Old 09-01-2014, 10:59 AM   #127
Ubersuber
Drives: BRZ Pearl White
Originally Posted by Mikem53 View Post
Nobody buys gasoline to be used as a lubricant, that was not my point.. Uber-ass had to say something to look like an expert, I should have ignored it.
The fuel does indeed lubricate the fuel pump and other fuel system components.
Uber-ass suber once again has to try and impress everyone with his vast knowledge, which of course was similar to his suspension/bump stop ramblings which were all worthless bullshit, but amusing.
It's my fault for arguing with an idiot.. They will just knock you down to their level and beat you with experience.
Gasoline does not lubricate the fuel pump, rather the reverse, and certainly doesn't lubricate the injectors. This lack of lubrication quality caused serious engineering challenges to makers of fuel injection and fuel pressure systems. This is such common knowledge no expertise is required to understand it.
The username is spelled Ubersuber.
And you got the rest wrong in your post also.
Give up.
Ubersuber is offline   Reply With Quote
Old 09-01-2014, 11:03 AM   #128
Well I tried.
Ubersuber (09-01-2014)
Old 09-01-2014, 11:04 AM   #129
charged86
charged86's Avatar
e85
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 09-01-2014, 11:26 AM   #130
Stevew8
Stevew8's Avatar
Drives: Scion FR-S 10 #0931 ManT
I had used nothing but the highest octane ever when available on
99 volvo S70 Turbo
2003 Passat W8
2011 Camry Se
2013 FR-S
If you own the car then why be cheap on it, the dirty gas eventually will haunt your dreams on the long run.
I told everybody, don't worry I drive rear wheel drive in the snow all the time at work, and the car fits 2 kids in the back and my groceries in the trunk are no problem.
Stevew8 is offline   Reply With Quote
Old 09-01-2014, 11:47 AM   #131
wparsons
wparsons's Avatar
Originally Posted by Synack View Post
12.5:1 super high compression says premium only. Sure it will compensate if you put in 87, but when you take your car to the dealer when your engine blows and they find 87 in your fuel lines and gas tank they will leave you with the multi-thousand dollar bill.
Mazda sells 13.5:1 SkyActiv engines that run on 87 octane. C/R isn't the whole story.
>Thread about octane ratings
>A dozen posts arguing about the lubricity of gasoline
Welcome to ft86club!
Welcome to any thread Suberman (Usersuber) posts in.
Originally Posted by Neokolzia View Post
My question is in the winter would 87 be fine? Maybe with just a splash of octane booster, would save a fair amount of money, 1 tank free worth over a winter for sure.
Not worth it. The cost difference between 87 and 91 octane is like $4/tank, and running 87 octane would mean babying the car to avoid knock. If you want a car that runs on 87 octane, buy one that's designed for it.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
strat61caster (09-02-2014), Synack (09-01-2014)
Old 09-01-2014, 12:13 PM   #132
rs999
rs999's Avatar
Drives: VW MK6 GTI | 13 Mustang GT
You can run regular 87 if you want. If the car is stock nothing will happen, even if you race, autox, or run the car out.
The octane ratings don't mean anything for stock cars because the manufacturer has built in safeguards to protect the car from the appliance driving public.
The only time octane ratings matter is when you flash tune the car since most tuners don't account for lower octane levels and try to tune the car to get the most HP out of the octane. So lower octane ratings on tuned cars are more likely to experience the badness of knock and timing retarding.
SOLD FR-S Build | MK6 GTI Build | I might be getting another FR-S
rs999 is offline   Reply With Quote
Old 09-01-2014, 12:55 PM   #133
Ubersuber
While true that modern engines are programmed not to damage themselves when filled with low octane fuel, performance is very poor with low octane.
Subaru states in the owner's manual that the engine is intended to run on 93 (98 RON) so using 91 is already using low octane fuel for this engine.
Old 09-01-2014, 01:14 PM   #134
rs999
rs999's Avatar
Yes but on a stock 86 nothing will be damaged if you run lower octane even if you race, autox, or drive aggressively.
Also, the lower performance is very subjective, 99% of the drivers (both forum and regulars) wouldn't know the difference if the car was filled with 87 vs 91/93.
As I stated above you only feel and require higher octane once you are tuned, otherwise it really is optional.
Old 09-01-2014, 02:59 PM   #135
wparsons
wparsons's Avatar
Even with an aggressive tune the stock ECU will still respond to knock the same way it does on the stock tune, which is to pull all kinds of timing.
If you're boosted, the consequences are much higher and you're likely to damage something, but N/A it's not going to explode.
flickr
Old 09-01-2014, 03:11 PM   #136
Neokolzia
Drives: 1996 Celica GTFour ST205
93 is scarcely available in Canada we only get 91 so they can't really force it
Neokolzia is offline   Reply With Quote
Old 09-01-2014, 05:28 PM   #137
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
I've never had an issue finding 94 oct in western Canada.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 09-01-2014, 06:05 PM   #138
Would have to take out a second mortgage to buy 94 in Ontario! Plus burn a 1/2 tank driving to the few places that have it.
Old 09-01-2014, 08:13 PM   #139
CoupedUpSubie
Drives: 2013 BRZ Limited
I wish people would read the manual. 93 is preferred while 91 is minimum. If an automanufacturer wants to sell volume in the US then selling a car that requires 93 is almost shooting themselves in the foot.
When poor or low octane fuel is used it can creates knock, the knock sensor then relays that to the ECM which retards the timing. As stated the stock tune is conservative, for 91/93 octane. If you run 87 octane you do risk damaging your engine, even on a stock tune. Most people who have had the dealer put 87 in the car get away with it because they drive easy for the break in period.
When it comes to engines using fuel which meets the specifications given by the manufacturer is key. In the shipping industry vessels carry fuel samples for 2 years. One reason is if bad fuel is the cause for mechanical failure. I'm not saying we all have to keep samples of the fuel we put in the car, just making a point.
Don't be cheap, put at least 91 octane in the car. You bought a "sports" car.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
The Following 2 Users Say Thank You to CoupedUpSubie For This Useful Post:
Apoc (09-01-2014), Tcoat (09-01-2014)
Old 09-02-2014, 08:58 AM   #140
wparsons
wparsons's Avatar
You're kidding right? I have 4 stations within 2km's of home that have 93 or 94 octane. Three petros and one esso. Both are only 2-3 cents more per liter than 91 octane at the same station.
Before you claim London has fewer stations with 94, this is all the petro stations in the London area that have 94.
http://www.petro-canada.ca/en/locati...PC=+&R=50&B=UL
flickr
uberstupid, use premium!, you can't fix stupid
Premium gas, or? NotlocTRD Scion FR-S / Toyota 86 GT86 General Forum 151 09-27-2017 03:56 PM
FRS arrival for regular customers question NWIguy Scion FR-S / Toyota 86 GT86 General Forum 20 05-05-2012 09:54 AM
Anyone have a pic of the regular seats? DuMa Scion FR-S / Toyota 86 GT86 General Forum 38 12-14-2011 01:29 AM
So is it a hatch or regular trunk? xantonin Scion FR-S / Toyota 86 GT86 General Forum 5 12-09-2011 08:26 PM
Consequences to Adding Regular Gas? iff2mastamatt Scion FR-S / Toyota 86 GT86 General Forum 34 12-06-2011 01:52 AM
