Old 03-16-2018, 03:11 AM   #127
djezlee
Drives: 2017 BRZ Limited
Can someone help me find the files for the v3 or v4 OTS tune? I need something compatible with my MY17... and OFT is not replying to my emails.
djezlee is offline   Reply With Quote
Old 03-16-2018, 12:29 PM   #128
jslack
Drives: 2017 Red subaru BRZ Limited
Same as previous poster. I have been trying to get a hold of OFT for a week now and no response on email or facebook messenger. Also if you goto Amazon or ft86 speed factory, they show the tablet as unavailable to buy. Sooo, does anyone know if they are still in business?? I wanted to buy the header overpipe tablet combo. Glad I didn't send any money yet. I have the 17 model and want to make sure the tablet works with the 17. You call their phone and says please email also.
jslack is offline   Reply With Quote
Old 04-16-2018, 05:03 PM   #129
Maverick986
Drives: 2014 Subaru BRZ
ACE and Nameless PLM header cam angle tables Normal and safe tables are same.
Note these tables will get you in the ballpark, but may require adjustments and you may need to adjust fueling and ignition timing as well to extract full benefit
Their is a second set of Nameless PLM header tables with modified midrange by @KoolBRZ called VII NH 1.4 EL see the tune tweaks thread first post for those.
First time adjusting tables, and wanted to clarify before flashing. Where it is stated that "Normal and Safe" tables are the same, I am suppose to adjust both the normal and safe on both intake and exhaust tables, correct? Also, do I need to adjust any other tables other than intake and exhaust AVCS, at least initially? This is for a Nameless header.
Maverick986 is offline   Reply With Quote
Old 04-16-2018, 05:22 PM   #130
steve99
If its just header change then just adjust fhe cam timing initially.
Correct normal and safe tables are same in oft tunes but different for intake\exhaust so you need to change 4 tables.
Later you may adjust fueling and timing if needed
Old 04-16-2018, 05:23 PM   #131
freerunner
freerunner's Avatar
Drives: GT86
AVCS normal and safe maps are not equal in the stock rom.
If the IAM gets reduced due to knock, the 'normal' maps are used.
I can't remember the transition threshold, it's 0.4 or something like that.
Most people (myself included) just put the same maps in both of them.
freerunner is offline   Reply With Quote
Old 04-16-2018, 07:19 PM   #132
steve99
Yep base is different it limp mode i believe
Old 09-18-2018, 08:38 PM   #133
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
OFT Tune Tweeks and Information
Load limits:
ON OFT C & D series rOMS the load limit tables B&C (some defs it will be A&B) are set to about 1.5 accross entire rpm range. This can cause bogging or hesitation. Either copy @Wayno's load tables or copy back the standard load limits from say a G or I series OFT rom.
There are 4 load limits that may need to be altered:
MAF maximum (in g/s)
Engine load Max (in g/rev)
Engine load limiter A and B (g/rev per RPM)
@Wayno has done some work on the E85 Automatic Transmission tunes which appear to push the "engine Load limite A & B beyond 1.3 causing issues see posts below load limits increased to 1.4
http://www.ft86club.com/forums/showp...postcount=2510
http://www.ft86club.com/forums/showt...46468&page=114
Where are the load limit tables located in V4.03? I cannot find them for the life of me. My car keeps running rich between 3600-4000rpm, apparently the load limiters could be to blame
Old 09-18-2018, 09:15 PM   #134
steve99
the tables will be in rom its may be just your definition does not reference them
try the def I posted up in first post if your 2012-2016 car
http://www.ft86club.com/forums/showthread.php?t=126180
also load limiters just limit the load calculation to the load limit for that rpm range
if its running richer than commanded afr in that range in open loop then fix the maf scaling
Old 09-19-2018, 06:41 AM   #135
Yoshoobaroo
TRACKBREAD
Thanks, that worked!
I don't think my MAF scale is to blame, I've got low STFT and LTFT across the board, but at high load between 3600-4000rpm it goes rich to 11.3. I've read some people were able to fix this using Wayno's load limit tables.
Old 09-19-2018, 06:56 AM   #136
tomm.brz
Drives: brz 2017 hksv2
in open loop it doesnt really matter the ltft you get because that depends more on the closed loop indirectly, you need to look at afr actual vs afr target. if you get 11.3 and afr target is much leaner you need to fix maf scaling around that maf voltage to get afr actual following the target
use the vgi maf scaling tool provided by kodename47 to fix it easily
the engine load limits usually (also wayne's ) stop acting after 3200, means that after 3200 load is already maxed out, so you shouldn t counting on that to lean the afr
Old 09-19-2018, 07:26 AM   #137
Yoshoobaroo
TRACKBREAD
Thanks!
Should I scale for OL or CL first? Been reading conflicting info on that.
Old 09-19-2018, 07:30 AM   #138
tomm.brz
do what steve says on his maf scaling thread :P
use the tool to scale well both of them
Old 09-19-2018, 07:41 AM   #139
tomm.brz
anyway you can do both together at the same time
Old 09-19-2018, 08:38 AM   #140
Yoshoobaroo
TRACKBREAD
OFT Tune Usefull Information and Tweaks
Thanks for the help guys. I re-cecked my logs and looks like I am not hitting a condition where the load limits would kick in anyway, so rescaling the MAF it is.
Drift Office Tune vs Visconti Tune mechaghost Engine, Exhaust, Transmission 109 07-03-2014 12:57 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
difference between vortech tune and perrin tune? Frs32907 Forced Induction 7 12-05-2013 02:49 PM
Information I did not want to know. K2 Great Lakes 19 07-23-2012 08:18 AM
