Old 03-18-2014, 06:38 PM   #1499
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
The accelerator pedal takes time to learn any time it loses power. Ideally you would push it a few times to WOT with the car in the on position but engine off. Over time you WOT will start to register higher and higher, but my understanding is, anything over like 94% (I can't remember the exact value) is WOT.
Luckrider is offline   Reply With Quote
Old 03-18-2014, 06:41 PM   #1500
Kodename47
Kodename47's Avatar
Drives: UK GT86
If you're worried, then just look at the throttle angle. FYI, that doesn't show as 100% either though and seems to taper down on OFT.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-18-2014, 06:55 PM   #1501
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by Walla Walla View Post
anyone able to understand if this log is good or bad?
i'm still trying to understand datalogging, any imput would be great
http://datazap.me/u/walla-walla/brz-...g=0&data=1-8-9
OFT stage 2, with 91 oct
It's a bit on the rich side and i see the ECU trying to pull out fuel (LTFT pegged at -3.9%). Since you don't have any intake mods, I'm guessing this may have something to do with the fuel formulation in Canada. Still perfectly within reason though so you can either leave it as is or lean it out slightly in the primary fuel map. Timing and throttle) look spot on. It's normal to see throttle peak at 95-100% and then taper off to 90%. This is the actual throttle blade angle. Not to be confused with accelerator pedal position (which is also log-able now since the last OFT update). Engine load does seem pretty high for an NA car though.
Shiv
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Walla Walla (03-18-2014)
Old 03-18-2014, 07:03 PM   #1502
nelsmar
i'll post again, since i think it just passed free, with so many topics in 1 thread
here it is
3rd gear pull
http://datazap.me/u/walla-walla/3rd-...g=0&data=1-8-9
UEL Open Flash Header is the only mod (only other thing I did was to remove the sound tube but i really don't think it change something..?)
note that I had the accel down on the floor the whole time.. it's weird that it is not shown as 100% (could not go higher than 96%..?)
@shiv@vishnu @nelsmar
Intake is completely stock? What was ambient temperature and elevation i am quite curious...
Also A01c?
Looks like there may be some FLKC (very minor) at the 6-7k range. AFR is "close" to target after trims have gone in but looks like its over shot and giving a false reading of load. Your actually reading load over the edge of the map. Tell me which rom you are on and I can send you something to test real quick. I am going to assume your fuel does not have ethanol in it correct? I can send you a rom back with MAF scale adjustment and LTFT turned off for two quick pulls and then you can turn them back on. Once the maf is adjusted the ignition might have to be pulled a hair in that 6k range if it is FLKC as it looks like it was pulling just roughly -.7 degree from what im guessing it should be. You can see in the knock correction learn value plot that it "dips" down and recovers yet the actual ignition advance table is fairly smooth.
My flickr - Canibeat
Local magazine scout
The Following User Says Thank You to nelsmar For This Useful Post:
Old 03-18-2014, 07:27 PM   #1503
Walla Walla
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
Shiv
thanks for the quick feedback! since I don't know shit about tuning, I really wanted to be sure my engine was safe!
i kind of understood it looked rich, but I wouldn't be comfortable to play with map myself!
Also A01c?
the gas is from Shell, so no ethanol (but they do say on the pump it contain azote...?)
temp was like around -2C to 2C. completely stock intake. elevation 322 feet in quebec city.
i dont really understand everything you explain, but if you want me to test something, it would be my pleasure!
i'm running on Stg2 UEL 900C.bin
Walla Walla is offline   Reply With Quote
Old 03-18-2014, 07:36 PM   #1504
Kodename47
Kodename47's Avatar
Drives: UK GT86
@Walla Walla it might be worth using Romraider to look at the maps. Use the open ROMs as a chance to learn what the maps are doing. If you Google a lot of the info you can learn a lot. I've gone from knowing nothing to having learnt how to do a tune, having reference maps to see what changes have been made is a great benefit.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
Old 03-18-2014, 07:37 PM   #1505
frsqc
Drives: raven FRS
walla walla, did you try 94 oct from petro???
RAVEN FRS 2013 - TRD air filter - Nameless OP/DP - Greddy EVO3 - STAGE 2 OFT/OFH -
frsqc is offline   Reply With Quote
Old 03-18-2014, 07:39 PM   #1506
Shiv@Openflash
Drives: 2013 FRS
The tune is completely safe. If you want to get custom tuned from this point out, we do offer e-tuning services. But in all honesty, you may only be looking at picking up 5-8whp by running a little bit leaner and by seeing how far we can push timing. It may or may not be worth it to you
Cheers,
Shiv
Old 03-18-2014, 08:03 PM   #1507
Walla Walla
Hicas Thread Basher
Cheers,
Shiv
Thanks!
for now I will be ok, but I'm waiting to see what will get out of the third party review for the "Crawford Billet Power Blocks"
then, maybe I will be going for some e-tuning services!
no, I tried once, and with all the negative feedback I read about it, I decided to stick with shell
The Following User Says Thank You to Walla Walla For This Useful Post:
Luckrider (03-18-2014)
Old 03-18-2014, 08:04 PM   #1508
Shiv@Openflash
Drives: 2013 FRS
Thanks!
I think sticking with Shell was a good choice
We will be testing the Crawford BPB soon as well!
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
Luckrider (03-18-2014), Walla Walla (03-18-2014)
Old 03-18-2014, 08:14 PM   #1509
Luckrider
Luckrider's Avatar
Does this mean if it works out well, we could see a polymer based unit that is way cheaper and works well for NA or Phantomcharger cars?
Old 03-18-2014, 08:16 PM   #1510
Sniper2606
Sniper2606's Avatar
Just for research sake, heres my 3rd gear pull on sc kit.
http://datazap.me/u/sniper2606/3rd-g...l?log=0&data=1
91 gas on 93 map
Vortech
UEL headers
Test pipe
Overpipe
Q300
Sniper2606 is offline   Reply With Quote
Old 03-18-2014, 08:23 PM   #1511
nelsmar
91 gas on 93 map
Vortech
UEL headers
Test pipe
Overpipe
Q300
Pretty rich, and a bit of knock up top starting @ 6k Your ecu is pulling a good 3 degree's timing. I would offer to modify that earlier posted ROM but thats probably something best left to shiv. You should be seeing a flat 3.16* timing under all higher load conditions.
Old 03-18-2014, 08:24 PM   #1512
nelsmar
Mind you that is if the rom posted earlier is what you are running.
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 02:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 01:39 PM
