#1471 |
Drives: Subaru
At Laloosh defense, I ran there that day as well. The lot was just resealed that week and the pavement was harsh. Because the lot was just resealed that week and not yet cured, I wouldn't necessarily say that the data would be that useful. Just my 0.02 cents though.
I personally was having a ton of issues with understeer and push. Laloosh drove very well that day considering that his car is not fully prepped yet. There's always gonna be more time out there though. It's just a matter of finding it. I do have a question for you CS guys though. After the most recent event, my car felt absolutely atrocious (pushed like a pig). I think I'm running too big of a front bar (whiteline 22mm adjustable on full soft). Been thinking about changing to 20mm whiteline adjustable. Anybody here have experience with that bar and how did it feel? Thanks for the input in advance! |
#1472 |
I dont think you should go changing your car based on one event. Where did it push at? Corner entry, mid corner, or exit.
The trick that helped me was completely unhooking the front bar (or in my case snapping it) and see how the car handles. Then you will really know what the bar does. |
#1473 | |
Drives: Subaru
I'm still learning and need to get faster but I feel that general consensus is controlled oversteer is quicker. I've been debating going to a smaller bar for a while. Just really confused on what to do after that one event. |
#1474 | |
Lost in Kansas
Drives: 2013 Scion FRS (Raven)
Second, I run the Whiteline 20mm bar on full soft and I still think it is a bit too stiff. One of the things I didn't like about it, and I am sure the 22mm could have the same problem, is that the bar didn't come very symmetrical. It appears to be a problem with a lot of bars and I am not sure it really affects anythings as long as you adjust the end links with the full weight on the car. |
#1475 | |
Drives: Subaru
#1476 |
I have the 22mm Whiteline bar too, and I think it was just a bit too big when I was on race tires. Now that I'm on street tires I definitely want to try a smaller bar. I doubt I'll go with Whiteline again, though.
#1477 |
Lost in Kansas
#1478 |
Every single setup I tried, F33 and F43 would lead to disaster oversteer. i think youve got an issue somewhere else as it would suprise me if the front bar could be THAT much too stuff. Go back to OEM before you decide which new bar to order.
#1479 |
Drives: Yes
Wow, this blew up. Everyone must be antsy and just killing time at work this week before Lincoln. I'll be there Sunday night with my beer, and I'm anxious to see the data on how well people like some Natty Boh.
Safe travels and see you all on the practice course Monday! |
#1480 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
This bar- http://www.revworksinc.com/Hotchkis-...R-S_p_672.html
It's 170% stiffer on soft than stock, Strano's is 85%. And it's not one of those crap Japanese manufacturer calling 70% as 170%, it's a legit increase of 170%. It's meant to be paired with their rear bar. I have it still with VERY little usage on it, if someone wants it cheap at Lincoln. Here's my ancient FS thread on it, I didn't push it very hard haha http://www.ft86club.com/forums/showthread.php?t=30420
#1481 | |
Dodging cones
#1482 |
Just the sentiment that the 20mm Whiteline bar is still too stiff more than anything.
I have had a pretty miserable experience with the 22mm bar - clunking that I've spent probably 30 hours to date trying to resolve, and have multiple times, but it keeps coming back for a different reason. But I don't have any delusions that another brand will be any better. Just crossing my fingers. I think I'll probably go with Strano. More on my struggle here.. I have a clunk AGAIN, but it may be a loose plastic undertray or my exhaust. Sigh. http://www.ft86club.com/forums/showt...07#post1786807
#1483 | |
Lost in Kansas
#1484 | |
The dumbest thing I found was just a loose nut on the sway bar side of the endlink, a sound you can probably imagine. The sad part is pretty much every other issue has sounded exactly the same. Edit: Maybe worth nothing, the Whiteline bar is "inside-out" so you have to use aftermarket endlinks. I think, anyway. It's been a few days since I've looked at it.
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 06:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 01:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 09:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 02:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 11:03 AM |
