Old 04-14-2014, 07:09 AM   #127
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by SHIFTER View Post
Looks like Ca-Fi sent out a customer wide email tonight for people who bought the initial batch of the Dashlinq4 regarding the ipod issue you're experiencing!
Interesting, I didn't receive that email, but then again I haven't received my head unit yet either. Got an email this morning with the tracking info. It should actually be delivered this afternoon.
Old 04-14-2014, 09:43 AM   #128
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
You probably didn't get a unit that was affected. They said it was just one batch fortunately.
Congrats on the purchase. Post pics when u get it
Andrew
2013 Scion FR-S MT (Silver)
2011 Toyota Rav4 Sport V6 4wd (Silver)
SHIFTER is offline   Reply With Quote
Old 04-14-2014, 11:43 AM   #129
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
Contemplating going this route since I've upgraded every item but the headunit. Currently running an lc6i to convert the audio seeing as their are no preamp outputs on the brz headunit.
My only concern is the lack of separate front and rear channel preamp outputs like on most aftermarket headunits.
SubaSteve is offline   Reply With Quote
Old 04-14-2014, 12:09 PM   #130
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
Has anyone confirmed if another bluetooth OBD will work with this, and not just the one they sell?
Deathalo is offline   Reply With Quote
Old 04-14-2014, 03:54 PM   #131
bgibbsunc
bgibbsunc's Avatar
Drives: Firestorm Scion FR-S
I would also like to know this as I would rater use a cheap low profile elm then to buy their bulky obd2 reader. This would load the bullet for me.
FA20 club 60 trim + flex fuel
467 whp 356 ft lbs @ 19 lbs
Owner of Sidewinders Auto LLC.
San Antonio TX
bgibbsunc is offline   Reply With Quote
Old 04-14-2014, 04:23 PM   #132
xjohnx
Grip>Slip
xjohnx's Avatar
so mine arrived, i've got blue and grey wires though. any ideas?
Old 04-14-2014, 05:08 PM   #133
Deathalo
BANG!
Old 04-14-2014, 05:24 PM   #134
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I'm going to assume they used grey instead of the violet.
Old 04-14-2014, 05:27 PM   #135
xjohnx
Grip>Slip
xjohnx's Avatar
yeah, i figured that much. I'm just not sure if they still need to be swapped or if the harnesses with the grey wire are good to go?
Also, @SHIFTER - any tips for ejecting the SWC pin so i can reuse it for the amp wire?
Old 04-14-2014, 05:43 PM   #136
Andrew025
Andrew025's Avatar
If they kept the blue pinned the same, you may have to swap it since it looks like it should be where your grey wire is.
Old 04-14-2014, 06:05 PM   #137
DC2R
Drives: 2014 Scion FR-S
You could just buy obd2 extension ribbon flat cable from Amazon and pout module wherever
Sent from my GT-N5110 using Tapatalk
DC2R is offline   Reply With Quote
Old 04-14-2014, 07:51 PM   #138
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
You probably don't need to swap the pins. Plug it in and try it first.
Andrew
Old 04-14-2014, 07:51 PM   #139
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
Needle nose pliers, smallish ones. Grab onto the end of the pin and push inward and it should pop out.
Andrew
Old 04-14-2014, 07:52 PM   #140
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
Thats what I did.
Andrew
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 06:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 03:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 04:58 AM
