Old 05-06-2015, 11:50 AM   #1513
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Seems easier just to keep the tank topped off.
Old 05-06-2015, 11:59 AM   #1514
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
That won't work if you get to the point @Jonsey has reached. I agree that as long as you are able to get a couple sessions in before fuel starving and you aren't in a competition like time attack or racing with a minimum weight, then it is far easier to keep the tank topped off.
The Following User Says Thank You to King Tut For This Useful Post:
ATL BRZ (05-06-2015)
Old 05-06-2015, 12:03 PM   #1515
gramicci101
Off Topic
How much fuel do you use in a 20 minute session? Would you be able to top it up between sessions and have no issues, or is this something where you start with a full tank and are having starvation issues by the end of the same session?
Never seen that. Generally it is mounted inside the car or near the fuel tank under the car. For the BRZ, I would ditch the rear cushion and build a nice mount for it in the driver/rear seat area.
Is there any reason it would need to be physically close to the OEM tank? There's already a fuel line running from the OEM pump to the engine; it just seems easiest to access that line in the engine bay when it's no longer covered or tucked under stuff. I'm just speculating in the absence of data, mind.
Old 05-06-2015, 12:07 PM   #1516
ATL BRZ
ATL BRZ's Avatar
I typically use about 1/4 tank per session, so I don't have issues for a full session after topping off.
Never starved at Road Atlanta or Barber even dipping below 1/2 tank. AMS and AMP are where it has happened so far and only recently.
Old 05-06-2015, 12:15 PM   #1517
gramicci101
Off Topic
And even then only when it's below 1/2 tank?
Yeah, seems like it would be easier and cheaper just to top it off between sessions. It's just not as #racecar.
Old 05-06-2015, 12:21 PM   #1518
ATL BRZ
ATL BRZ's Avatar
Starved at AMS below 1/2 tank only on the banking and at AMP below 3/4 tank on the carousel in T14-15.
Old 05-06-2015, 12:56 PM   #1519
gramicci101
Off Topic
@Element Tuning saw similar activity on hard left turns followed by long right sweepers. Note the racing slicks that would allow for even more lateral g's.
http://www.ft86club.com/forums/showthread.php?t=2742
Originally Posted by Element Tuning View Post
Saddle tanks are a problem in the newer STis because there is only one fuel pump and then a siphon system on the other side. Now even without the saddle tanks the older STis have fuel starvation issues below half tank (if you're fast on the track).
The FRS has been really good for me while racing but I did pick up some fuel starvation around half a tank in a hard left turn followed by a long right sweeper (on racing slicks). We fix the STis by using two fuel pumps but I need to look more into the FRS system to see if it's similar to the STi where the surge tank on the passenger side is feed by the siphon on the driver's side.
It seems like the pump is on the driver's side, so a hard left turn will slosh all your fuel to the passenger side of the saddle and away from the pump. You'd think the left turn banking at AMS would help keep fuel on the driver's side (downward side), but I guess the g-forces are enough to overcome that. Maybe Element has come up with a way to install an additional pump on the passenger's side to correct that issue.
Old 05-06-2015, 01:44 PM   #1520
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Another option that the S2000 guys are excited about is the Holley HydraMat. Supposedly they are going to be releasing a version the size of a normal pump filter that you can just snap on the end of your fuel pump to help with starvation.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
gramicci101 (05-06-2015), Rosticles (05-06-2015)
Old 05-06-2015, 11:43 PM   #1521
ATL BRZ
ATL BRZ's Avatar
Farewell to my RE-11As. They put up with over a year of track abuse before heat cycling out and wearing down past the wear bars.
Street mode engaged
Looking forward to some much stickier rubber in the future!
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
Hyper4mance2k (07-29-2015), Teseo (05-22-2015)
Old 05-07-2015, 01:05 PM   #1522
Chazzzy
Drives: TBD
Street mode engaged
Chazzzy is offline   Reply With Quote
The Following User Says Thank You to Chazzzy For This Useful Post:
ATL BRZ (05-07-2015)
Old 05-16-2015, 08:42 PM   #1523
Cop
Cop's Avatar
Drives: 2013 FRS
Awesome build, loving what you're doing with the car
Cop is offline   Reply With Quote
The Following User Says Thank You to Cop For This Useful Post:
ATL BRZ (05-18-2015)
Old 05-18-2015, 05:01 PM   #1524
ATL BRZ
ATL BRZ's Avatar
Old 05-21-2015, 01:05 AM   #1525
Lawn_Mower
Lawn_Mower's Avatar
Drives: GTI, BRZ
I've been reading that they wear VERY quickly but I don't understand how they get a 200 treadwear rating?!?
I'm sure you're aware, but tread wear ratings are practically completely arbitrary, and not as cut and dry as you'd expect them to be. A manufacturer can basically put whatever wear rating they want (exaggerating a little) on a tire to position it for a certain market .
http://www.tirerack.com/tires/tirete....jsp?techid=48
Lawn_Mower is offline   Reply With Quote
The Following 2 Users Say Thank You to Lawn_Mower For This Useful Post:
ATL BRZ (05-21-2015), Tristor (03-02-2018)
Old 05-23-2015, 06:33 PM   #1526
ATL BRZ
ATL BRZ's Avatar
Put down 205whp on DBW Motorsports' Mustang Dyno today.
Very pleased with the torque curve!
D_Thissen (05-24-2015), Tristor (03-02-2018)
jdl turbo, mazworx, racecomp engineering, track build, verus engineering
Wnt3d's 86 - Turbo E85 Daily/Track Build wnt3d Member's Car Journals 77 07-17-2017 03:35 PM
No Limit Motorsport Full Blown BRZ Build No Limit Motorsport Member's Car Journals 16 07-08-2014 12:46 PM
