#141 |
Drives: 2004 Toyota RAV-4 5M
I doubt it. If anything I would imagine the extra pressure and heat would make them more prone to wearing out the DI seals.
Which reminds me, on my first day at NJMP (Saturday) I got a CEL for P0351, which is the coilpack warning and some people have seen it with DI seals going bad. It went away overnight and didn't return during any of my Sunday sessions. I couldn't feel, hear, or smell any issues, even when the light was on, so I just kept going, but I should probably take it to a dealer to get it checked out. |
#142 | |
Drives: Hydra EMS Powered FRS Raven Black
Check the wiring for a short against the fuel rail protector on the passenger side. I just blew out (EFI "IGN") fuse and the wiring diagram shows coils 1 and 3 are wired to that. I need to dig into the harness but it's a dead short because the fuse blows instantly. Phil Grabow |
#143 |
NA Summit Point (Main) / 1:26:259 / Josh Adams / June 8, 2014 / Ohlins Road and Track, ACT Prolite Clutch/Flywheel, DSS CF Drive Shaft, Whiteline Pos. Shift Kit & Diff Cradle, Perrin Motor Mounts, Driveway Labs Rear Diffuser, Essex AP Racing Sprint BBK, Hawk DTC-60, K&N Drop In Filter, Crawford Performance AOS, Hoosier R6 225R45, 70lbs. of ballast
[ame="http://youtu.be/3Cj0EHnLImQUnfortunately"]http://youtu.be/3Cj0EHnLImQ[/ame] Unfortunately, this was the only session on the Hoosiers I got in yesterday. It started raining in the afternoon and I packed it in early. The car should pretty easily have a low to mid 1:25 in it, maybe even a 1:24, which would put me close to the lap record for TTD. I had a 1:25 going for just a little bit according to my data logger, but I went through the chute (turn 4) faster than I've gone before (104 on entry and didn't drop below 101 through the turn) but I couldn't get the car settled quick enough, which you really need to do on this turn before you slam the brakes) and ended up going off track just a little. This, unfortunately, disqualified my entire session so I did not get the second place that my 1:26.259 would have gotten me for the day. Video of going off course: Good news is I didn't get any CEL's this weekend, so I think my last event may have just been a fluke. And I only put one heat cycle on the Hoosiers so they should still be pretty good when I hit VIR next month where I think I have a decent chance at winning TTD. |
#144 |
Drives: 2013 Scion FRS
NA NJMP Lightning/1.20.36/Dan/19 June 2014/RCE yellow springs/Hawk DTC-60 pads/Yokohama AD08R tires (225/17/45)/Castrol SRF brake fluid/Harry's LapTimer
#145 |
Drives: 2022 BRZ Limited
@jsimon7777 I have installed the Kraftwerks kit (Moto-East tuned), Fortune Auto 500 coilovers with 9k/9k swift springs,
Track Name/Track Time/Driver Name/Date/Mods/Link Oregon Raceway Park(RMP) CW/2:02 /glamcem/6-15-2014/Kraftwerks kit (Moto-East tuned), Fortune Auto 500 coilovers with 9k/9k swift springs, -3.0 Front / -2.8 rear camber, 235-40-17 Nitto NT-01 R Compounds (17x9 +35 RPF1 wheels), Carbotech XP12/XP12 pads, Motul RBF 600, Ti shims, heat reflective material for brakes, Grimspeed MBC brace, back seats removed/ w/some serious rubbing issues [ame="http://youtu.be/2JDtUJGLag0"]http://youtu.be/2JDtUJGLag0[/ame]
#146 | |
Dismember
Drives: 2013 Red Scion FR-S
#147 |
Dismember
Bypass?
#148 |
#149 |
I copy pasted the last post and updated the track and date info but left the wording "I've installed" ..This is ORP in the last video times are similar so I'm sorry for the confusion
#150 |
#151 |
Drives: 2013 BRZ Limited
NA Miller Motorsports Park (MMP) East Track / 2:08.05 / Lisa Crawford / 6/28/2014 / RCE Yellows, Eibach Sway Bars, HVT top hats, SPC camber bolts, SPC Rear LCAs, -3.0F -2.9R camber, 0 toe F/R, Enkei RPF1s, OEM tires, Perrin Inlet, Blitz panel filter, Crawford BPBs, OFT, HKS EL catless header, Q300, Driveshaft Shop Aluminum Driveshaft, MTEC Shift Springs, Perrin Oil Cooler, EBC Yellowstuff pads, ATE 200 brake fluid, Grimmspeed master cylinder brace
[ame]http://youtu.be/FPJi-WoxO0U[/ame]
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523 Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car www.makesmodels.com www.camautomag.com Last edited by zdr93523; 07-01-2014 at 01:24 AM. |
| The Following User Says Thank You to zdr93523 For This Useful Post: | Blizzard (09-08-2014) |
#152 |
NA Miller Motorsports Park (MMP) East Track / 2:02.26 / Toby Crawford / 6/29/2014 / RCE Yellows, Eibach Sway Bars, HVT top hats, SPC camber bolts, SPC Rear LCAs, -3.0F -2.9R camber, 0 toe F/R, Enkei RPF1s, OEM tires, Perrin Inlet, Blitz panel filter, Crawford BPBs, OFT, HKS EL catless header, Q300, Driveshaft Shop Aluminum Driveshaft, MTEC Shift Springs, Perrin Oil Cooler, EBC Yellowstuff pads, ATE 200 brake fluid, Grimmspeed master cylinder brace
2014-06-30-22-22-35 by zdr93523, on Flickr
Youtube: https://www.youtube.com/user/zdr93523 Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car www.makesmodels.com www.camautomag.com |
| The Following User Says Thank You to zdr93523 For This Useful Post: | EAGLE5 (08-24-2014) |
#153 |
Drives: Devolving WR Blue 6 Spd BRZ Limited
2 min 17 sec lap at vir, May 2014, n/a
VIR Full, 2 minute 17 second lap, Eric Nilsen, naturally aspirated, May 2, 2014
mods: toyo r888 on 17 x 8in wheels, ap racing sprint front brake kit, nameless exhaust/ header, mfactory 4.67 final drive, bc racing coilovers, cusco rear lca's [ame="https://www.youtube.com/watch?v=QlDtLwrZvIo"]Subaru BRZ 2 min 17 sec lap at VIR chasing Porsche 944 - YouTube[/ame] |
| The Following User Says Thank You to Slip Angle For This Useful Post: | YodrOne (09-21-2014) |
#154 |
Virginia International Raceway (Full Course) / 2:15:521 / Josh Adams / July 20, 2014 / Ohlins Road and Track, ACT Prolite Clutch/Flywheel, DSS CF Drive Shaft, Whiteline Pos. Shift Kit & Diff Cradle, Perrin Motor Mounts, Essex AP Racing Sprint BBK, Hawk DTC-60, K&N Drop In Filter, Crawford Performance AOS, Hoosier R6 225/45R17, 70lbs. of ballast
Unfortunately, my camera wasn't working during my best session, so I don't have any video. Official results can be found here though: http://timingscoring.drivenasa.com/N...n-TT-FINAL.pdf I managed to lose my rear diffuser to some roadkill in the middle of the night on my way to the beach the week before the race, which is why it was no longer listed. Was still able to be fast enough to win TTD on both Saturday and Sunday, so fresh Hoosiers here I come! I do have video of my best lap from Saturday, which was a 2:16.587 [ame="https://www.youtube.com/watch?v=ooCdWxMc-nY"]NASA MA (Heat Wave) - 7/19/14 - VIR - TTD Session 4 - YouTube[/ame] Unfortunately, my CEL light came back (P0351 was the code if I remember correctly) and on my way home I started noticing some popping noises coming from the engine bay, so I think I might be having some of the dreaded DI seal issues. I'm at the dealer right now trying to get this addressed. Also, since I updated my data logger I can track my oil temps. I was averaging 270-280f, so I think it might be time for an oil cooler. Last edited by ja1217; 07-22-2014 at 02:02 PM. |
| The Following User Says Thank You to ja1217 For This Useful Post: | EAGLE5 (08-24-2014) |
| Can too much grip hurt track times? | ayau | Tracking / Autocross / HPDE / Drifting | 53 | 04-22-2013 11:28 AM |
| Top Gear (UK) track times | GeeTee86 | AFRICA | 29 | 02-15-2013 08:04 AM |
| Before/After Track Times (Sonoma Raceway) | CorteXracing | Tracking / Autocross / HPDE / Drifting | 5 | 11-26-2012 11:28 PM |
| POST YOUR FASTEST GT5 NURBURGRING TIMES.... | FT-86GOD | Other Vehicles & General Automotive Discussions | 96 | 07-15-2012 01:45 PM |
| GT5 - fastest Suzuka (full track) times | NESW20 | Other Vehicles & General Automotive Discussions | 11 | 04-03-2011 01:20 AM |
