Old 03-18-2015, 12:23 PM   #1443
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by aquaman View Post
Anyone that did the install themselves; how long did it take you, start to finish?
It took me and a relative about a week, mostly because it was our first ever turbocharger. Install was quite difficult for us but we got it
Astroboy is offline   Reply With Quote
Old 03-18-2015, 01:20 PM   #1444
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Mmm... that is a pretty sweet package deal right there. Would be nice if existing buyers could get a discounted rate on that breather tank set up mmmmmmm AVO?
Mine came in yesterday and i sifted through the boxes and there was a BOV and Breather tank.
-Jon
Originally Posted by AVOturboworld View Post
Note:This is not an AVO turbo world quote. I have no idea how to do shout outs and it never works so I am changing a quote so they get a notification...
Old 03-20-2015, 11:13 AM   #1445
kbogarto
Drives: 2013 BRZ limited WRB
what did you need to get?
Parmatex gasket sealant
Drill bit for drilling larger hole for the windshield wiper fluid tank
River-nut gun
Fitting to connect BOV hose into brake booster line.
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
kbogarto is offline   Reply With Quote
Old 03-23-2015, 10:08 AM   #1446
aquaman
aquaman's Avatar
thanks. "T" fitting? what size?
aquaman is offline   Reply With Quote
Old 03-23-2015, 01:02 PM   #1447
kbogarto
The brake booster line is larger than the BOV line so makes for a harder to find T fitting. I can't remember the sizes but I think the BOV hose was 6mm and the brake booster slightly bigger. I ended up buying a T fitting that you could screw in different fittings and bought the fittings for the size I needed. I'm at work now but I'll try and post a picture when I get home.
Old 03-26-2015, 07:37 PM   #1448
aquaman
aquaman's Avatar
Originally Posted by protpibe View Post
-Use 2 crush washers and high temp thread sealant on the oil pickup line (on top of the pass side of the engine)
-Be very careful with torquing the header on (27ft lbs I believe. Confirm first), and also make sure you torque it similarly to a wheel (one bolt per side at a time)
-Use hairspray to lubricate the intercooler piping when sliding it in to the silicone piping
-Get a rivnut tool to bolt the intercooler on
-take your time with the oil scavenging pipe install. it can get messy if you don't
Everything else is as described in the instructions.
what size crush washers did you need?
Old 03-27-2015, 01:39 PM   #1449
protpibe
protpibe's Avatar
Whichever one fit lol.
Sorry, I didn't measure, I just had a bunch on hand and grabbed what fit.
Old 03-27-2015, 01:55 PM   #1450
robr
Drives: 2013 FRS, with boost by ATS Racing
Pretty sure they are 1/2".
robr is offline   Reply With Quote
Old 03-31-2015, 09:07 AM   #1451
JustBoostin
Drives: Asphalt FR-S 6MT
I just used the stock washer from that spot, and added the crush washer, and it worked beautifully!
Also, does anyone have the avo street breather tank AND a Mishimoto oil cooler? The part that replaces the oil cap won't thread on because it's hitting the sandwich plate. Thoughts on a remedy?
JustBoostin is offline   Reply With Quote
Old 04-06-2015, 08:10 AM   #1452
aquaman
aquaman's Avatar
Turbo is in and running great! Some things I over looked durring install, I put the intercooler on backwards. The smaller opening is the inlet... hence a boost leak when I was done. there is a small L shaped pipe under the intake, make sure that doesn't come off when removing the water hose. if it does, you might have to take the intake off to get to it (I had to but that might just be to find where it was). the last thing was the piping for the oil catch can. one line runs to a "T" coupler. one end goes from the can to an upgraded PCV and the other goes to the back of your intake and has a one was valve (preventing oil going into your intake). the second line goes to your inlet pipe. it is coupled with another pipe to make it long enough. and the last goes to the origional tube that was connected to the intake. I also had to make a connection into the brake master cylinder vacume line with home made connector because it didn't come with one. I hope this helps someone.
Old 04-09-2015, 11:53 PM   #1453
Skorov
Skorov's Avatar
Drives: 86 GTS White
I'm soon replacing the AVO breather tank with a Radium Dual Can setup and need the knowledge of someone smarter than I am before proceeding with the install.
The block fitting that is supplied with the AVO kit - Is this the PCV valve or simply a fitting?
The AVO valve that is inserted into the PCV hose - Is thiis the PCV valve or a check valve for one directional airflow?
Should I reinstall the stock PCV Valve before installing the Radium kit?
What is the ID of the AVO hose connected to the AVO block fitting?
Many thanks!
Skorov is offline   Reply With Quote
Old 04-10-2015, 12:01 PM   #1454
GremlinGSP
The block fitting was just a fitting the PCV valve was seperate (My fitting didn't fit and i had to source an alternative)
I believe that's the PCV valve.
If your turbo I'd keep the AVO PCV it got upgraded for Turbo pressures.
Didn't use the AVO fitting to I can't say on last one.
GremlinGSP is offline   Reply With Quote
Old 04-10-2015, 08:21 PM   #1455
Skorov
Skorov's Avatar
Thanks man! I was thinking I would just reinstall the stock PCV valve and use a check valve between the manifold and catch can to stop from pressurising the crank case.
So flow would go like this:
Crank Case -> stock PCV valve -> Catch can -> Check valve -> manifold
Will this work? Remember, I'll have another catch can for the breather hose.
Old 04-24-2015, 12:03 AM   #1456
protpibe
protpibe's Avatar
AVO Turbo Kit Owners Topic
I finally sorted out a fuel issue that was hanging over my head last year, so I put my car on the dyno to see what kind of power it's making. I ended up running 305whp at 13psi
I also ran 285whp on wastegate pressure 10psi with the full Avo 3" catless exhaust into a Perrin 3" non resonated
For reference, the other line on the chart was from last spring. 10psi (Before the fuel issues) but with the standard 2.5" exhaust setup. Obviously there could be some discrepancies in ambient temp etc, but there are definitely benefits to opening up the exhaust from the downpipe back
avo, avoturboworld
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
