Old 04-15-2015, 12:34 PM   #1513
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
@Scoobysouth
Thinking about getting solostorm. Did you purchase the GPS dongle? or just the software?
And how are the 3.5 lithium for DD use?
-Jack Burton
Old 04-15-2015, 12:46 PM   #1514
cjd
cjd's Avatar
Drives: 2017 BRZ
You'll probably want a GPS dongle if you're using a phone or tablet, not discreet hardware; 1hz update rate doesn't cut it and some phones are slower.
The Following User Says Thank You to cjd For This Useful Post:
tahdizzle (04-15-2015)
Old 04-15-2015, 01:26 PM   #1515
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Originally Posted by tahdizzle View Post
@Scoobysouth
Yes.. I have the 10khz GPS Dongle for the faster updates.. works awesome, I also have a BT OBD2 reader that integrates nicely with everything.. that way it gives you all you pertinent input data as well.. Throttle, Brakes, Steering angle, G-force and integrates nicely with everything so you get a complete picture. .been using solostorm for the last 2 years.. Provides awesome Data capture and pretty easy to setup and analyze..for the most part. Highly recommended for Autocross... has a Pro feature and normal Autocross .. hope that helps you.. I run it on a Galaxy tab 2..
Absolutely agree 100%
Bill
Scooby South is offline   Reply With Quote
The Following User Says Thank You to Scooby South For This Useful Post:
Old 04-16-2015, 01:14 PM   #1516
TallTerror13
TallTerror13's Avatar
Drives: 2014 DGM BRZ & 2015 WRB WRX
With the rs*r rear lower control arms, am I allowed to use the additional mounting holes for lowered setting and harder settings, or do I have to mount in factory locations?
TallTerror13 is offline   Reply With Quote
Old 04-16-2015, 04:03 PM   #1517
Scooby South
Conedancer
You can use whichever holes you want .. not limited on 'just' the factory holes.. Whitelines have additional holes as well. The only requirement is that they have the Rubber bushings vs the heim jounts. Length, adjustment is all open..
Bill
TallTerror13 (04-16-2015)
Old 04-21-2015, 02:34 PM   #1518
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
I am not sure I agree with that interpretation. That would be a change in suspension geometry. You are supposed to from my reading use the holes that are in the factory location.
2superblus is offline   Reply With Quote
Old 04-21-2015, 02:36 PM   #1519
MTCRX
MTCRX's Avatar
Drives: Whiteout FRS- autocross ready
I agree, that would fall under the rule that you cannot change the suspension geometry from factory locations.
MTCRX is offline   Reply With Quote
Old 04-21-2015, 03:25 PM   #1520
xwd
This is the actual rule.
The replacement arms or mounts must attach to the original standard mounting points. All bushings must meet the requirements of Section 14.8.B. Intermediate mounting points (e.g., shock/spring mounts) may not be moved or relocated on the arm.
It's pretty vague so I'm not sure it actually disallows it. Usually by standard mounting point they are talking about another piece which can't be replaced. They also give no guidance on the shape of the arm... So even though they say you can't move the shock mounting point there is nothing that says it can't be C-shaped like the Stance arm.
I guess the main benefit would be to lower the car while keeping suspension travel. I got the Raceseng upper mounts for the same reason.
The Following User Says Thank You to xwd For This Useful Post:
TallTerror13 (04-21-2015)
Old 04-21-2015, 03:41 PM   #1521
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
Yes, it is vague. This segment "Intermediate mounting points (e.g., shock/spring mounts) may not be moved or relocated on the arm." of that specifically disallows use of holes on the arms that are not in the factory location. Just my opinion though.
I would suggest if you want and official response write a letter.
Old 04-21-2015, 04:30 PM   #1522
MTCRX
MTCRX's Avatar
I agree with this interpretation. THe arm can be shaped differently but the holes for mounting points have to be in the same location as the stock arm.
Old 04-21-2015, 05:29 PM   #1523
Scooby South
Conedancer
hmmm I was under the impression you could use whichever.. but you are probably right..
Bill
Old 04-21-2015, 08:21 PM   #1524
xwd
Ah I didn't notice the RS*R arms had different locations for both the struts, swaybar, and knuckle. I think having the knuckle mounting point would be legal, but not the other two.
Old 04-24-2015, 11:52 AM   #1525
conedodging
conedodging's Avatar
Drives: '14 BRZ
Originally Posted by vroom4 View Post
After 500 or so runs in CSR and stx, I finally hear the click every start and stop.
Wonder how long until kaboom
What's that indicative of?
conedodging is offline   Reply With Quote
Old 04-24-2015, 12:02 PM   #1526
vroom4
Every cv joint I've ever had fail was preempted by these clicking noises
vroom4 is offline   Reply With Quote
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 07:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 02:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 12:02 PM
