Old 10-20-2014, 03:49 PM   #127
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Originally Posted by Shutter View Post
so if you have the subaru 4pot swap, would running the Legacy GT front rotors help correct the brake bias?
Since the calipers are similar(Z32 vs wrx 4pot)
WRX 4 pot have been proven again and again to be worse than stock (or at least, not as balanced/useful)
Just an FYI
Old 10-20-2014, 04:11 PM   #128
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Just an FYI
Right, which is why I haven't put mine on yet haha.
That's why I was asking if adding the larger Legacy GT rotors would help balance it back out again. Since OP said the Z32 and 4pot were similar, and added the Legacy GT rotors with the Z32 setup, then wouldn't the larger rotors benefit the 4-pots as well?
Old 10-26-2014, 01:54 PM   #129
White64Goat
I'll let some brake engineers explain it, JRitt has someone on staff I'm sure. They can do a better job then I can.
Force via caliper *BODY* movement vs caliper *PISTON* movement is the difference. Given the same exact piston area, brake force is the exact same (everything else being equal).
The key benefits of fixed calipers are feel, modulation, and pad wear (less tapering as force is applied more evenly across the backing plates).
This is from my race car. Sliding calipers can exert PLENTY of force on the pad:
And so can the piston
Holy Shit..............!!
A little heat??
Old 10-26-2014, 03:45 PM   #130
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Yes, assuming you can still use the 4 pots (they would have to fit those brackets he used for the Z32 calipers).
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-26-2014, 03:49 PM   #131
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
A little heat??
Maybe just a little
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-26-2014, 03:53 PM   #132
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by zohare View Post
Anyone have experience with RacingBrake 1 piece rotors? @JRitt @Dave-ROR
Can't speak for any other products, from personal experience, or for their newer stuff- don't want to bad mouth, just check into it before spending $, which you're doing obviously. But check the vw forums... There are horror stories of their BBK calipers failing. The crossover simply breaking free from the caliper. Complete loss of brakes. Warranty denied. Biggest issue that everyone agreed on was crappy customer service. Perhaps not?
What about a DBA 4000 series for the LGT? Don't they have better cooling vanes? Since we have essentially determined the weight while increased, is very much negligible, (other than in your mind KNOWING it's there :P) but cooling should be better, why not just improve the good qualities you have- since removing mass from the rotor *COULD* remove cooling potential- or maybe offset by better vaning? God knows. My head hurts from this read, but thanks everyone for all the info.
More OT Crap here - - - I should also note- I'm extremely proud of myself for my calculations on my own being determined as what was right. Totally patting myself on the back, you can all hate me for it. re-reading, trying to help my buddy with his celica GT-S not have to pay for a freaking TRD bbk. *SIGH* Told him tires. Auto-x, determine next issue. Hoping to find a vented rear OE brake for it, and then use Avensis front brakes. Same piston, larger pad, larger rotor, so need to balance it out in the back. his back brakes look like my 94 Miatas... Pathetic. Then again, my 94M will stop dam good for what it is. Not... a ton of times. but once or twice :P OH yeah, *facepalm* brakes don't stop car brakes don't stop car *repeating in head*
Not a waste of time, you made this amazing thread.
You guys freaking rock. I love this forum, so much less ... abusive? than others, and I always learn something... and hopefully don't dump it later. Thanks for putting this together OP! Following closely, and if for NOTHING ELSE than cosmetics, this could be worth it to me if it doesn't make the brakes worse, I do drive hard? Spiritidly? (I've definitely cooked the stock pads before...) but when brake upgrade time comes around, might do this instead of the pads/rotors/lines with stock brakes, and just tack on a bit more, and do calipers as well.
I haven't used anything from RacingBrake. I've driven on cars with DBA 1 piece rotors but not the 2 piece setups. The 1 piece is basically like stock from what I could notice.
My brakes (and car) will be up for sale soon. Going back to MR2s.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-26-2014, 04:28 PM   #133
gramicci101
Off Topic
What niche will an MR2 fill for you? Same one as the BRZ?
Old 10-26-2014, 08:03 PM   #134
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
MR with torque and HP
And since there will be no car payment, and I'll likely buy a 94 or 95 it won't be a massively depreciating asset (just a regular one) it should be a nice change.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-31-2014, 02:08 AM   #135
OmarYasin
OmarYasin's Avatar
Wile im considering this mod, i realize that the legacy rotors are heavier, i cant for the life of me find project mu rotors for the proper legacy, i cant find dba or hawk rotors either, 294mm not 317mm is there any other rotor that can be used that might have more aftermarket options? As far as pads i can find pmu pads all day for the z32.
OmarYasin is offline   Reply With Quote
Old 10-21-2015, 08:08 PM   #136
RedFR-s
Builder/Driver/Enthusiast
RedFR-s's Avatar
Drives: 2013 FR-S 6MT Turbo Firestorm
Sorry for digging up and old thread, but I'm looking into this for my FI build.
How'd the rear brakes work out? Did the e-brake fit into the legacy rotors ok?
Andy
1977 Triumph Spitfire 1500 - New Project
2013 Firestorm FR-S 6MT Turbo - Sold
2013 Honda CBR 250 Repsol- Toy
2017 Toyota Tacoma - The Rig
RedFR-s is offline   Reply With Quote
Old 05-03-2016, 09:49 PM   #137
asnatlas
Drives: 2013 - BRZ - SWP
Any updates ?
asnatlas is offline   Reply With Quote
Old 05-05-2016, 09:38 PM   #138
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Funny seeing @hmong337 like my old posts about buying MR2s.. and now I have two. One for sale soon
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 05-05-2016, 09:49 PM   #139
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Lol... damn guy buying up all the 94-95‘s! Super jealous. I still like my sw20 more than my frs...
hmong337 is offline   Reply With Quote
Old 05-05-2016, 09:50 PM   #140
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I'm with ya. The 93 86,000 mile car will be going up for sale. Replacing ALL coolant lines, timing belt, water pump, etc as preventative maint first so new owner doesn't need to bother. Also tires and ignition bits.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 12:29 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-24-2013 11:26 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
