#1415 | |
Drives: Toyota GT86
#1416 |
Drives: 2016 Raven FRS
I recently tuned my car with the OFT to get most benfits from my UEL tomei headers.
I've been doing datalogging as im using Canadian fuel. I'm using chevron 94 for the stg 2 UEL 91 ROM. http://datazap.me/u/refriedspinach/l...data=1-5-12-14 Here's the first run, which includes the ECU learning. http://datazap.me/u/refriedspinach/log-1470805319?log=0&data=5-10-11-12-14 Here's my run form the end of day yesterday, about 20 mins after tuning to stage 2 and steadily cruising around. -Is the FLKC supposed to be going crazy into +/- 100 like that? -The Advance Multiplier(Is this IAM?) is staying at 0, and didn't move the full trip. -knock correction didn't move the full trip either @Boomerang Mentioned that with a ZA1JF40C CAL ID (I'm driving a 2016 MT) the OFT cant log some parameters properly. Is this the case? I've tried searching everywhere but couldnt really find an answer to questions I have. |
#1417 |
Drives: '13 BRZ
To start this off, I am very new to the tuning world so please go easy on me. I'm learning as I go on.
So I did a data log with my OFT of a 3rd gear pull yesterday from 2000rpm to redline. http://datazap.me/u/tinma/log-147093...-9-10-11-12-13 I added the alarms that are on the OFT Tips & Tricks page and every so often these following alarms go off. I would also like to add that I seem to have backfire every so often coming out of 1st gear. Alert B ( knock alert & Fuel Trim alert) For E85 suggest -1 for Petrol may -2 FLKC < -1 Knock Correction < -1 IAM < 0.9 LTFT > +10 LTFT < -10 Alert C running lean alert you might have to tweak AFR for petrol/E85 try 13 for E85 12.5 Petrol RPM > 5000 Engine Load > 1 AFR > 13 Select AND at bottom of screen I dont think the 3rd gear pull log will give me much info on this issue, but I feel like its a step in the right direction. If someone could give me a hand with this, I would greatly appreciate it! @steve99 or @Wayno if you have any input on this? Running on 91oct stage 2 OFT tune with UEL header and drop-in filter Last edited by tinma; 08-12-2016 at 12:51 PM. |
#1418 |
Drives: 86
I want to share my logs via datazap but the only thing i can see is "#encoding: utf8". I logged with ecutek and saved the .csv file to datazap.... can anybody help?
edit: http://datazap.me/u/denso/1?log=0&data=0&solo=0 |
#1419 |
Does the first line of your file have #encoding, and then the rest have all the parameters? If so, delete that line.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
#1420 |
Drives: 86
First and only line is encoding... I can only see the seconds. No parameters
#1421 | |
Drives: UK GT86
You want the top row to be the column headers. Recently ECUtek have added info into the top like OFT does.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | denso (08-11-2016) |
#1422 |
Drives: 86
#1423 | |
y flkc knock you have a bit round 4000-5000 in that log. the load limits not being set looks like your running pretty rich when you get on throttle at lower rpm this may cause the miss fire , it also running on the rich side wot at most rpm, wont hurst just costs you power. knock is not bad iam is still 1. |
| The Following User Says Thank You to steve99 For This Useful Post: | tinma (08-15-2016) |
#1424 | |
Drives: 2015 86 GTS
I strongly feel that Openflash should make this clear in the sales burb on their website so that you know what you are getting 😑. Feel free to send an e-mail to sales@openflash.com and raise the issue. More customers doing this will give them a sense of how many of us are affected. At some stage they might fix it 🤔. |
#1425 | |
Drives: '13 BRZ
I noticed you mention the Front Oxygen Sensor scaling in one post. http://www.ft86club.com/forums/showp...&postcount=371 Would changing my tables to the ones you posted help fix this issue? Thanks! |
#1426 | |
no rescaling front 02 sensor wont help you, it just allows the sensor to read richer values. you need some maf scaling correct load limits as in wayno's posts. and maybe a bit of smoothing of ignition timing, but best to get the fueling corrected first. its not real bad though so don't sweat on it, , a different brand of fuel may fix the minor knock issue. |
| The Following User Says Thank You to steve99 For This Useful Post: | tinma (08-16-2016) |
#1427 |
Drives: Toyota 86 GTS
Looks completely fine.
| The Following User Says Thank You to Wayno For This Useful Post: | fibble (08-18-2016) |
#1428 | |
IN latest version I've adjusted < 2.4 MAFV +5% (over stock) to better match AU E85. Should have zero affect on LTFT at WOT. |
| The Following User Says Thank You to Wayno For This Useful Post: | Boomerang (08-18-2016) |
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 01:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 09:27 AM |
