Old 07-06-2023, 08:50 PM   #1499
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Kaotic Lazagna View Post
I think my Genesis time is still gold.
I stopped looking at the Genesis time since I don't want to know. I had to redo it twice already to get back into gold.
Old 07-07-2023, 04:04 PM   #1500
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Im so confused. Trying to put together a Fanatec bundle. The Bases are CSL DD, either the 5nm or 8nm which is basically just the adapter. But they're not compatible with PS5? Does the support come from the wheel or the base? Because there are multiple wheels compatible with PS5.
Old 07-07-2023, 04:35 PM   #1501
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
My understanding is the bases are the same and it is the wheel that is different. I used my GT7 CSL DD with an Xbox/PC specific wheel with my Xbox One before I got my PS5. Not worth getting the boost kit with GT7. You can always buy it later.
Old 07-07-2023, 04:44 PM   #1502
spcmafia
spcmafia's Avatar
Other platforms: Compatibility with other platforms depends on the used steering wheel. For more information, please check the product page of the steering wheel you plan to use.
Found this. So all this time Im trying to setup a really expensive bundle when I could've gotten much cheaper because at the end of the day, is all about the wheel. Fanatec does not test on PS5, but on PC, Im guessing they don't because of whatever deal they got or licensing.
The Following User Says Thank You to spcmafia For This Useful Post:
NoHaveMSG (07-07-2023)
Old 07-07-2023, 04:47 PM   #1503
Kaotic Lazagna
Drives: GR Corolla
What about the GT DD since it is supposedly specifically designed for Gran Turismo?
Old 07-07-2023, 04:49 PM   #1504
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
for the Brands Hatch and Watkins Glenn TTs I got very close to Gold. But in both situations I just didn't have enough time to push over that threshold. Silver for both.
Valkyrie at RBR though, forget it. Struggled to get Silver.
The weird characteristic you mentioned for the Valkyrie is traction related. In 3rd gear the tires are still spinning. For some reason it's harder to notice (than in 2nd gear) so if you shift at redline in 3rd while the tires are spinning you'll be way down in the rev range when 4th engages.
I'm worried that the Valkyrie is going to pop up in most of the Hypercar races. The fun of those races were already questionable given the Vulcan and 918 Spider blew everything else away. Toss in the Valkyrie, which is an order of magnitude faster than the aforementioned cars, and it'll be worse.
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R
WolfpackS2k is offline   Reply With Quote
Old 07-07-2023, 04:50 PM   #1505
spcmafia
spcmafia's Avatar
Because I wanted a three pedal setup, so I went into a rabbit hole trying to customize and it kept saying the wheel base was not compatible. Then I would look at the GT DD, and the wheel base is exactly the same across the board, just with the fancy steering wheel licensed for Gran Turismo, hence why it is compatible with PS.
Old 07-07-2023, 04:56 PM   #1506
Kaotic Lazagna
Drives: GR Corolla
I do remember it being confusing when I was originally looking at them, and it was before the GT DD was announced. lol
Old 07-07-2023, 04:59 PM   #1507
Kaotic Lazagna
Drives: GR Corolla
I think for the Valkyrie, I skipped 2nd and 3rd gears a lot, and just used the passing button to make up. Pretty hard to modulate the throttle to not just spin the tires.
The Following User Says Thank You to Kaotic Lazagna For This Useful Post:
Old 07-07-2023, 05:15 PM   #1508
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah it is super annoying. I just hang into it until it bangs limiter, otherwise I accidently upshift too early.
I was doing this for a while but I noticed it was faster to just go ahead and stay in the lower gear. I just said screw it and ran TC at 1. I got down to like a 19.2, I just struggle so much coming out of turn 3, I am losing a ton of time there.
Old 07-07-2023, 05:45 PM   #1509
Kaotic Lazagna
Drives: GR Corolla
I don't remember what my time is. lol. For the slower corners, I skipped gears. I remember a corner or two where I would be on the top half of third, so for those, I just tried modulating the throttle to not spin the tires. I did more laps than I wanted to for this TA because I was testing out skipping gears or not. I'm not a big fan of the Valkyrie, especially its braking. I don't know if they're too good (so ABS activates too often), or not good enough for the car. So on top of out of corner traction issues, I don't find it fun to drive.
Old 07-07-2023, 06:29 PM   #1510
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Corners like turn 1 I was doing in 3rd but found 2nd was so much quicker. I usually try to leave it in a higher gear to control the power a bit easier but my hand gets tired trying to reach over and hold the overtake button all the time
Old 07-07-2023, 06:33 PM   #1511
Kaotic Lazagna
Drives: GR Corolla
That's definitely where the controller as an advantage, the overtake button. Although if I press the right stick at even the slightest angle, it moves the camera. LOL
Old 07-07-2023, 06:43 PM   #1512
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I bound right stick button to horn instead.
Originally Posted by humfrz
I'm old and lazy
gran turismo, gran turismo 7
Gran Turismo 5 GT Off-Topic Lounge [WARNING: NO POLITICS] 24 06-16-2019 06:53 AM
FT-86 in Gran Turismo 5 AaronCompNetSys Scion FR-S / Toyota 86 GT86 General Forum 207 01-21-2014 11:32 AM
Gran Turismo 5 Thread SuperGTS Off-Topic Lounge [WARNING: NO POLITICS] 7 10-30-2013 02:14 AM
Gran Turismo 6 - Box Art!! RevoG Scion FR-S / Toyota 86 GT86 General Forum 26 05-15-2013 12:53 AM
Gran Turismo 5 JLMtm Scion FR-S / Toyota 86 GT86 General Forum 3 11-03-2012 05:06 AM
