Old 09-19-2012, 08:23 PM   #141
subatoy
subatoy's Avatar
Drives: subatoy
Originally Posted by AllDayJonRay View Post
Love this kit for it's developers basing design on efficiency and not worrying about how 'sloppy' the kit looks with the turbo mounted at a slight angle!
Subscribed to here any further data regarding engine bay temps. Turbochargers can dramatically increase engine bay temps. I like to see if there are any adverse effects on due to the front mounted location.
efficiency huh? the most efficient way to oil a turbo is if it's straight.
what do you prefer a crooked one that meets the needs of the airflow of the freaking intake by and insignificant amount or keeping straight to ensure the best oil flow on the turbo?
The 5-10 or so degrees it would take to fix the angle wouldn't change ANYTHING in terms of performance. It's just the tube for the air filter.
subatoy is offline   Reply With Quote
Old 09-19-2012, 09:20 PM   #142
SnapOv3st3r
Drives: 400whp Scion tC
Originally Posted by VSGTS14 View Post
15 degree max. p&l look to have it in a pretty good position.
Full Blown's turbo setup isn't angled though and it's in the same spot. They went the opposite direction with their charge piping, allowing more room and clearance to position the turbo parallel.
SnapOv3st3r is offline   Reply With Quote
Old 09-20-2012, 01:05 AM   #143
AllDayJonRay
Drives: 2013 Ultramarine FR-S
Yes. Efficiency. The positioning on this kit looks like its around the 15* mark. I don't see that is a real detriment to turbocharger longevity.
IMO, the only reason to mount the turbo with the shaft parallel to the ground is aesthetic. And again, IMO, that's a compromise.
Plus, as John already pointed out, it looks badass.
I suspect there will be more issues with the elevated engine bay temps..
AllDayJonRay is offline   Reply With Quote
Old 09-20-2012, 10:28 AM   #144
VSGTS14
987 Motorsports
VSGTS14's Avatar
Drives: '13 WO FR-S
guys, i'm still trying to dig up that article. the turbo can be straight also. but it goes about saying that too much angle is bad.
VSGTS14 is offline   Reply With Quote
Old 09-20-2012, 10:55 AM   #145
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
There's a garrett writeup that says their turbos are fine at an angle. it warns against angles of more than 33. I posted a link to it a little while back. This is an old argument, and angled turbos are nothing new.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 09-20-2012, 11:02 AM   #146
kiks
Drives: V12
Angle on turbo is nothing compared to g forces.
1g of accel = 45deg. Be it lateral or longitudinal.
So much for being a wanker arguing about little angles.
kiks is offline   Reply With Quote
Old 09-20-2012, 11:22 AM   #147
Got3n
86-75309
Got3n's Avatar
Drives: Toyota FR-S
Man, this thread makes me happy, not sad I'm getting an automatic now :-)
Got3n is offline   Reply With Quote
Old 09-20-2012, 10:46 PM   #148
P&L Motorsports
P&L Motorsports's Avatar
Drives: '13 Turbo BRZ (AT) & '13 FRS
A quick video of we put together of our BRZ equipped with the P&L stg. 1 turbo kit!
[ame="http://www.youtube.com/watch?v=hvy5Rkl0lkk&feature=g-upl"]P&L MotorSports - 2013 BRZ / FR-S Stage 1 Turbo Kit - YouTube[/ame]
Thanks!
P&L Motorsports is offline   Reply With Quote
The Following User Says Thank You to P&L Motorsports For This Useful Post:
Lonewolf (09-20-2012)
Old 09-20-2012, 11:00 PM   #149
Klar
Drives: 2013 FR-S Whiteout
So the AT seems to be holding up well. No known issues as of yet?
Klar is offline   Reply With Quote
Old 09-20-2012, 11:02 PM   #150
P&L Motorsports
Do you really know how a turbos internal oiling system works?? Have you ever designed a turbo kit? Have you ever been to any turbo manufacturing training courses explaining their engineering / design process?
The turbo is angled 8 degrees for a couple of different reasons that I wont get into because you still wont like it anyway.
Obviously you don't like our design and you have made that very clear on multiple occasions, thank you for your concerns but we designed this kit with certain benefits in mind and having the turbo sit on a 8 degree angle is one of them.
Every kit we have designed for the past 7 years from our 2 record setting 8 second dragcars to our TA/AutoX dominating customer 100+ turbo'd Subarus have the turbo angled 8 degrees, why because it works.
Heck the worlds fastest BRZ by Accelerated performance (which we really respect) has the turbo at a 5 degree angle facing forward, is that wrong too?
OmarGC (09-22-2012)
Old 09-20-2012, 11:06 PM   #151
P&L Motorsports
Its not in the same spot! its 8 inches to the driverside. More room maybe? I sure would hate to be that nice cold air in that charge pipe that now travels right above that really hot downpipe right below it!
Old 09-20-2012, 11:09 PM   #152
SnapOv3st3r
I wasn't meaning "exactly" in the same spot. Exhaust wrap for the charge pipe, perhaps.
I do have some questions regarding the Auto trans.
What can you tell us as far as the behavior of the auto trans when shifting with the paddles in manual mode vs letting it shift by itself. Does it handle the new power ok if you leave it shifting by itself?
Also....1/4 mile run at the end...What's with the No Time posted?
Old 09-20-2012, 11:51 PM   #153
mact
Drives: 13 GTI
Looks like a lot of fun. Is that the iconic Subaru boxer rumble at the end of the 1/4 run?
mact is offline   Reply With Quote
Old 09-21-2012, 12:05 AM   #154
AllDayJonRay
P&L, I would still like to hear from the manufacturer (you) about your thought (and potentially concerns) regarding the turbocharger's location, considering the immense amount of heat it brings to engine bays. Thanks.
Dynosty Turbo FR-S FA20 Highest Horsepower Record 324WHP Hal@Dynosty Forced Induction 363 11-19-2014 11:03 AM
The Record, Cars section FR-S review muffinman Scion FR-S / Toyota 86 GT86 General Forum 0 07-01-2012 06:17 PM
Toyota captures Nurburgring EV record 1660 Other Vehicles & General Automotive Discussions 2 09-01-2011 04:05 AM
Toyota looks to set Nurburgring record for EV 1660 Other Vehicles & General Automotive Discussions 1 08-21-2011 11:34 AM
