Old 02-20-2013, 01:52 PM   #127
Mach V Dan
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
Originally Posted by 619_FRS View Post
It really isn't that bad. I had the same thoughts too when I was ordering the set up. Everyone has their own preference though.
Better shot of the wheel fitment
Shaking my head. 619, you of course are free to do what you want and like what you want, but this fitment is outside the manufacturer's specs on every tire I can find. (Basically, 225/40R18 is specified for wheel widths between 7.5" and 9" wide.) It also looks to me like that front tire is going to contact the fender at full compression, but I could be wrong on that.
For the rest of you watching at home, my big issue with this kind of "fitment" (or ill-fitment) is that the tire isn't designed for the sidewalls to be at such an extreme angle. The bead strength is reduced, the connection from the sidewall to the tread is weakened, and overall sidewall strength will be less.
From the standpoint of weight, you've basically added extra weight in the form of a much larger wheel than is required for that tire size. On a car where weight is so important (given the low power and torque, every pound counts), wasting weight on a wider-looking wheel just seems a shame.
Again, to the original poster, this is your car and you can do what you like to it. Some people like this look, regardless of function. I guess my post is mostly directed at future wheel/tire purchasers. To those people, do yourself a favor and get a wheel that's sized properly to the tire you're planning to run. It'll weigh less and you'll maximize grip and strength, and you'll have better-than-stock performance, not worse.
--Dan
Mach V
Mach V Dan is offline   Reply With Quote
The Following 8 Users Say Thank You to Mach V Dan For This Useful Post:
batlwagn (03-31-2016), BRZ37J (09-10-2014), coyote (04-12-2013), dorifuto (02-21-2013), infinite012 (02-20-2013), Scaldy (02-28-2013), sidswiftsteel (11-08-2013), VoiD (02-20-2013)
Old 02-20-2013, 02:06 PM   #128
619_FRS
Drives: Ultramarine Scion FR-S
--Dan
Mach V
Everyone has their own opinion. No sense in bad mouthing my car. I never thought of tracking these wheels. Simply wanted this particular look. The car actually handles better than factory. If I want to track my car or worried about shaving seconds off my lap time then I'd go with a different size. As for weight, the wheel only weighs around 1 pound more than factory. Not bad for such a large wheel. Thanks for your post.
619_FRS is offline   Reply With Quote
The Following 2 Users Say Thank You to 619_FRS For This Useful Post:
PradiG (02-20-2013), sal (02-21-2013)
Old 02-21-2013, 12:25 PM   #129
sal
sal's Avatar
Drives: 16 FRS
Glad to see this wheel setup posted up. Ordered my wheels with the exact same setup. Are you running any negative camber in the front/rear? No rubbing during hard turns either?
If you could post a picture of the car from the back that would be great. (Want to see how wide it looks with a 225/40 tire.)
Thanks, and the car looks wicked!
sal is offline   Reply With Quote
The Following User Says Thank You to sal For This Useful Post:
619_FRS (02-21-2013)
Old 02-21-2013, 01:02 PM   #130
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
I would have went with a higher offset to tuck them in a little but it is clean! I like it. Whats the highest offset you can get these in for 18x8.5 and 9.5?
Tansey86 is offline   Reply With Quote
The Following User Says Thank You to Tansey86 For This Useful Post:
Old 02-21-2013, 01:59 PM   #131
619_FRS
Thanx! In the rear there is some camber, but it comes naturally from the car when you lower it. I lowered it 1.4 inches with some Center Gravity springs. The front has no camber. Lemme edit some pictures and I'll post them later for the rear shot.
Oh and no rubbing at all on hard turns. That's not to say if their was a massive pot hole that it wouldn't rub haha.
Old 02-21-2013, 02:02 PM   #132
619_FRS
The offset really depends on the tire size you're going with too. The only reason my size wheel with +30 even fits is because I went with a 225 tire and the stretch of the tire fits perfect to tuck when the suspension compresses. What size are you thinking of doing?
Old 02-21-2013, 02:11 PM   #133
Mach V Dan
I'm not bad-mouthing your car! I'l be the first to say, it LOOKS fantastic.
I guess I am bad-mouthing your decision to pair those wheels with those tires. Sorry.
That's true -- they are very light for such a large wheel. Of course, an 8" version of the same wheel would be even lighter.
--Dan
Mach V
Old 02-21-2013, 02:12 PM   #134
619_FRS
Rear shot
The Following User Says Thank You to 619_FRS For This Useful Post:
sal (02-22-2013)
Old 02-21-2013, 02:15 PM   #135
619_FRS
Thanx! It's ok, everyone has their own opinion. I knew what I was getting into pairing those tires and size wheels.
--Dan
Mach V
Old 02-21-2013, 02:25 PM   #136
ThugNasty
Drives: Asphalt FR-S
--Dan
Mach V
He doesn't care about safety or performance. He just wants to be herrafrush.
ThugNasty is offline   Reply With Quote
The Following User Says Thank You to ThugNasty For This Useful Post:
USMC FR-S (04-01-2013)
Old 02-21-2013, 02:29 PM   #137
619_FRS
YUP!
Old 02-21-2013, 03:48 PM   #138
bigjake
Drives: 2013 Scion FR-S, Firestorm
I have never heard of those springs. Anywhore, I'm really gonna shit on Dans day, I'm running 17x10+15 WORK EQUIPs 05' with a 215/40. Tons of neg camber, and rolled/pulled fenders. I look so cool when I have no grip though.
bigjake is offline   Reply With Quote
The Following User Says Thank You to bigjake For This Useful Post:
Old 02-21-2013, 03:57 PM   #139
philstar
philstar's Avatar
Drives: Argento FR-S
If i recall correctly, I remember several of the Japanese tuners currently run a 18x9.5 with 225 setup, and their cars are catered towards performance and chasing time.
philstar is offline   Reply With Quote
The Following 2 Users Say Thank You to philstar For This Useful Post:
619_FRS (02-21-2013), HATED1 (02-21-2013)
Old 02-21-2013, 04:34 PM   #140
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Well they are much slower than they could be then.
The Following 2 Users Say Thank You to BlaineWasHere For This Useful Post:
Laika (02-23-2013), norsamerican (02-21-2013)
cr ultimate, fitment, ultramarine, work wheels
Wheel Directory: Work Emotion CR-Kiwami 18x8.5 +38 Jeff Lange Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 03-21-2018 06:18 PM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x9.5 +38 kimchangil424 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 01-03-2017 07:00 PM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 19x9.5 +38 Killerbee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 03-08-2014 05:49 PM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 19x10.5 +32 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 02-25-2014 07:00 AM
WTB: Work Emotion Ultimate Kiwami Wheels Center Caps hanabie Want-To-Buy Requests 0 10-25-2013 07:34 PM
