Old 07-01-2012, 10:06 PM   #127
GirlyScions
Drives: Mazda3
Originally Posted by jedibow View Post
Your simple statement was boost and high RPM don't mix, in that case I could sight any internal combustion engine that uses forced induction
Thanks Dimman you always have a way to elequantly state the point I'm trying to make. HaHa
Actually I think I said it wasn't as safe. The below sentance was refering to the top one seeing how the fa20 is what this fourm talks about. I need to work on stop being so damn confusing
Still skeptical of 300 FI reliable hp particularly after the difference subaru's version is to achieve the same goal. I just assume subaru made those changes because its just that much more reliable.
GirlyScions is offline   Reply With Quote
Old 07-01-2012, 10:13 PM   #128
jedibow
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
The end goal of the OEM is, and will be different. They have to have a vehicle and tune that is reliable, emmisions friendly, and can accomodate any driving style first, and then the look at performance afterwards. limiting the RPM on this engine just because of FI seems strange to me, but subaru isn't the only manufacturer that does this. If they were to swap out the crank for a longer stroke, then droping the redline would make sense as the longer stroke would mean the torque peak would happen lower in the rev range, so most drivers wouldn't care. I mean when is the last time you heard somebody with a big block in there car cry about the engine not reving to 10k, it doesn't happen because they have all the power under the curve they need without running the engine to those speeds.
I know you were discussing the fa20, I just wanted to get my point across using engines that most people are familiar with, that is all.
As numerous people have already stated, with the correct amount of fuel, and ignition timing there is no reason (that we know of yet) that this engine couldn't produce 300whp with FI. However through company's like accelerated performance pushing the envelope we will be able to determine, block strength, rod strength, cylinder sealing, cooling strength, oiling strength, and as popular as this platform is I believe that when each limitation is determined, somebody will offer a solution. I have learned a valuable lesson, you learn more from failing, than you do from suceeding. It is from failing that you identify limits, and can plan how to overcome those limits.
Originally Posted by ImAwesome
Great info in here. arghx7 what do you do?
He's obviously a very knowledgable landscaper.
jedibow is offline   Reply With Quote
The Following 2 Users Say Thank You to jedibow For This Useful Post:
Chewie4299 (07-13-2012), Exhaust (07-02-2012)
Old 07-01-2012, 10:47 PM   #129
Don@Accelerated
Don@Accelerated's Avatar
That's why I'm all over this. Not to mention I bought one myself.
Don@Accelerated is offline   Reply With Quote
Old 07-01-2012, 10:51 PM   #130
jedibow
I know and I appreciate all you are doing!
Good turbo selection, great idea for packaging, I'm excited to see where you take this,
Thanks Don
G
Old 07-01-2012, 11:02 PM   #131
serialk11r
Drives: '06 AM V8V Coupe
Errrr only drastic changes in stroke will do that, Toyota noticed a 1% change in fuel economy or so across a huge range of strokes when developing the 1ZZ.
My guess would be they limited revs since the turbo poops out at higher revs, and then they use that to possibly cheapen the engine in other places due to reduced rev requirement.
Old 07-01-2012, 11:30 PM   #132
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
true, compressive forces from higher Bmep and boost are less stressful on the rotating assembly than high rpm.
But with a tuner-friendly design, high compression, and relatively lively redline of 7300rpm, I believe the rods have been designed to handle at least 300whp easily... the pistons probably won't handle a lot of detonation too well though.
The last few toyota engines I have torn down have had really spindly connecting rods, with weaksauce bearing sizes. Same with the EJ20. But I still believe 300whp will be achievable and reliable with proper tuning... and it will be a riot to drive!
Coheed is offline   Reply With Quote
Old 07-02-2012, 12:59 AM   #133
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
This was probably just a general comment from you but to make sure, this is a Subaru engine not Toyota, so don't expect this this engine to fail similar to how Toyota engines commonly fail.
Old 07-02-2012, 01:03 AM   #134
Dimman
Kuruma Otaku
Dimman's Avatar
The EJ20 he mentioned is a Subaru motor.
Because titanium.
Old 07-02-2012, 01:05 AM   #135
Sportsguy83
Drives: Limited BRZ
Fair, and exactly the reason I quoted only the Toyota sentence.
Old 07-02-2012, 01:53 AM   #136
Exhaust
UCanThrottleMyBody
Exhaust's Avatar
Drives: 2015 GM 370z Sport
face-palm.
Exhaust is offline   Reply With Quote
Old 07-02-2012, 04:26 AM   #137
slow_frs
Drives: turbo scion tc
Hmm odd I've seen more subaru engines have piston ring failures than Toyota think about the design the pistons are sideways, gravity is constantly pulling the piston down on its side mix that with the stroking motion and it's like running something across a file over time the bottom side of the piston will flatten its just physics
slow_frs is offline   Reply With Quote
Old 07-02-2012, 04:44 AM   #138
Sportsguy83
Drives: Limited BRZ
Originally Posted by Exhaust View Post
face-palm.
I am not saying that Toyota's engines regularly fail, or making a comparison between Toyota or Subaru engines. All I said was not to compare the possible failures of this engine with Toyota engines because it is a Subaru engine, nothing more.
Old 07-02-2012, 04:46 AM   #139
serialk11r
Perhaps you should familiarize yourself with the typical order of magnitude of the acceleration forces pistons see. Gravity is measured in...well, 1g. Piston acceleration is measured in 1000s of gs.
Old 07-02-2012, 05:29 AM   #140
brewksy
Drives: 2011 Subaru STI
Then why does Subaru recommend flipping the pistons every 25k miles to offset gravitational distortion of the piston heads. Duh.
brewksy is offline   Reply With Quote
accelerated performance, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
Accelerated Performance 2013 BRZ Intake Dyno Testing Video Don@Accelerated Engine, Exhaust, Transmission 109 05-17-2013 11:24 AM
Accelerated Performance 2013 BRZ Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 135 09-03-2012 11:24 PM
Accelerated Performance 2013 BRZ/FRS Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 24 07-07-2012 07:05 AM
Hello from Accelerated Performance! Don@Accelerated Announcements, Contests, Giveaways 5 07-04-2012 08:14 PM
