Old 06-21-2015, 01:52 PM   #127
Rybot
Rybot's Avatar
Drives: Subaru BRZ Series.Blue
Originally Posted by yomny View Post
Update: the gasket for the drain is looking moist, meaning oil is finding its way out and it's a matter of time before it drips. This is frustrating, maybe I'm too anal and these things are never supposed to be completely dry but I do recall it being dry prior to now. I think the fact that the center section oil outlet is square and all the flanges for the drain hoses are round allows for oil to get to the gasket. That or the flange isn't sealing well enough. Regardless I don't want to leave things this uncertain and ordered a drain flange with a square inlet and O ring.
Yikes. Let us know how those parts hold up.
Rybot is offline   Reply With Quote
Old 06-21-2015, 02:48 PM   #128
erok81
Drives: 2015 BRZ
Where did you get the new drain flange? I'm still waiting on my kit but I'd like to grab one while I'm waiting. I've never had luck keeping that seal leak free on other cars.
erok81 is offline   Reply With Quote
Old 06-21-2015, 02:51 PM   #129
drambo136
drambo136's Avatar
Drives: 2013 Hot Lava
Amazon, eBay, etc.
Sent from my SAMSUNG-SM-N900A using Tapatalk
drambo136 is offline   Reply With Quote
Old 06-21-2015, 07:08 PM   #130
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Didn't have any issues till now, not sure what has changed, maybe the darn extreme heats we've been having don't help. Just made another gasket till my new flange arrives. I got in on eBay, it's from a company called PRL Motorsports.
Can't attached images the right way via my phone but here's the link. Just wait and see, maybe you have good luck. I know mine was doing great till these 90F+ days came around. No biggie honestly, don't sweat it.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 06-22-2015, 09:25 AM   #131
yomny
yomny's Avatar
After another failed attempt at eliminating the leak, yesterday afternoon I made another one and today the gasket started to get wet again. I'm going on the second gasket, fortunately for me I have the flange coming in, if not I'm going to use the sealant used on the oil pan for this car specifically which is one tough mofo. Either it stops leaking or it'll be sealed shut and it will stop leaking. What beats me is why the hell did this thing start to leak now.. nothing has change, the turbo hasn't moved.. no damage, accidents.. nothing to alter any of the previous conditions. It sealed well before, why not now , anyways, below is the "ported o ring sealed square drain flange I was talking about. I already contacted the guys at JDL to see if they have any suggestions but understand this has really nothing to do with them.
The Following User Says Thank You to yomny For This Useful Post:
Rybot (06-22-2015)
Old 06-22-2015, 09:33 AM   #132
Rybot
Rybot's Avatar
That really sucks. So the stock flange is round with no o ring, correct?
The point of getting the new one is so the flow geometries match up? Also, you're still going to use a gasket once that gets in, right?
Old 06-22-2015, 10:04 AM   #133
yomny
yomny's Avatar
The stock one and most return flanges are round, no o-ring, just the paper gasket. I don't know why but most manufacturers including Precision use this round hole flange. It could be to use with the bigger t4 center cartridges and not have to make difference flanges, im sure its not creating too much of a problem for them otherwise they'll change the design. Since im at it already mind as well get a matching one to the turbos drain hole and replace that paper gasket. Although its "oil resistant", I think any paper like material mixed with oil will eventually get damaged.
Old 06-22-2015, 10:13 AM   #134
xxscaxx
Drives: 2013 SWP BRZ
A good online store to pick up turbo parts from is atpturbo.com. Should be able to pick up more gaskets from there. Thats odd you got a leak from that, I've never had issues in the past on them but it makes sense it could happen with all the heat the CHRA is seeing and the surrounding heat.
xxscaxx is offline   Reply With Quote
Old 06-22-2015, 10:21 AM   #135
yomny
yomny's Avatar
Thanks for that suggestions, ATP and AGP are one of the first that come up when searching for those gaskets. Maybe its that gasket paper im using, the odd thing is that the oem one started to leak to after several months of use The gaskets are pretty affordable so i'll get a few just in case.
Old 06-22-2015, 10:22 AM   #136
xxscaxx
yeah thats weird, i know the one that JDL sent me was not the typical paper gasket ones, but a different material. Was hoping it would hold up better than the typical paper ones.. oh well lol.
Old 06-22-2015, 10:26 AM   #137
yomny
yomny's Avatar
Im sure it'll hold up.. could really be one of those things that happen to one in a million under very odd circumstances lol. Just documenting all this stuff for anyone in the future that may encounter something similar. Since these cars aren't oem turbo its hard to find little issues like these on the forums.
Old 06-22-2015, 10:32 AM   #138
Rybot
Rybot's Avatar
A part of flange design is cost to manufacture. Round is extremely easy. Just drill it. Square, not so easy so more cost intensive.
Either way, the flange you bought should definitely help paired with a not paper gasket. I'd imagine once the paper is saturated, you're screwed.
Old 06-22-2015, 10:32 AM   #139
Rybot
Rybot's Avatar
Does the JDL one hold up better?
Old 06-22-2015, 10:33 AM   #140
xxscaxx
I have not turned my car over yet, but once I do I will report back in due time
RS*R Sports-i coilovers - install & review ultra Suspension | Chassis | Brakes -- Sponsored by 949 Racing 50 07-27-2022 06:29 PM
Powerhouse Amuse Single Exit Exhaust + R1000 FP Review BrianJC Engine, Exhaust, Transmission 26 06-06-2016 10:09 PM
My OEM Audio Plus 400 Install and Review Yruyur Electronics | Audio | NAV | Infotainment 156 03-01-2016 05:53 PM
TRD Sharkfin Install and review Tye300 Cosmetic Modification (Interior/Exterior/Lighting) 27 07-19-2014 07:21 PM
REVIEW: Berk Technology Single Exit Track Pipe w/ Tip NYC BRZ Engine, Exhaust, Transmission 11 12-29-2012 08:22 PM
