Old 10-05-2016, 05:02 PM   #127
Fenix
Fenix's Avatar
Drives: 2013 Scion FR-S + 2011 Yamaha R6
Originally Posted by pleong View Post
it's pretty damn loud... i was cruising and sometimes i can't bare it... but on the track, i can't even hear it lol
Is it so loud you cannot have a normal conversation in the car with someone else?
Fenix is offline   Reply With Quote
Old 10-06-2016, 03:41 PM   #128
pleong
Drives: 2013 Whiteout FR-S
IMO yes..
I'm trying to think how loud it is without my straight pipe exhaust... I can tell you... if you're worried about the noise as a daily driver, I wouldn't get it... If you're pushing this much power to need these gears, it shouldn't be your daily driver.
TEAM NEMESIS | NEM 86 | IG: @NEM_86
PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics
The NEM86 Build Thread
pleong is offline   Reply With Quote
Old 10-06-2016, 10:43 PM   #129
dp1
driving smoother faster
Drives: Sold
@pleong and others, please advise, thanks
I have a spare 2014 transmission begging for an upgrade before I destroy the 2015 transmission with low miles that was just installed.
If I ship my transmission to Jack's, what bits should I order to make a complete upgrade? i.e., PAR gears + double synchro 4th gear + performance build service including all coatings + anything else?
I'm ok with gear noise. Car is primarily used on track though I'd have enough time to enjoy a new type of whine driving to/from track, to add to OSGiken lsd and suspension noises.
dp1 is offline   Reply With Quote
Old 10-07-2016, 04:38 AM   #130
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
The par gearset should come precoated and treated. Ask Jack's about their shift forks if your interested in that. They are also developing a trans cooler if you track your car.
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
Old 10-08-2016, 10:18 PM   #131
dp1
Drives: Sold
Thanks a lot - talked to Jack and we may end up doing some business together. I will probably send him my 2014 transmission first for inspection, then we can figure out what is available for testing by May 2017, beginning of my next track season.
Old 10-09-2016, 09:53 PM   #132
Dipstik-sportech
Dipstik-sportech's Avatar
Is there any way to just do 1st though 4th and leave 5th and 6th stock? I need the strength but I do like road tripping my car so the noise on the highway is a deal breaker.
Old 10-09-2016, 11:16 PM   #133
Drakiv
Project Shadow
Drakiv's Avatar
If that's the case, just drive in 5th gear. 6th makes noise, but 5th gear is completely silent as a straight cut because it's the direct drive gear. I believe Velox is still working on that and testing a 1-4 set, and I believe Jacks Transmission's is also looking into prototyping a 1-4 gear set or something along those lines. Very exciting that we have multiple companies looking into this now, very good for everyone in the Ft-86 community indeed because it can only get better.
614whp/421tq on E85
Instagram: Drakiv
Old 10-09-2016, 11:27 PM   #134
Dipstik-sportech
Yeah driving 6+hrs in 5th gear doesn't really sound like a great idea not to mention kinda negates having a 6speed
Old 10-09-2016, 11:47 PM   #135
Drakiv
Project Shadow
Drakiv's Avatar
true, but if you have enough power requiring this type of gear set or something along those lines and you have to drive 6+ hours a lot, don't you think you should be driving a different vehicle or if you are taking the car to a track maybe trailering the thing? I'm not telling you how to do something I'm just throwing that out there, I understand what you are saying. For all of those saying that can't handle the gear whine, I don't get it. I daily my car still and the gear whine is fine to me, I can still listen to my music with the windows down and have conversations with my wife in the car without yelling. Learn to use throttle manipulation to keep the whine to a minimum and bada bing bada boom. I am able to tune out the gear whine and it just doesn't bother me.
614whp/421tq on E85
Instagram: Drakiv
Old 10-10-2016, 07:42 AM   #136
Dipstik-sportech
I have a fast street car not a streetable race car. I enjoy driving it and I don't want to take away from that enjoyment
Old 10-19-2016, 08:16 PM   #137
PAR Engineering
Answers from the Manufacturer
Hi All, I have recently been directed to this topic and have read over the history.
As known, we have been supplying a gear set option.
Keep in mind 6th gear is an option and is usually replaced since its too weak or the ratio does not suit.
6th can remain OEM and hence 5th and 6th will then be quiet. This will appeal to the users that are worried about noise.
Straight cut technically known as Spur has many advantages when compared to Helical gears. Although the 1 disadvantage is the gear whine. Keep in mind the way we manufacture gears these days with our new technology our spur gears are quiet when compared. We actually have customers request they be nosier.
The few advantages of Spur cut gears include, no thrust axial loads, better tooth profiles, strength, etc. All these advantages reduce horse power loses.
Can we purchase 1st-4th only?? was a question I noticed popped up often.
The answer is Yes, 5th and 6th will retain OEM gears. The only issue with this is that if the car is a heavily launched 5th can break since all the power runs through 5th before it is transferred through the selected gear. Only when 5th is selected it is direct drive. If 5th shatters there is a chance that the tooth debris can blend through other gears. So if you don't launch the car and have not got really high power then 1st-4th may work at your risk. As the manufacturer we need to be very clear.
I will keep an eye on this forum and will happily answer any questions but can I please ask to not ask the same question twice since I don't have much time away from production.
PAR Engineering is offline   Reply With Quote
Old 10-31-2016, 01:20 PM   #138
TruthfulDeception
Drives: '14 FRS
Where is the option to purchase?
TruthfulDeception is offline   Reply With Quote
Old 10-31-2016, 01:24 PM   #139
brianhj
Drives: 2017 Camaro 1SS
Do you want to buy a set? I'm selling mine, $4500 shipped
Brand new unused
brianhj is offline   Reply With Quote
Old 11-19-2016, 12:23 PM   #140
lonespeedster
Drives: Subaru BRZ 2014
Brand new unused
Hello Brian,
I'm interested, is it still available? Please conform,
Thanks and regards
lonespeedster is offline   Reply With Quote
FRS/BRZ Manual Trans Fluid shellslinger Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 131 11-02-2017 10:44 AM
WTB: FA20 and Six Speed Manual Trans Cross Want-To-Buy Requests 2 04-24-2016 12:06 AM
Manual Trans 12k miles $750 OBO Amir Ghadiri Transmission and Driveline 4 05-23-2015 02:35 PM
Bump start in a manual trans? bayank BRZ First-Gen (2012+) — General Topics 11 02-16-2014 06:47 PM
FS: 1st 86 DGM/Asphalt Scion FR-S (Manual Trans) Neurytic Cars for Sale/Trade 3 05-22-2013 11:54 PM
