Old 02-19-2014, 08:27 PM   #127
xia
Drives: 1995 Supra TT & 2013 FRS
Anyone have this lip from them? Seems like people on this thread are more for or aiming for the T-style (TRD Rep). I want to know how the fitment is before pulling the trigger. I just need something cheap so when I hit something it wont damage my bumper.
http://www.ebay.com/itm/12-14-Scion-...4157f9&vxp=mtr
xia is offline   Reply With Quote
The Following User Says Thank You to xia For This Useful Post:
carlovestela (06-04-2018)
Old 02-19-2014, 10:06 PM   #128
jonathan9573
jonathan9573's Avatar
Drives: 2013 Asphalt Scion FR-S
Try this thread:
http://www.ft86club.com/forums/showthread.php?t=43566
Sent from my iPhone using Tapatalk 2
jonathan9573 is offline   Reply With Quote
Old 02-21-2014, 01:34 AM   #129
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
Bayson R Motorsports Bodykits (good or bad)
You guys that have the TRD kit, can you explain how you've mounted the side skirts?
I know there are brackets underneath, along with the screw holes that go inside the wheel well/mud flap holes. Did you guys drill for the rear holes? I believe the front lines up with the mud flap mounting holes. Should I also use 3m tape?
Joe-G is offline   Reply With Quote
Old 02-21-2014, 01:39 AM   #130
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Before you put anything to your car, you should at least wash the area. By test fitting on a dirty surface, you are only going to scratch your paint. No comment on the mounting...
Old 02-21-2014, 01:44 AM   #131
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
No worries. I'm having the car polished come summer anyways. Doesn't really make a difference with all the swirls/micro scratches on there already.
Besides, it's not like I had to force the parts on. They pretty much just sat there :/
Old 02-21-2014, 02:16 AM   #132
boredom.is.me
Custom User Title
The dreaded swirls....
Old 02-21-2014, 07:41 PM   #133
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Got the front bumper and sti rear spats on after work today. Skirts go on tomorrow then some real pics
The Following 2 Users Say Thank You to spitfire481 For This Useful Post:
JW89225 (02-21-2014), van_fc3s (02-22-2014)
Old 02-25-2014, 05:33 PM   #134
congee
congee's Avatar
Drives: SSM BRZ
Originally Posted by Tim_Asphalt_FRS View Post
Update: more pics posted. The asphalt does kinda have a blue metallic to it at certain angles.
That looks pretty amazing for such a inexpensive spoiler.
Will probably order the same one soon. Any issues with it now?? Has it shifted?? And did you use the existing holes from the trunk or just used the double sided tape that came with it???
congee is offline   Reply With Quote
Old 02-26-2014, 01:27 AM   #135
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
[/URL]
Is it completely necessary to remove the front bumper? In regards to attaching the lip to the front bumper via the holes behind the plate, did you drill a hole and use the supplied bolt/washer/speed nut? Or did you end up using a washer/self tapping screw?
Old 02-26-2014, 09:31 AM   #136
spitfire481
Drives: 2JZ FRS
I just used two course threaded screws. No nut or anything. Only reson I pulled the bumper was to replace my worn bumper brackets at the same time
Old 03-04-2014, 09:47 PM   #137
jonathan9573
Well I think the time has come to modify the license plate on the front bumper. My plan is to make a mold of the piece to replace the area that will be cut out from the license plate area and vacuum mold some ABS to create a piece that will fit into the removed area and molded in with minimal body work. I am also hopefully going to add usable area to be able to use double sided tape to attach the top part of the lip to the bumper.
Old 03-04-2014, 09:58 PM   #138
Midarete
Midarete's Avatar
Drives: Whiteout FRS
Not sure if you answered this before but did the STI rear spats needed to be drilled in?
Midarete is offline   Reply With Quote
Old 03-04-2014, 11:16 PM   #139
spitfire481
Drives: 2JZ FRS
Double sided tape along the top and rear, then uses an oem hole underneath for a push in clip
The Following User Says Thank You to spitfire481 For This Useful Post:
Midarete (03-05-2014)
Old 03-05-2014, 01:03 AM   #140
Midarete
Midarete's Avatar
Thanks man! Those are the BaysonR ones right?
Bayson R lip kit review Cjymiller Cosmetic Modification (Interior/Exterior/Lighting) 59 07-06-2017 02:23 PM
Weather strip/Rubber seal for bodykits FRSHunter Cosmetic Modification (Interior/Exterior/Lighting) 4 03-08-2016 05:34 AM
Weatherstrips for bodykits FRSHunter Exterior Parts (Aero, Lighting, Etc.) 1 12-14-2013 10:15 PM
Who has Bayson R Lip kit? Cjymiller Northern California 21 09-29-2013 10:52 AM
Bodykits....Bodykits....Bodykits.... FT-86GOD AUSTRALIA 78 08-08-2012 10:44 AM
