Old 02-24-2014, 04:00 PM   #127
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
Originally Posted by cdrazic93 View Post
At what point do your internals become the weak point? Seems like the intake mani, and (larrrrge) turbo would provide such an increased air flow & pressure that in any case of boost creep...your internals would crumple...right?
There is no boost creep on appropriately sized external wastegate applications. Some other factors like exhaust scavenging, blah blah. Mostly the wastegate.
I imagine with larger intake runners you would enjoy a little bit less knock/heat and more turbo efficiency. More flow = less boost needed. Remember 12psi @ 500cfm isn't the same as 12psi @ 750cfm, you could run more efficiently at like 8psi @ 750cfm. These are example numbers not actual figures.
From what I know, this motor is pretty well balanced, no issues with factory oiling equipment, very strong crank. Tolerances seem pretty darn good to be honest if you maintain it well.
So just remember that heat kills. Heat is a by-product of pressure. If you keep the heat down, you keep the dangerous pressures down. This is why I'm going with an EGT at some point to backup the wideband and re-affirm running 20+ psi is safe enough (for me).
Ironsquid is offline   Reply With Quote
Old 02-24-2014, 04:05 PM   #128
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Originally Posted by SkAsphalt View Post
Fun fact, NOS isn't ricer, so why is everyone hating on it?
No hate for chemical superchargers. Truth be told it's more efficient than turbos.
I hate the community that resorts to using it (outside pro-am/pro circuit racing). Seems like cheating, it's not, but it is =P
btw I used to spray 250 shot on my WS6.
The Following User Says Thank You to Ironsquid For This Useful Post:
SkAsphalt (02-24-2014)
Old 02-24-2014, 04:20 PM   #129
Dipstik-sportech
Dipstik-sportech's Avatar
I had a 150shot on my Ranger and a 75 on my Yota pickup.
The Frozen North
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
SmsAlSuwaidi (02-24-2014)
Old 02-24-2014, 04:23 PM   #130
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Originally Posted by lbroskee View Post
ricer no, but IMO it's like using Gameshark on video games lol
I was a Game Genie kind of guy
The Following 4 Users Say Thank You to SkAsphalt For This Useful Post:
lbroskee (02-24-2014), OjiGeorge (05-20-2014), raven1231 (02-24-2014), Rosticles (03-21-2014)
Old 02-24-2014, 04:29 PM   #131
raven1231
I always used that analogy lol
The Following 2 Users Say Thank You to raven1231 For This Useful Post:
lbroskee (02-24-2014), SkAsphalt (02-24-2014)
Old 02-24-2014, 06:13 PM   #132
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
Originally Posted by SmsAlSuwaidi View Post
Lol nobody said its ricer, nor are we hating. We are just throwing jokes around, if i had a built block id spray the fuck out of it w/ e85 and a shit load of boost @Dipstick-stoptech ehm
Sent from my IBrick
I'm not hating on it, just having some fun
When I think of NOS, I think of F&F or NFS Underground, good times
leicaboss is offline   Reply With Quote
The Following User Says Thank You to leicaboss For This Useful Post:
Old 02-24-2014, 07:40 PM   #133
carlossanchez89
2Supras1FR-S
Drives: 13 Scion FR-S, 87 Supra
If upgrading to this manifold. Will a re-tune be required @FullBlown
carlossanchez89 is offline   Reply With Quote
The Following User Says Thank You to carlossanchez89 For This Useful Post:
Old 02-24-2014, 08:01 PM   #134
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
You can almost bet on a retune being required...if it's required for an intake you can be damn sure it'll be required for a manifold. Lol
Tuned by Delicious Tuning
http://www.delicioustuning.com/node/209
Kraftwerks Supercharged
Zach3794 is offline   Reply With Quote
Old 02-24-2014, 08:12 PM   #135
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Yep lol
I love boost!!!!!!
Old 02-24-2014, 08:42 PM   #136
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
A new tune for an intake is normally required because it modifies the MAF location, flow, and/or pipe size. This new manifold doesn't modify the MAF, but will hopefully flow a ton of extra air and require a retune.
The Following User Says Thank You to King Tut For This Useful Post:
SirBrass (02-25-2014)
Old 02-24-2014, 08:45 PM   #137
OrbitalEllipses
Drives: Attitude
A new tune for an intake is normally required because it modifies the MAF location, flow, and/or pipe size. Hopefully this new manifold doesn't modify that, but will flow a ton of extra air and require a retune though.
It would be idiotic to add a new manifold and not tune for it. Might as well have kept the stocker if you won't tune for it, nomsayin'?
Old 02-24-2014, 08:48 PM   #138
King Tut
NASA SpecE30 Racer
King Tut's Avatar
This car ain't a Honda doe. It has fuel trims and can adjust for the additional air to a point. Like I said, I hope it flows considerably more air and does require a retune.
Old 02-24-2014, 08:49 PM   #139
FullBlown
FullBlown's Avatar
Drives: Scion FRS
We will know soon. Just need to put a car back together lol
FullBlown is offline   Reply With Quote
Old 02-24-2014, 08:53 PM   #140
OrbitalEllipses
Drives: Attitude
The Following 19 Users Say Thank You to OrbitalEllipses For This Useful Post:
Brody602 (03-07-2014), charged86 (02-25-2014), Creole (03-04-2014), dabocx (02-25-2014), Dipstik-sportech (02-24-2014), diss7 (02-25-2014), Dr Evil (03-06-2014), Hanni_0176 (02-24-2014), JackSmiley (02-25-2014), JDogg (02-24-2014), JustBoostin (02-24-2014), lbroskee (02-24-2014), Marcoscrdo (02-26-2014), mrk1 (03-06-2014), mxsled (02-24-2014), ShadowSeraph (02-25-2014), SirBrass (02-25-2014), SkAsphalt (03-14-2014), SmsAlSuwaidi (02-24-2014)
Intake Manifold Bu-Tang Engine, Exhaust, Transmission 29 12-06-2014 02:43 PM
Intake manifold cover protpibe Engine, Exhaust, Transmission 16 02-28-2014 07:44 PM
Wanted intake manifold ciro Want-To-Buy Requests 0 09-27-2013 01:03 PM
Aluminium intake manifold? Hempo Engine, Exhaust, Transmission 18 06-27-2013 02:19 PM
WTB: intake manifold carlitosway6891 Engine, Exhaust, Bolt-Ons 0 06-22-2013 03:24 PM
