Old 02-27-2015, 11:01 AM   #127
Koa
yes exhaust leaks at header cause 02 reading to be in correct high fuel trims and incorrect afr results if it gous lean it will cause knock and iam to drop.
this leak was at the CBE, where midpipe met axleback. I don't know if I had a bad batch of gas, or what... but IAM no longer drops and tip in knock is significantly reduced.
Old 03-15-2015, 03:49 AM   #128
kl95210
Drives: 2014 BRZ
I have a Tomei UEL along with the GS intake. Will I be fine running the OTS Stg2 with 93 octane? What about on E85?
kl95210 is offline   Reply With Quote
Old 03-15-2015, 05:10 AM   #129
steve99
The grimspeed intake maf scaling is very close to stock, so your pretty safe with that intake running the oft tunes even e85.
Old 03-18-2015, 01:42 AM   #130
Koa
This just in: the best map for this intake with uncatted UEL headers is the OTS stg2 E85 map. Holy balls what a kick in the pants... :cheer:
Old 03-18-2015, 03:33 AM   #131
steve99
its about as good as it gets before FI
Koa (03-18-2015)
Old 03-18-2015, 01:05 PM   #132
Cop
Cop's Avatar
Drives: 2013 FRS
Beats out your own GS tune on 91oct?
Cop is offline   Reply With Quote
Old 03-18-2015, 01:18 PM   #133
Koa
Way better. Tiny bit of knock up top (7300RPM / 1.3+ load), and I mean tiny -.63 or less, IAM pegged at 1.. and is a bit rich at WOT.. so I'm tweaking that OTS map and will post my changes here when I'm done.
By the way, I'm going to be updating the GS + OFH stage 2 tune.. there's a bit of knock at 2800-3600 with the revised MAF due to the Primary OL table.. pulled a little timing and smoothed out the MAF scale. Will update the post and reply to this thread with it when I get home
Old 03-18-2015, 01:29 PM   #134
Cop
Cop's Avatar
Drives: 2013 FRS
Looooool. What is the main difference between the OTS stage 2 91oct vs E85 tunes?
Old 03-18-2015, 01:32 PM   #135
Cop
Cop's Avatar
Drives: 2013 FRS
Experienced the same knocking with the MAF scale I just tried out this weekend. Thank god for Koa
Old 03-18-2015, 01:46 PM   #136
Koa
It's huge.. major timing and fuel changes, MAF scaled for wide range of E content.. power all across the board, IAM pegged at 1, no real knock (little bit of tip in, but that's just fine tuning) and is in general just a whole 'nother beast now. The v2.06 OTS E85 UEL map plays VERY well with the OFH and g/s intake at least in my environment and using Shell E85
Old 03-18-2015, 02:53 PM   #137
Cop
Cop's Avatar
Drives: 2013 FRS
For some reason I thought you were suggesting running the OTS E85 tune for 91 octane (since you were tuning for that before). Makes a whole lot more sense right now !
The Following 2 Users Say Thank You to Cop For This Useful Post:
Koa (03-18-2015), Sleepless (03-18-2015)
Old 03-18-2015, 08:03 PM   #138
j_Zer0
Drives: Asphalt FRS 2014
Very interesting. Think it's good enough that MAF scaling isn't necessary? Or will MAF scaling be necessary no matter what? I have the GS intake but haven't installed it yet for fear of creating issues for a few extra HP.
ESC+OFH | Borla Axleback | Helix clear side markers | Opti-coat | Beatsonic v2 Sharkfin antenna | TRD lowering springs | TRD sway bars | 18" Enkei Kojins + PSSs
j_Zer0 is offline   Reply With Quote
Old 03-18-2015, 09:23 PM   #139
Koa
You'd want to shy away from maf scaling if the actual E contact varies from where you get it
Rather adjust timing for any knock that may be being reported by the system.. shouldn't happen often on a prim and proper system with quality corn juice although don't take my word for it.. Learning as I go
I had very small knock events in the upper 7000rpms and some tip in down low that I've adjusted for @ the advance base B table
Also increased the heavy load areas in POL table to try and lean my AFRs out a bit as I'm getting as rich as 11.37 in mid 6k-7k loads
The Following User Says Thank You to Koa For This Useful Post:
j_Zer0 (03-19-2015)
Old 06-28-2015, 05:50 PM   #140
nunonuna
nunonuna's Avatar
Did you see my post containing a MAF rescale for the G/S Intake + OFH?
This is most of the work that needs to be done to have the v2.06 tune play nicely with the intake and header combo.
A side note, off-the-shelf tunes are often needing a rescale or tweak to get to work with your system, even with identical parts setups. This has many variables to it, but main variables are fuel quality and environmental conditions. Just some food for thought, hope you try it out. Let me know if you need any help
Do you still have this file available???
The link you provided seems not working.
nunonuna is offline   Reply With Quote
DIY - GrimmSpeed Intake Installation Guide GrimmSpeed DIY (Do-It-Yourself) Guides 60 09-08-2017 11:12 AM
** GrimmSpeed BRZ/FR-S Air Intake - GROUP BUY ** GrimmSpeed Engine, Exhaust, Bolt-Ons 1902 08-29-2017 08:47 PM
GrimmSpeed Intake Before and After OFT Tune + Review F1fletch Engine, Exhaust, Transmission 76 06-30-2016 03:40 PM
For Sale: GrimmSpeed Intake *newish* xDanger_208x Engine, Exhaust, Bolt-Ons 13 11-30-2014 11:16 AM
WTB GrimmSpeed intake VakaGT Want-To-Buy Requests 0 11-18-2014 01:19 PM
