04-15-2015, 11:34 AM | #1513 |
So elite I'm 1338
Drives: WRB Subaru BRZ
@Scoobysouth
Thinking about getting solostorm. Did you purchase the GPS dongle? or just the software? And how are the 3.5 lithium for DD use?
-Jack Burton |
04-15-2015, 11:46 AM | #1514 |
Drives: 2017 BRZ
You'll probably want a GPS dongle if you're using a phone or tablet, not discreet hardware; 1hz update rate doesn't cut it and some phones are slower.
The Following User Says Thank You to cjd For This Useful Post: | tahdizzle (04-15-2015) |
04-15-2015, 12:26 PM | #1515 | ||
Conedancer
Drives: 2013 Subaru BRZ SWP
Bill
STX #68 Join my BRZ/FRS FB Group Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
The Following User Says Thank You to Scooby South For This Useful Post: | tahdizzle (04-15-2015) |
04-16-2015, 12:14 PM | #1516 |
Drives: 2014 DGM BRZ & 2015 WRB WRX
With the rs*r rear lower control arms, am I allowed to use the additional mounting holes for lowered setting and harder settings, or do I have to mount in factory locations?
04-16-2015, 03:03 PM | #1517 | |
Conedancer
Bill
The Following User Says Thank You to Scooby South For This Useful Post: | TallTerror13 (04-16-2015) |
04-21-2015, 01:34 PM | #1518 |
Drives: 13 BRZ WRB
I am not sure I agree with that interpretation. That would be a change in suspension geometry. You are supposed to from my reading use the holes that are in the factory location.
04-21-2015, 01:36 PM | #1519 |
Drives: Whiteout FRS- autocross ready
I agree, that would fall under the rule that you cannot change the suspension geometry from factory locations.
04-21-2015, 02:25 PM | #1520 | |
This is the actual rule.
I guess the main benefit would be to lower the car while keeping suspension travel. I got the Raceseng upper mounts for the same reason. |
The Following User Says Thank You to xwd For This Useful Post: | TallTerror13 (04-21-2015) |
04-21-2015, 02:41 PM | #1521 |
Drives: 13 BRZ WRB
Yes, it is vague. This segment "Intermediate mounting points (e.g., shock/spring mounts) may not be moved or relocated on the arm." of that specifically disallows use of holes on the arms that are not in the factory location. Just my opinion though.
I would suggest if you want and official response write a letter. |
04-21-2015, 03:30 PM | #1522 | |
04-21-2015, 04:29 PM | #1523 | |
Conedancer
Bill
04-21-2015, 07:21 PM | #1524 | |
Ah I didn't notice the RS*R arms had different locations for both the struts, swaybar, and knuckle. I think having the knuckle mounting point would be legal, but not the other two. |
04-24-2015, 10:52 AM | #1525 |
Drives: '14 BRZ
04-24-2015, 11:02 AM | #1526 |
Every cv joint I've ever had fail was preempted by these clicking noises
Similar Threads | ||||
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
