Old 08-05-2013, 11:01 PM   #1
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
Bayson R lip kit review
I recently found the time to install the Bayson R front lip on the BRZ. I am pleased with the result and thought I'd post my experience here.
I picked up the kit in person, from their store here in San Jose,CA. The people on site opened up the packaging and held the piece in place so I could make a final decision. Upon initial inspection, the front lip was warped in a way that did not allow it to properly fit. They convinced me that this could be easily addressed by leaving the piece out in the sun for an hour or two.
This turned out to be true. Leaving the Polyurethane piece out in the sun allowed it to warm and take it's natural shape. Once, warm and pliable, we were able to go to work drilling the front bumper and mounting the lip.
The kit included 14 nuts, bolts, and washers and no instructions. I was told at the store that installation would be easiest if I removed the front bumper. I decided to keep the bumper in place since I had an extra pair of hands to help out. Admittedly, some of the bolt points would be much, much easier to reach and tighten had I removed the bumper.
Overall I am definitely satisfied and would suggest others purchase as well. I will include the side skirts review in this post after I find time to install them.
TL;DR
Installation difficulty: 4/10 (3/10 if you remove bumper).
Approx time: 2hrs
Quality of product: 9/10
Fitment: 9/10
Rice Rating: 3/10
UPDATE: Side Skirts Installed
Installation time took 2 hours for the side skirts. It was a very straight forward process.
Installation difficulty: 3/10
Approx time: 2 hrs
Fitment: 9/10
Rice Rating: 2/10
Initially Bayson R sold me a set of side skirts that had a poor and inconsistent finish. This was due to the factory in Asia packaging the pieces before their finish had time to set. As a result, you could see the pattern of the bubble wrap in the finish of the piece. Kevin at Bayson R was very helpful in restoring my side skirts to a proper finish. We even tore open another 4 packages and they all had the same poor finish. After dropping the sides skirts off on Friday, I had them in hand by the next Monday and they finish was back to normal.
Each side fastens securely with 5 self tapping screws and 2 nuts and 2 bolts for the ends.
Photo Dump:
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
The Following 20 Users Say Thank You to Cjymiller For This Useful Post:
Alain (02-15-2014), BAOVAN (01-13-2017), brenesk91 (08-25-2013), CaptainSlow (03-31-2014), charged86 (08-05-2013), Choco (01-21-2015), Dadhawk (02-09-2015), D_Thissen (09-01-2014), Guff (01-12-2014), improvius (08-21-2017), Loki2x (08-05-2013), Marcoscrdo (03-16-2015), MileMonger (02-01-2017), Noli (02-08-2014), sprintertrueno86 (08-06-2013), srizzors25 (07-01-2015), steezypenguin (08-06-2013), Suffa (08-05-2013), weepel (09-18-2014), Zechs21 (02-15-2014)
Old 08-06-2013, 12:57 AM   #2
Vmax911
Drives: WRB BRZ
Thanks for the review. I see they sell on eBay, I think I'm gonna pick one up!
Vmax911 is offline   Reply With Quote
Old 08-06-2013, 01:31 AM   #3
sprintertrueno86
sprintertrueno86's Avatar
Drives: 2018 BMW M2
Do you have to remove the undertray to install the lip?
Can you install without jacking the car up?
sprintertrueno86 is offline   Reply With Quote
Old 08-06-2013, 01:35 AM   #4
Perihelion
Unemployed DIY Ninja
Perihelion's Avatar
Drives: 2013 SWP BRZ, 1983 MB SD300
No x2
Perihelion is offline   Reply With Quote
The Following User Says Thank You to Perihelion For This Useful Post:
Old 08-06-2013, 01:46 AM   #5
norcal_brz
Drives: 04 Evo 8 SSL, 13 Brz Limited
how much picked up at bayson r?
norcal_brz is offline   Reply With Quote
Old 08-06-2013, 03:16 AM   #6
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
You don't have to jack up the car if you remove the bumper, otherwise, you need to raise the car to be able to drill from underneath.
Whichever way you decide, you will need to remove the under-body panel located in black on the ground in this picture.
Even though this is a different lip, it covers the underbody panels that are to be removed:
[ame="http://www.youtube.com/watch?feature=player_embedded&v=EEOCncqEdp4"]HT Autos Front Lip Spoiler - Unboxing, Install and Review - 2013 Subaru BRZ - YouTube[/ame]
I got front lip and side skirts for $300 cash OTD.
φφκα
The Following 2 Users Say Thank You to Cjymiller For This Useful Post:
sprintertrueno86 (08-06-2013), Wolfking (08-06-2013)
Old 08-06-2013, 05:34 AM   #7
Freude am Fahren
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
I wish I would have known about leaving it out in the sun (and having an extra hand). Also those guide clips would have been nice. Mine is a bit off, so I'm going to have to re-drill , ugh.
-XXR 527 18x8.75 +35
-Nameless 2.5" OP/FP Combo (Coming soon) & Axleback
-SBD 500X (Waiting on coating to install)
-Southbend SBD500X Clutch
Freude am Fahren is offline   Reply With Quote
Old 08-06-2013, 01:29 PM   #8
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Yeah, warming it definitely helps. I don't think the guide clips demonstrated in the video are applicable to the Bayson R kit, just the HTAutos one. I found it was easiest to drill the center hole first to ensure that the fangs of the lip and bumper were lined up as best as possible. Once I had that location, I proceeded outwards on either side. We muscled the last few drill locations to ensure a good fit.
φφκα
Old 08-06-2013, 01:38 PM   #9
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
if you hate to drill your bumper, you could use 3M VHB tape. That would be the easiest way to do.
However, the side skirts don't work well with 3M VHB tape. You should be looking something like Tigerseal.
hanabie is offline   Reply With Quote
Old 08-06-2013, 03:40 PM   #10
OoLong
#TeamAURA
OoLong's Avatar
Drives: BRZ Limited Lighting Red '13
I was thinking about the same thing. Could the tape be too thick? So in return it might cause from offset from the bumper? Sorry, just a case of OCD.
OoLong is offline   Reply With Quote
Old 08-06-2013, 04:00 PM   #11
hanabie
hanabie's Avatar
I believe it's 0.45mm. It depends on which type of VHB you will be using.
I used VHB 5952. The highest grade will be 4952. Yes There will be a slightly offset which is really not noticeable. You could warm the lips up by using heat gun.
Fyi, the Bayson R front lip looks exactly the same as mine sold on ebay for ~100. Ht auto lips and sti lips are different.
Old 08-07-2013, 11:02 AM   #12
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
In for the skirts review. Hope it will look good with an sti lip as I don't like their side skirts.
Old 08-07-2013, 11:34 AM   #13
DarkestBuddha
Drives: BRZ limited GBS
this lip and skirt is being sold on here as the CS poly ones.
i have it installed and looks great.
and also drilling the holes isnt so bad, since its going to be covered and if you remove it just cover the holes with some tape. . .
noone is going to see the underside of your car anyways
also some type of glue should be used on the skirts if you arent going to drill
the tape will give you a gap
DarkestBuddha is offline   Reply With Quote
Old 08-24-2013, 07:44 PM   #14
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
First post updated with the side skirts installed! LMK if you want another angle for a better view!
φφκα
Who has Bayson R Lip kit? Cjymiller Northern California 21 09-29-2013 10:52 AM
The 86 – My Review Thavash AFRICA 70 03-07-2013 03:01 AM
Perrin Pulley review? Invidia Q300 exhaust review? ScionFrsFan Engine, Exhaust, Transmission 4 12-10-2012 09:27 PM
EVO magazine review of GT86/BRZ review out TheRoadWarrior Scion FR-S / Toyota 86 GT86 General Forum 6 01-05-2012 09:26 PM
AutoExpress BRZ Review - Follow up to the GT86 Review Zgrinch BRZ First-Gen (2012+) — General Topics 3 12-13-2011 09:03 AM
