Old 02-19-2012, 04:19 PM   #1401
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
Originally Posted by fatoni View Post
from a performance standpoint the solid axle and 115mph driveshaft (which i have never heard before) are only disadvantages if the was was slower, which it isnt. a solid axle is lighter and reduces unsprung weight. ford has made this an advantage imo
1) http://jalopnik.com/5869650/why-do-2...keep-exploding
2) http://www.autoblog.com/2011/12/19/w...ails-at-135-m/
3) http://www.autoguide.com/auto-news/2...mph-video.html
You are right, it isn't really 115mph more like 140mph.
[u2b]-qWhxYElSW0[/u2b]
tranzformer is offline   Reply With Quote
Old 02-19-2012, 04:31 PM   #1402
fatoni
Originally Posted by tranzformer View Post
i wonder if they have addressed this yet. that last post wasnt sarcasm by the way. i had no idea
Old 02-19-2012, 04:37 PM   #1403
tranzformer
Drives: Zoom Zoom
I know you weren't being sarcastic; neither was I. I was just showing you a few links with info about the issue and a video. Just thought I would be helpful.
Old 02-19-2012, 05:20 PM   #1404
ZDan
ZDan's Avatar
Drives: '23 BRZ
Solid axle *greatly* INcreases unsprung weight. That's one of the major advantages of IRS. With a live axle, the entire rear axle assembly including the differential is unsprung mass. With IRS, the differential and half of the halfshaft weight, ~2/3 of the control arm weights are sprung mass.
The overall weight penalty for IRS is very small, often tremendously overstated. I think this might have to do with how much weight it added on the last-gen IRS Mustang Cobras. But that weight gain included an added-on subframe for mounting.
For a dedicated IRS design (as opposed to IRS added on to a car designed for a live axle), the real weight penalty isn't that big, if it exists at all.
On the Mustang Cobras, the additional required hardware made the IRS version 80 lb. heavier. But unsprung weight was reduced by 125 lb., according to this source, anyway:
http://www.mustangmonthly.com/featur...a/viewall.html
Here's a shot of the Mustang IRS:
[edit: no idea why I can't load this pic! Click on web address below or just search the interwebz for Mustang Cobra IRS images]
Note that the loads from the control arm mounts have to be beamed over to the existing hardpoints in the chassis for the live axle. VERY inefficient load path, resulting in a heavy subframe. With a dedicated IRS car, you'd simply have chassis hardpoints located right at the control arm pivots.
Source for pic also reports 125 lb. reduction in unsprung mass. Seems like a lot, but then a live axle is a heavy assembly...
http://www.miracerros.com/mustang/t_suspension2.htm
"Ford designed this IRS so that it attaches to the 1979-2004 Mustang's stock suspension mounting points. That somewhat compromised the performance of the IRS, but it means that the unit can be bolted into any late model Mustang chassis. The IRS subsystem is about 70 lbs. heavier than a solid rear axle, which contributes a better front/rear weight distribution, and it reduces the car's unsprung weight by about 125 lbs."
Old 02-19-2012, 05:41 PM   #1405
pastuch
pastuch's Avatar
Originally Posted by Deslock View Post
"FR-S/BRZ vs. Genesis Coupe, a narrative by SUB-FT86"
Sub-ft86 has contributed many useful posts to this thread and while I may not always agree with him he does stay on-topic unlike many of you.
pastuch is offline   Reply With Quote
Old 02-19-2012, 06:05 PM   #1406
fernan2
fernan2's Avatar
Drives: Wrx
+1
fernan2 is offline   Reply With Quote
Old 02-19-2012, 06:46 PM   #1407
SVTSHC
(ノಥ益ಥ)ノ
SVTSHC's Avatar
Drives: 2015 Series Blue BRZ
Agreed, although I also agree with him 99% of the time. (the 1% being the bit about the stang v6 propeller shaft speed load limit.)
SVTSHC is offline   Reply With Quote
Old 02-19-2012, 06:53 PM   #1408
tranzformer
Drives: Zoom Zoom
So what are your thoughts on the V6 Mustang driveshaft issues?
Old 02-19-2012, 09:06 PM   #1409
Tbxgz
Tbxgz's Avatar
Drives: 2013 BRZ Limited 6MT
wow gotta say the 3.8 has one hell of a rumble
[u2b]NpWgp1AsgRM[/u2b]
Tbxgz is offline   Reply With Quote
Old 02-19-2012, 09:27 PM   #1410
Exage
GL 86!
Exage's Avatar
Drives: Maybe FR-S... maybe not
I was expecting a Crown Vic with Lights and Sirens 5 seconds after the start of that video.
No idea why...
Exage is offline   Reply With Quote
Old 02-19-2012, 09:39 PM   #1411
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Yeah I meant to say Ford put a limiter on the car to 115 mph in fear of the driveshaft issues with the V6 model.
SUB-FT86 is offline   Reply With Quote
Old 02-20-2012, 02:48 AM   #1412
vq37
Drives: Opel Kadett
Review from autoguide
vq37 is offline   Reply With Quote
Old 02-20-2012, 02:59 AM   #1413
fatoni
sorry i didnt mean unsprung weight, just weight. i was on the way out the door to work. the point is that while solid axles potentially are at a disadvantage, in this new mustang it is not
Old 02-20-2012, 07:59 AM   #1414
Deslock
Deslock's Avatar
Drives: 2013 DZE/01 (sold for MX5 ND1)
You may have taken my comment too seriously. Though we don't always agree, we're all here because we share an enthusiasm for cars. It's all in good fun, and I hope SUB-FT86 laughed at what I intended to be a little light hearted teasing.
Thanks for posting that. Here's a transcript from 3:00 into the video, when he made his main comparison between the FRS and GC 2.0T:
Originally Posted by autoguide_GC2.0T_video_review
Now a question a lot of people are going to be asking is, how does it compare to the Scion FRS? Well I have say, you really can't compare the two cars. Now Hyundai will tell you that the Genesis Coupe 2.0T actually has a better power to weight ratio, but there's just such different vehicles. You know, the Scion FRS really is more of a momentum machine, and in this you feel like more of a serious sports car, but it doesn't... it lacks some of the purity that the Scion has.
And some quotes from the related written review: http://www.autoguide.com/manufacture...ideo-1880.html
Originally Posted by autoguide_GC2.0T_written_review
2.0T models have a better power to weight ratio than the Scion FR-S, while the V6 model beats out the BMW 335i and Infiniti G37.
A bragging point for Hyundai is that the new 2.0T has an even better power to weight ratio than the Scion FR-S. The comparisons between the two should probably end there, however. As solid a car as the new Genesis is, it’s a more substantial vehicle and lacks the purity of the FR-S, which excels at communicating with the driver through the chassis and steering.
All these factors combine with the unique value packaging of Hyundai’s rear-drive sports car to make it not just a stand-out, but a stand-alone pick. True, in the entry-level range it doesn’t offer the purist appeal of the Scion FR-S, and in top-trim it’s still no G37, but in each comparison there are strong arguments to be made for the Hyundai, be it price, style or the fact that when compared to a car like the FR-S it has an edge when it comes to the level of sophistication.
For reference, their Scion FRS review: http://www.autoguide.com/manufacture...ideo-1809.html
Deslock is offline   Reply With Quote
FT-86 / FR-S size dimensions compared to Genesis, Civic, Sction tC, etc JDMinc FR-S / BRZ vs.... 559 05-15-2014 07:50 PM
FR-S/Subie Coupe fantasy Maxim Scion FR-S / Toyota 86 GT86 General Forum 23 06-10-2011 01:25 PM
new Kia coupe Ground N Pound Other Vehicles & General Automotive Discussions 22 12-29-2009 02:04 PM
