#141 | |
Reverse Burnouts
Drives: 2013 Argento FRS
![]() theres a hill by my house thats a 15% grade on the freeway and i dont need to leave 6th to climb it either, i cruise at 70 and my pedal doesnt really move when i go up that hill... lighter cars dont struggle as much up hills even though they are torque less wonders...
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#142 | |||
Drives: N/A
This engine has barely more torque than some compact cars, the advantage is this "sportscar" has it all in better gearing and more power from 4k-7k RPM. This is an involved car, not a lazy DD. Quote:
#143 |
Drives: '06 AM V8V Coupe
lol, I'll just copy it over the day someone wants to know about it.
But the early shifts helping fuel economy makes sense, because the lower the load, the bigger the difference right? I also have a hunch that typical automatic transmissions, when put in auto mode at least, may use gas pedal input as an indicator of overall torque demand, rather than engine load demand. That would REALLY help EPA scores. |
#144 | |
Drives: ‘16 4Runner, ‘19 Corolla HB
#145 |
The reason why I think it's okay to extrapolate is that the engine has cam phasing, but not variable lift/duration. The 2GR-FSE makes power a good 1000 rpm lower than this engine, and in Toyota released papers they indicate an intake cam duration of ~250 degrees or so. For the 1NZ-FXE there are similar diagrams that indicate a ~270 degree intake cam.
The FA20 needs more duration than the 2GR-FSE in order to have good VE at 7000rpm, so it's reasonable to expect slightly longer duration intake cams. If you look at the released dyno charts you'll see that the torque is very weak before 3000. However the specific torque is quite a bit stronger than say the 1NZ-FXE or 2ZR-FXE at low rpm. The reason being, direct injection + premium fuel allow them to use a huge intake cam advance that causes a lot of hot exhaust gas to get trapped in the cylinder. Of course there is a limit to how much you can do this before you run into problems, so the torque under 3000 is weak. If you look at the 2GR-FSE on the other hand, its torque is weak below 2000, but is pretty good after 2000. By comparison, the 2ZR-FXE has torque that increases up to about 4000rpm. So there is definitely an appreciable difference in intake cam duration, and my guess is that the FA behaves somewhat like a direct injected Prius at medium load, low rpm. The cam is probably closer to the Atkinson cycle engines than it is to the 2GR. In addition, may I note that Toyota's D4-S system created sufficiently homogeneous fuel mixtures at low speed even with a high flow port on the 2GR, so it's possible that an even longer duration intake cam will reduce throttling loss but not affect combustion, improving fuel economy. Direct injection, crazy stuff
#146 | |
Reverse Burnouts
![]() Great explination
#147 |
Drives: N/A
Good read and I know exactly what you are talking about. For once.
