149
Luckrider
Luckrider's Avatar
That is what I meant. Here is the actual log pointing to a useful spot
Old 02-13-2014, 12:26 AM   #150
steve99
I switched back to gas today and was able to get just over 11.5 gallons in the tank. I ran it for almost 10 minutes before flashing and probably almost 10 minutes after flashing before moving, but the fuel trims are just crazy right now. After the 3 minute drive home from the gas station (and very little throttle), LTFT was almost 30%. AFR was bouncing and running rich in some places and there were times when STFT was almost 30% and LTFT was -2%-3%. .
Went back to gass (petrol here in Oz) from E85 yesterday as well.
Noticed same thing.
Appears it take a few Km to clear the E85 out of lines (suppose their is 300mL or so in lines pumps ect, by which time the ECU has tried to compensate and remembered the compensations for running E85 (or high alcohol content) on a petrol map ie huge fuel trims due to E85 in lines.
Then suddenly is will get straight gass (petrol) but its still on the E85 compensations so you get weird stuff like +30 LTFT and -30 STFT as it re learns petrol on a petrol map. Quite interesting to watch and not likely to cause any drama as long as you drive very sedately till it all settles down took about 20 km to unlearn compensations and settle on petrol.
Old 02-13-2014, 07:54 AM   #151
bfrank1972
Drives: 2013 FR-S Argento
FYI I usually flash a bit after switching fuels - drive around a bit watching the fuel trims until they start changing rapidly, that's when the new fuel has made it through the lines. Then I pull over and re-flash, will save you from running a map not matched to your fuel. The ECU compensates with fuel trims, but I still don't feel comfortable with it, especially when converting from gas to E85 (aggressive timing).
bfrank1972 is offline   Reply With Quote
Old 02-14-2014, 02:40 AM   #152
8686
8686's Avatar
Drives: 86
My data log. I am little bit concerned that the KC learning value dropped after 6,800 rpm.
Mod list is in the signature. comments are appreciated.
http://www.datazap.me/u/haririmm/155...7-8-9-10-11-12
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 02-14-2014, 03:29 AM   #153
steve99
Are headers catless
ROM type C.D, G ect
But if you assumed 1.5 stage 2 due headers fitted (catless ??) then the KC learned looks a bit low through out the rev range.
I have been told by person's more experienced than myself that the KC learned should track the "Knock correction Advance" table in ROMRaider for given RPM/LOAD values.
If so looks like its pulling about 1-2 degrees timing.
Maybe try better fuel if you have added max octane booster
Old 02-14-2014, 04:13 AM   #154
8686
8686's Avatar
Drives: 86
Are headers catless
ROM type C.D, G ect
Yes the headers are catless.
And yes, our gas is like shit so with each visit to the gasstation I add one bottle of Lucas Octane Booster.
ROM type is K.
Should I add 2 bottles for every tank.
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
FS: Openflash Tablet Sgt.Beardface Engine, Exhaust, Bolt-Ons 8 01-04-2014 11:12 AM
FS: Openflash tablet nguyen_er Engine, Exhaust, Bolt-Ons 6 12-30-2013 12:31 PM
new OpenFlash tablet autobrz Engine, Exhaust, Bolt-Ons 5 12-23-2013 09:05 AM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
