10-31-2013, 10:27 PM | #127 | |
Are you on the stock pulley? Verify your alignment of pulleys. There is a lot of play in angle. A few degree's can cause too much tension. Unbolt the two bolts on the top of the alternator bracket, they are slotted so that you can slide the top of blower forward / back away from the firewall. Personally I never broke a belt on the stock pulley, only my smaller one and this was also related to over-sized belt. I put a good 8k miles or so on the standard 3.48" belt with fairly "spirited" driving sessions of 30+ minutes that rarely hit lower than 4,500RPM
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
The Following User Says Thank You to nelsmar For This Useful Post: | Mersd (11-01-2013) |
11-01-2013, 08:42 PM | #129 |
For which pulley, and which belt, the standard or racing?
11-03-2013, 01:00 AM | #130 |
Winter Is Coming
Drives: 2013 Scion FR-S Ultramarine
http://www.raceseng.com/revo-pulley-...r-s-subaru-brz
anybody know if the idler pulley in this kit would work? thought I might just replace all and make it look clean if I had to get a new idler anyway |
11-03-2013, 10:00 PM | #131 |
Drives: WRB BRZ
Vortech idler pulleys seizing and belts breaking
The idler on the vortech SC is the issue.
11-18-2013, 04:31 PM | #132 |
Just a dude
Drives: Scion FR-S 2013
So wanting to know "now" latest kits, assuming a guy does a great install, doesen't deciat from stock goods meaning no other pulleys etc, straight 91 gas tune, is this now a reliable no fuss kit? No cutting or modding needed and all bolt in?
11-18-2013, 05:48 PM | #133 | |
Thupercharged
If you want added insurance, get the gates racing belt and a new pulley for the supercharger bracket. Never had issues with my kit until the pulley went bad, and it just squeaked a lot... 10 dollar fix
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
11-19-2013, 03:13 PM | #134 |
Drives: GMC
Should I have any additional concerns about running my Kartboy lightweight crank pulley pulley with the supercharger? I've noticed people sell off their lightweight pulleys when they go FI claiming that "the difference would be negligible", but would I have any added risk of ruining my belt? I've had the pulley on my car for about 6 months.
11-19-2013, 04:59 PM | #135 | |
SLO NO MO
Sent from my Nexus 5 using Tapatalk |
11-19-2013, 05:03 PM | #136 | |
Thupercharged
If it's the same diameter/fitment as oem you should be good to go.
2013 FRS
11-20-2013, 06:53 AM | #137 |
Drives: Scion FS-R
I sent vortech a message about other belt replacement and they said to use gates k060970 which is different then what comes in the kit, k060975. It seems to be a half inch shorter.
12-22-2013, 07:16 PM | #138 | |
Drives: FR-S :)
12-22-2013, 07:37 PM | #139 | |
Thupercharged
Autozone/amazon/rockauto
2013 FRS
The Following User Says Thank You to DJCarbine For This Useful Post: | p00mba (12-22-2013) |
12-25-2013, 03:29 AM | #140 |
Drives: Toyota 86
I have a Vortech on order and now I'm getting nervous with all these belts snapping and breaking can somebody post some links on where I can buy spare belts and idler pulleys online for the stock 9psi pulley?
The Following User Says Thank You to HRTROB For This Useful Post: | ZionsWrath (12-25-2013) |
Similar Threads | ||||
Kartboy Crank Pulleys 95.00 | tom@kartboy | Engine, Exhaust, Bolt-Ons | 16 | 06-11-2013 01:06 PM |
Crank,Alternator,Waterpump Pulleys etc..? | fareastbrz | Engine, Exhaust, Transmission | 6 | 05-28-2013 08:46 PM |
Titan Performance second batch of pulleys | Amalgamo | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 07-30-2012 09:57 PM |
