#141 |
Drives: 2013 FR-S, 2016 Miata Club
It's growing on me...
http://www.tomeipowered.com/BTE/wp-c.../sDSC01915.jpg |
#142 |
Drives: FR-S Whiteout
Hmmm It looks identical to the street version from the rear axle forward with the axle back held on with exhaust springs. If that's the case I'd just buy the street version and have a section of piping fabricated without muffler. The rear section should be a easy on/off affair at the track.
#143 |
Question:
would the 60R or 60S clear the oem subaru rear diffuser? Thanks. |
#144 | ||
Drives: 2014 Widebody Cosworth FR-S
![]() PS. Talke to TOMEI and they will do testing in Japan and let us know Kirill RallySportDirect.com Last edited by RallySport Direct; 08-14-2013 at 06:47 PM. |
#145 |
I am interested in this exhaust.
I am soon going with a turbo kit, and I'm wondering if this exhaust can be installed on a turboed car? Do most of the turbo kits leave the connection placement in the stock position? I'm trying to decide on which turbo kit, and which exhaust to run. |
#146 | |
Kirill RallySportDirect.com |
#147 |
Slack Bum
Hi RallySportDirect,
Will this exhaust setup be too loud ? 1. 5Zigen Proracer Catless Header 2. Perrin overpipe and front pipe (hi flow catted) 3. tomei 60R |
#148 | |
![]() Kirill RallySportDirect.com |
| The Following User Says Thank You to RallySport Direct For This Useful Post: | Burn (08-14-2013) |
#149 | |
Slack Bum
#150 |
Hella Flush
Drives: 2013 SWP BRZ
i am wondering the type 80 is running 80mm piping and a canister exhaust, this should not be as loud as the NA 60 mm exhaust. I think this should sound amazing on my FA20 kit.
#151 |
Drives: 135i
#152 |
Slack Bum
#153 | |
Drives: 135i
I was reading the T1R 3" single exhaust, its still gaining hp and tq(maybe just not as much compare to smaller piping exhuast) as well, so only 0.15" more, I don't really see the different. but just me, I could be wrong. |
#154 |
Keep it in the right rpm range and you should be good to go if your tune is right. I'm N/A and considering the 80mm as well. The silencer would be excellent for road trips. Maybe someone could do a with and without silencer dyno run. That would be cool. I remember awhile back they did it on a NA Miata. No loss in power at all with silencer. But on a turbo'd 240 it lost power with silencer. Of course an NA Miata on a dyno can barely hit 100whp. Of course there are other tests that show different results. I just wonder how loud it will be with 80mm piping. Hmmmm
Here's the Miata results here: http://www.importtuner.com/tech/impp...er_power_loss/ Here's another result from a Honda: http://honda-tech.com/showthread.php?t=2802991 |
| SINGLE EXIT EXHAUST | karma003 | Engine, Exhaust, Transmission | 163 | 06-28-2018 03:48 PM |
| 3" Single Exit Exhaust | Tansey86 | Engine, Exhaust, Transmission | 12 | 11-22-2012 08:49 AM |
| Full titanium single exit exhaust? | mufasis | Engine, Exhaust, Transmission | 15 | 11-12-2012 01:03 AM |
| Single exit diffuser poll | adprokid | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 11-08-2012 11:03 PM |
| Single exhaust exit on left or right? | Kuzuri | Engine, Exhaust, Transmission | 18 | 07-30-2012 04:53 AM |
